School me Sparky!! - Spark Plug Variety
Discussion in 'Trials' started by Greebe, Nov 1, 2018.
  1. Ymirtrials
    Ymirtrials Long timer Supporter
    Jan 12, 2012
    1,218
    Ymir BC Canada
    Does the enamel hold up on fasteners even at higher torque requirements like head bolts/studs?
    #41
  2. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    4,626
    Upper Michigan
    They worked for me and thanks.
    #42
  3. Junglejeff1
    Oct 20, 2016
    4,626
    Upper Michigan
    Years ago I purchased one of those hot coat guns from Eastwood. I drill holes in copper flashing,drop them in and powder coat them.works great on Allen heads but tends to chip on nuts and bolts.If I am working on other people's bikes will clean and coat with antisieze. Unreal how well that stuff stops corrosion. I always wanted to try cadmium coating but never seem to find the time.
    #43
    Ymirtrials and Brewtus like this.
  4. Thumbster
    Thumbster Adventurer
    May 28, 2019
    34
    Eastern Indiana
    Ok, for us in the back of the room...
    Denso W16FPR-U = NGK BPR5HS
    Is that correct?
    From what I have read the Denso “F” and NGK “H” designate 1/2” (12.7mm) reach.
    The Denso “16” and NGK “5” are heat range but I don’t know if they’re similar.
    The P and R on both plugs mean projected electrode and resistor (insulated).
    The Denso “U” indicates it’s their standard (not fancy) plug and I assume the NGK “S” means the same.
    I don’t know what the Denso “W” or NGK “B” means.
    fwiw the Denso W16FPR-U came with my 2018 Factory Sherco 250.
    #44
  5. Thumbster
    May 28, 2019
    34
    Eastern Indiana
    To answer my own question. I found this heat range chart on NGK’s site.
    #45
  6. Thumbster
    May 28, 2019
    34
    Eastern Indiana
    Not sure the longer 3/4” (19mm) plug will fit even though the manual and 3 dealers say it will. Central Kentucky Motorsports even looked it up on the parts fiche and it said use longer plug.
    This is the 1/2” (12.7mm) plug next to my certified McDonald’s straw showing how much room I have to the piston at TDC.
    Assuming the 3/4” (19mm) plug is actually 22.56mm counting the electrode that only leaves 4.24mm (a little over 1/8”) between the plug and piston.
    I’m no engine builder but I think I’ll stick with the 1/2” plug unless someone can convince me otherwise. 1/8” seems pretty close.
    #46
