Seat damage.
Discussion in 'The Garage' started by Nandoclp, Oct 7, 2019.
Tags:
  1. Nandoclp
    Nandoclp “V-Strom 650 XT Rider"
    Feb 28, 2019
    20
    São José dos Campos SP Brazil
    The seat of my motorcycle (V-Strom 650 2019) suffered minor cuts caused by a social parasite (cat). I wonder what repair options are available to prevent water from entering ... Thank you!
    PS: Sorry for the bad english !!!
  2. TripleTriples
    TripleTriples Long timer
    Feb 6, 2019
    1,451
    OH
    baldman1 and Nandoclp like this.
  3. Zuber
    Zuber Zoob Supporter
    Sep 28, 2004
    6,866
    West of the West, Oregon
    Vinyl spray paint, for vinyl seats. It actually sprays vinyl. Use in a really well ventilated area. I've sprayed it into a cup, then use a stick to trowel it into minor cuts. Can look like original if you have skills.
    Nandoclp likes this.
  4. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    9,916
    Anchorage, formerly Spenard (hub of the universe)
  5. PeterW
    PeterW Long timer
    Nov 11, 2005
    4,657
    Gold Coast
    1) Kill the cat, skin it and use it to cover the holes.
    2) Seat concepts base and cover.
    3) Seat covers from eBay
    4) Local furnishing store, buy some vinyl & DIY. Won't look great, but it will work.
    5) Phone round automotive and marine upholsterers. Most can do a really good job on a bike seat.
    6) If you haven't disposed of the cat yet :), work through options 2-5 until you get pissed off enough to do that.
    And yeah, shoe goo will also work, sortof.
    If you have a compressor you can do better. Get an air stapler and stainless staples, pull the staples at the front, repair from underneath using a vinyl repair kit (Camping stores sell them for fixing holes in air mattresses) and put a waterproof layer under the repair, staple it back down. With CARE you can make that almost unnoticeable. (Something like heavy duty garbage bag, or phone around and see if you can find something intended for the job). Problem with using common household plastics is that most will break down.
    A lot of those options need an air stapler, if you have a compressor and are in the US, cost is around $30. A hand stapler is NOT good enough.
    Note: I like cats, I have a cat but seriously some things are above and beyond ;)
  6. kantuckid
    kantuckid Long timer
    Nov 29, 2007
    9,912
    Kentucky-Eastern that is!
    #3 then daub it in with an artist brush or small matchstick like end and then smooth tape it (to flatten the repaired area) for a day or so until it dries. You don't need $30 worth of colors, just black. There are many brands of vinyl repair material.
  7. foxtrapper
    foxtrapper Long timer
    Sep 6, 2011
    4,431
    Turned the child loose with some of his black Sugru to fix some splits/tears on my Honda seat. Been several years now, the repairs are holding up just fine. It's visible, but you have to actually look at it to see it.
    There is also the likes of tear-aid tape.
  8. Maggot12
    Maggot12 U'mmmm yeaah!!
    Feb 21, 2010
    19,933
    Canada's ocean playground
    I'd look into options mentioned.
    Fix it with some vinyl spray, maybe liquid electrical tape.
    Seat cover from ebay and staple over the original.
    I'd also be concerned that the cat will return to it's new found scratch pad.
    #8
  9. Salsa
    Salsa Long timer
    Dec 12, 2006
    1,320
    Arizona, Alaska
    Vinyl Glue
    Don
    #9
  10. big-g-nm
    big-g-nm Adventurer
    Jan 23, 2010
    81
    New Mexico
    I have used black RTV (room temperature vulcanizing) sealant on a couple of motorcycle seat covers that were sun dried and cracked, and it worked okay. Appearance was not an issue for me but I did sculpt it a little so it at least followed the original seat cover embossing pattern. I roughed up the area around the cracks with sandpaper to give it some "tooth" to bond to and it's held up for several years on my old bikes.
    #10
  11. Nandoclp
    Feb 28, 2019
    20
    LOL... Thanks man!
    #11
  12. Arbolmano
    Arbolmano Not so Studly
    Feb 1, 2014
    265
    Commiefornia! 93420
    Sheepskin cover EZ an useful. Cat may be back. Repair seat, no worry about appearance. I like to go to scrap yards and
    get fancy car seat covers from wreck, cut out seat cover. Sheepskin much nicer to your precious parts if left to sit in the hot sun.
    Toss in pannier if rain threats.
    #12
  13. H96669
    H96669 A proud pragmatist.
    Nov 20, 2009
    5,938
    Hiding off Hwy 6, B.C.
    #13
  14. rotaxhippie
    rotaxhippie more cowbell
    Aug 14, 2009
    96
    Eagle, ID
    Water is going to enter your seat foam regardless of whether the cover is intact or not. Most marine vinyls shed water away, but the seat foam will still get wet if you ride or let the bike sit in wet conditions. We use VLP for small cuts to keep the vinyl from tearing further. It seals looking like super glue.
    #14
