Seat lock zuma
Discussion in 'Battle Scooters' started by bravada, Nov 30, 2019.
  1. bravada
    bravada Been here awhile
    Sep 18, 2011
    271
    Just received my sons 09 Zuma 125. Bunch of stuffed under the seat.now it won't open. What are ideas that work .
    Battery is charged the scooter starts and everything works except the seat lock.
    Thanks in advance !
  2. MJSfoto1956
    MJSfoto1956 Been here awhile
    May 12, 2017
    505
    Boston, MA
    You did try to turn the key in the right direction?
  3. av8erdunn
    av8erdunn Been here awhile
    Oct 9, 2014
    648
    Sit on the seat or push down compressing it where the latch is. Then try to unlock it at the same time. It’s more than likely in a bind therefore it can’t unlock.
    vertex and Wentwest like this.
  4. bravada
    Sep 18, 2011
    271
    Tried both suggestions
    Could someone take a pic of the underside of the seat and lock/ latch might try to push a screwdriver in and release it.
  5. MiniBike
    MiniBike Still here...
    Oct 1, 2010
    5,982
    Cowford
    I don't know if the Zuma lock is cable actuated, but I had a bad lock on one of mine and found I could still open the seat by reaching up under the scooter (mine was near rear side cover), grabbing the locking cable and tugging it (while compressing the seat just a bit).
  6. MJSfoto1956
    May 12, 2017
    505
    Boston, MA
  7. balnobbers
    balnobbers Been here awhile
    Apr 27, 2014
    185
    Midwest
    Removing the rear tail light helps. I've locked my keys in my storage compartment once or twice.
  8. bravada
    Sep 18, 2011
    271
    Thanks, I did find a video on YouTube just access the cable and yank it. Seems like accessing it will be the trick
    #8
  9. balnobbers
    Apr 27, 2014
    185
    Midwest
    Also having a spare helps also.
    #9
  10. vagent
    vagent n00b
    May 18, 2020
    4
    Hampton VA
    To preclude it happening in the future, tie a strong nylon fishing line to the release mechanism (figure out what makes it release) and hide the line behind the seat or frame. Next time it happens, just pull on the nylon line. The nylon fishing line is practically invisible to anyone who doesn't know it's there, but you do and that's all that matter.
    #10
