Securing a trials bike in a trailer while travelling
Discussion in 'Trials' started by Growzer, Jul 1, 2018.
  1. Growzer
    Growzer Adventurer
    May 27, 2017
    11
    Albury, Australia
    56D512D5-47AB-4A4D-9E09-4CD38AB83F8B.jpeg 5CDDDF63-B49D-4D87-B217-052EF64C201A.jpeg 5186FF6E-88A3-45A0-9ADA-50BA3718DAF6.jpeg
    Found a great product that helps secure a trials bike.
    Tried a few different ways, tie downs from the handlebars- front shockies but the Tyrefix Ace Bikes system works a treat as it slides under the front mudguard, simple and easy. Latch seat belt system that connects to the buckle is smart. Fit one on the rear wheel as well and it doesn’t move.
    https://www.acebikes.com/en/transport-service/tyrefix-tie-down-system
    DyrWolf, Ditch, Kiharaikido and 3 others like this.
  2. UstaKood
    UstaKood Been here awhile
    Feb 5, 2016
    144
    Michigan
    Nice setup . I've always tried to attach to the lower triple clamp , worried about shock load to the bars .
  3. lineaway
    lineaway Long timer
    Oct 1, 2011
    8,416
    nm
    That is way too complicated for my lifestyle. I would just stay home and :photog.
    sieg, 2whlrcr and Norman Foley like this.
  4. PSchrauber
    PSchrauber Long timer
    Jan 3, 2011
    1,234
    Summer: Kemiö, Finland; Winter: North Germany
    And it doesn't help if you have to accidently brake as much as you can the rear of the bike should be secured too.
    sieg likes this.
  5. jonnyc21
    jonnyc21 Trials Ninja
    Feb 8, 2011
    3,070
    Boise aria
    He did indicate attaching one to the rear...
    I think it's a great alternative to a standard tie down setup. Though it dose look a bit more cumbersome to get in place under a trials bike fender.
    I myself have been considering making a wheel axel to triple clamp chalk to help limit the amount of fork compression. We will see how well it works.
    Kiharaikido likes this.
  6. UstaKood
    Feb 5, 2016
    144
    Michigan
    405F7800-61C1-4BAE-89C7-9C21ECDD34DC.jpeg Well ...
    You made me dig it up .
    I just rode 1 section then as I stopped and went to get off ...
    Had the clutch lever and grip in my hand !
    Thank you .Jesus ...
    Thank you Lord !
    After that I I changed my habits.
    Yes I know OE steel. Bars .
    It also does away with with pressure build up on the seals
    But ...
    To each their own
    BTW ...
    I always have time for a frosty .
    Or two ...
    DyrWolf and Brewtus like this.
  7. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    12,025
    Dubuque, Iowa
    ouch!
  8. dmay
    dmay Been here awhile
    Jul 10, 2007
    294
    Bloomfield,Indiana
    J-Hooks through footpegs,takes 10 seconds to hook both,then strap front brake.
    (Motocinch on the RL because I needed to dig out longer J-Bolts for the vintage peg height.
    #8
    anoldsman, dpforth and laser17 like this.
  9. Growzer
    Growzer Adventurer
    May 27, 2017
    11
    Albury, Australia
    I like the idea, well done.
    #9
    soupbill likes this.
  10. broncobowsher
    broncobowsher Long timer
    Apr 21, 2010
    3,705
    Baking in AZ
    Strap the front brake?
    #10
  11. dmay
    Jul 10, 2007
    294
    Bloomfield,Indiana
    I put a cinch strap around the front brake lever to hold it on enough to keep the bike from swaying forward and back..
    #11
