Servos Suck
Discussion in 'GS Boxers' started by SCQTT, Sep 24, 2008.
  1. tagesk
    tagesk Tuscan rider
    Jun 23, 2007
    3,230
    Tuscany, Italy
    Did you see this one?
    But we digress!
    [TaSK]
    #61
  2. JimVonBaden
    Feb 11, 2005
    90,968
    Alexandria, VA
    AND you are a tease!:bluduh
    :D
    Some day my friend, some day!:deal
    Jim :brow
    #62
  3. cooney
    cooney Adventurer
    Feb 17, 2008
    33
    My servo quit working last week. Got caught in rush hour traffic with "residual" brakes. Really pissed me off and unsafe. Had 2 beemers before this one and loved them. I can't really explain how this made me feel. It wouldn't be nice i can tell you.
    So the dealer tells me 2000 plus dollars just for the unit. Can't afford that to tell the truth. So i'm stuck with a very nice bike that doesn't stop. Read all the info i could find on the net. I guess i'll have to convert it and lose my abs. Not that big a deal losing the abs but it is a nice feature that i would like to have.
    Anyone with helpful tips? I'm all ears.
    #63
  4. tagesk
    tagesk Tuscan rider
    Jun 23, 2007
    3,230
    Tuscany, Italy
    Unless you can find a used unit for less, there doesn't seem to be any alternatives for you but to go "naked".
    I feel your pain.
    [TaSK]
    #64
  5. cooney
    cooney Adventurer
    Feb 17, 2008
    33
    Yea i think you're right. Our electrician at the plant where i work wants to try and fix it. Might let him try then go as you say "naked". Thanks
    #65
  6. biggziff
    biggziff Funk Soul Bruvah
    Aug 2, 2008
    11,082
    Upstate NY
  7. AirForceDirt
    AirForceDirt "Give me back my face!!"
    Feb 3, 2008
    522
    The Desert
    Its only hot if you stop moving...so the key is to keep moving...the faster the better.
    #67
  8. ShaftEd
    ShaftEd Long timer
    Nov 6, 2001
    4,007
    San Diego, CA USA
    You can try Beemerboneyard too. They sometimes have used abs control units.
    http://www.beemerboneyard.com/
    #68
  9. Steptoe
    Steptoe steptoe
    Feb 21, 2004
    3,401
    london, England
    I'm doing just such a job today - An R1150R, 16k miles, servo unit failure.
    Electric servos, what a crap idea. If it's electric, it'll fail at some point. Why depend on a fuse for your brakes. :D
    #69
  10. diabolik37
    diabolik37 Deadly Gubba
    Jan 15, 2008
    2,937
    Down Under QLD
    Are we taking bets?:D
    Just wondering...can you buy a 2008 1200GS with servos?
    #70
  11. Nesbocaj
    Nesbocaj The NEW Soylent Green Deal???
    Jul 15, 2006
    1,647
    Westchester NY
    If you get a chance snap a couple of pics please! Are you going to a
    larger master cylinder?
    #71
  12. Steptoe
    Steptoe steptoe
    Feb 21, 2004
    3,401
    london, England
    Same master cylinder - no difference between servo and non-servo master cylinders.
    Why the need for pictures ? I'll take a couple tomorrow, but the servo unit is held in place by the elecric plug 3 bolts and 4 screws and the brake pipes. Undo and remove !!!!!!!!
    #72
  13. cooney
    cooney Adventurer
    Feb 17, 2008
    33
    What about brake controls. I understood that they were tied into the abs unit or something. I hope i'm wrong and it is normal switches at the bars and footpeg.
    #73
  14. JimVonBaden
    Feb 11, 2005
    90,968
    Alexandria, VA
    You are not totally wrong. Some rewiring needs to be done to make the brake lights work without an issue with the warning light.
    Jim :brow
    #74
  15. Steptoe
    Steptoe steptoe
    Feb 21, 2004
    3,401
    london, England
    Removing the servo/ABS unit - Three bolts secure the servo/abs unit. Remove them, unplug the electric connectors, lift the covers on the brake lines, and pull the retaining clips out .
    Once the clips are removed, just pull the brake lines out.
    Then pull out the servo unit.
    The rear brake line from the caliper can bolted direct to the master cylinder
    The front brake line needs the junction joint replaced with a non servo connector. it's a straight replacement. The brake lines don't need to be changed
    Servo junction unit ( took the picture after removing it :cry )
    The non servo unit, about to be bolted the frame in the same place as the servo unit.
    Still doing the brake lights and rear light wiring.
    The rear light needs a link inserted to fuse two ( remember to connect it down stream of the fuse) .
    And the brake light switches need to be changed to non servo switches ( servo switches are live when closed, non servo are live when open), you then need to splice the brake light wiring to a live and into the brake circuit ( finishing this tomorrow)
    #75
  16. cooney
    cooney Adventurer
    Feb 17, 2008
    33
    Steptoe you rock. PLEASE get us straight on the wiring and i think i can do that job. Ordered the non-abs junction for the front brakes today. I need the switches now. You wouldn't have part #s for those would you? Thanks so much for the pictures!:clap
    #76
  17. R1150gsadvrider
    R1150gsadvrider Been here awhile
    Apr 1, 2006
    211
    +1 :clap
    #77
  18. R1150gsadvrider
    Apr 1, 2006
    211
    The human mind and reflexes cannot out react ABS! A locked brake skid is a out-of-control vehicle. ABS allows for a slight rotation (impending skid) which offers maximum deceleration while offering some steerage and control. The exception is operation off hwy and in the dirt.:deal
    #78
  19. Anorak
    Anorak Woolf Barnato Supporter
    Jul 23, 2004
    54,529
    San Rafael, Marin County
    It's not the ABS that people don't like, it's the servo assist and the possibility of an astronomical repair bill if/when it quits working out of warranty.
    #79
  20. Mav
    Mav Something witty...
    Sep 17, 2006
    3,813
    Blighty
    Not wishing to throw petrol on the flames.... but I've discovered a new issue with Servos: My bike sometimes stalls on change downs, not normally a big deal - just coast for a second while the ECU sorts itself and restart before you even stop. However, the servos lose power at the same time! And when are you normally changing down? When you are trying to stop! No doubt you can still stop using residual brakes - but when you are already trying to coast without power, watching the traffic, and hitting the starter - trying to recalibrate how hard to the pull the brake lever (with the same hand that is trying to restart the bike!) is a task too many :cry
    I agree with the position that ABS is good and that riding with Servos is fine, even off-road. When mine die, I imagine that I will sacrifice ABS for the saving and the confidence of the brakes not failing.
    #80
