Setup your rugged Android for all things GPS ?
Discussion in 'Mapping & Navigation' started by ohgood, Oct 6, 2015.
  1. ohgood
    Sep 21, 2010
    9,284
    alabama
    copy that file into all the directories you want the gallery to skip indexing
  2. Cyclepath
    Cyclepath Lost wanderer
    Mar 17, 2006
    1,998
    SW. Wa. state
    Thanks again ohgood , in the past there has been "nomedia" entries already loaded in locus. This is the new latest version. Is that still a bug or did yours load ok. I have no idea what directories to add to, there are a lot of icons.
  3. ohgood
    Sep 21, 2010
    9,284
    alabama
    youre always welcome, sir !
    i dont remember when i learned about that. ill give yyou a full list of directories i have it in soon as i remember my linux bash search syntaxes, and can produce it! :-)
  4. Cyclepath
    Mar 17, 2006
    1,998
    SW. Wa. state
    Hahaha. I had a couple go arounds with Linux....didn't go to good....:baldy
    Is there any reason for those nomedia entries to not be there ? And is there a way to reload the new version?
    Thanks again ohgood :-)
  5. dflow
    dflow Been here awhile
    May 28, 2007
    806
    SW of STL
    FWIW as a follow-up to my earlier posting regarding unwanted screen rotation with OsmAnd+:
    I've installed the "Rotation Control" app and found that in addition to selecting the desired screen orientation the "guard" setting must also be selected in order for it to work with OsmAnd+.
    [​IMG][​IMG][​IMG]
    A test ride is still required to prove it's usefulness/effectiveness but so far it seems to work in hand.
    ohgood likes this.
  6. ohgood
    Sep 21, 2010
    9,284
    alabama
    i dunno. maybe it was removed so that the locus app could scan/find pictures for geotagging on the map. no idea really
  7. Cyclepath
    Mar 17, 2006
    1,998
    SW. Wa. state
    My other two phones with locus pro on them did not do this. I was looking for a way to re-load locus but all I come with is no matter where I try to down load from it says "installed" or "open" And I have no idea where to install "nomedia". I know I have seen this somewhere on my other two phones but now I can't find on those two phones. Thought maybe I'd get an idea where to find them.
  8. Cyclepath
    Mar 17, 2006
    1,998
    SW. Wa. state
    Ok, bear with me a minute. :-) My 4 year old Asus "gsm unlocked" running on cricket, has been doing some weird things lately so I bought a refurbished Kyocera E6820 . When I install my sim card into the Kyocera everything works except I can not turn on the hot spot. I get a message from AT&T that says log into my at&t account and upgrade to plan that includes hotspot. I DO NOT have an at&t account. I have a cricket account and I have always been able to use the hot spot. This Kyocera was an at&t phone as when I turn it on I get the round white and blue at&t globe logo. So why is this happening and can it be changed some how. I checked the apn settings on the Asus and then with the sim in the Kyocera. They are the same. ??? Anybody have any ideas ??
  9. Hootowl
    Hootowl Long timer
    Jul 2, 2002
    1,529
    Bend Oregon
    Cricket uses the AT&T network.
  10. Tripped1
    Tripped1 Smoove, Smoove like velvet.
    Aug 6, 2009
    28,210
    Nippon
    ...and AT&T blocks device tethering from their domain unless you pay them.
    One way around it is an app called PDa net. it used to be $16 and I have used that successfully with AT&T devices, but you need to have it on both devices.
  11. ohgood
    Sep 21, 2010
    9,284
    alabama
    hmm, they must have changed something for their contact customers. non contact customers (me) can tether 10 devices at once, with Android 5.x
  12. Cyclepath
    Mar 17, 2006
    1,998
    SW. Wa. state
    The Kyocera also allows 10 devices but when I try to turn on the Hot spot I get that message. So like Tripped1 said they must block there phones from tethering somehow. Funny thing is I don't have an at&t contract it's with cricket and I know cricket uses at&t, so this must be done with the phone. The phone has an at&t logo on the back side. 3 or 4 years ago when I bought the Asus on line I went to a cricket store and signed up and stuck the sim card in the phone and all was well.
    ohgood likes this.
  13. Cyclepath
    Mar 17, 2006
    1,998
    SW. Wa. state
    I will look up that PDa app. Please tell me what you mean by both devices? What if I only had the Kyocera as a cell phone. If I get it to work with the Kyocera can I switch back and forth as that is what I had in mind. What if it was a gsm phone from another carrier ?
  14. Tripped1
    Aug 6, 2009
    28,210
    Nippon
    You need the app on both devices
    PDa net's direct Wifi app is called FoxFI, and AT&T won't let you use it, so you have to use a secured WiFI pairing
    Annoying but it will get you around the AT&Ts ban
  15. Tripped1
    Aug 6, 2009
    28,210
    Nippon
    On AT&T?
    I run into that every time I go to the States they have tether disabled ....and by disabled I man removed from settings, AND the play store won't let you download legacy apps like FoxFi but you can pay them whatever per month use their crappy apps.
    Turns out that most of my devices ended up being AT&T
    So my options are root and find a stock Android (which is no picnic if you have ever played with the AT&T bootloaders) or go around them.
  16. ohgood
    Sep 21, 2010
    9,284
    alabama
    yes att branded
  17. Sonny S.
    Sonny S. Long timer
    Nov 23, 2015
    1,226
    Maryland
    I'm using a Galaxy S5. I have not used it in the rain yet. I'm 99% sure I can trust it but what about charging it while in the rain? I was thinking a dry bag / case over it with an Anker charger tucked inside.
    Am I overthing it? Right now I use the Deltran SAE to USB chargers.
    I did call Deltran and the said the charger is " weather resistant" and should be fine getting wet, not submerged.
  18. ohgood
    Sep 21, 2010
    9,284
    alabama
    take extra batteries and change them as needed. charge them over night.
  19. Sonny S.
    Sonny S. Long timer
    Nov 23, 2015
    1,226
    Maryland
    Yeah that's a plus for the S5. I've got a few. Locus eats em up with my normal settings. Full brightness, display always on. I figure I can set the display to only come on before a turn etc. to help battery life. Rode all over and coast to coast by map and no cell phone. Now my dilemma is charging my GPS in the rain..lol
