1. ADVRIDER Print Magazine!
    We're doing two more print magazines this year. July & November. 144 pages of high quality adventure riding stories, photography and interviews!
    Click here to purchase both for $35.
    Dismiss Notice
Shade tree ideas...
Discussion in 'The Garage' started by dtysdalx2, May 5, 2021.
  1. dtysdalx2
    dtysdalx2 Just send it!
    Aug 1, 2004
    28,657
    Moneyapolis, MN
    Okie dokie. I'm in a pickle at work. Our European pump has a plastic cooling fan.
    It dune broke. 6" diameter and 1" bore on end of shaft.
    I need to cool this motor with something. Junk yard doesn't have what I need.
    Any ideas what I could use? :hmmmmm
  2. VX Rider
    VX Rider Long timer
    Dec 11, 2015
    7,473
    Phoenix
    cut and bend up some fins out of light / thin aluminum sheet... and screw it onto that disc
  3. Kyron
    Kyron Oncler Inds
    Jun 11, 2007
    1,292
    Phoenix Arizona ATR > Pacifica Ca PMA
    I’ve used these to keep panels and other equipment cool 8E5CF3E3-0D5A-4F92-A50C-9FE734A105BC.jpeg
    ydarg and dtysdalx2 like this.
  4. dtysdalx2
    Aug 1, 2004
    28,657
    Moneyapolis, MN
    Yep, I found a small fan like that. 115V. Put it up beside the motor with an extension cord. :D
    Pump is this. Minus top shroud and fan.
  5. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    10,610
    Anchorage, formerly Spenard (hub of the universe)
    what part of it broke? there are fixes
  6. Salsa
    Salsa Long timer
    Dec 12, 2006
    1,458
    Arizona, Alaska
    How fast does it turn?
  7. Beezer
    Oct 26, 2004
    10,610
    need more info
  8. foxtrapper
    foxtrapper Long timer
    Sep 6, 2011
    5,160
    should be able to fit a pancake fan onto the rear of that motor, in place of that rear plate.
    #8
  9. dtysdalx2
    Aug 1, 2004
    28,657
    Moneyapolis, MN
    Take off top shroud. Muffin fan on top of cover would have worked too. I'm at home now.
    Just need to get a new pump. Man I hate jerry rigging stuff for a multi million dollar company. :fpalm
    #9
    local1 likes this.
  10. dtysdalx2
    Aug 1, 2004
    28,657
    Moneyapolis, MN
    Usually the hub around the motor shaft cracks in multiple spots. 3250 rpm.
    #10
  11. Arbolmano
    Arbolmano Not so Studly
    Feb 1, 2014
    602
    Commiefornia! 93420
    Yikes. I can think of a few work arounds but........what’s cost of fail vs doing it correctly? Why did it fail?
    #11
  12. katbeanz
    katbeanz earthbound misfit, I Supporter
    Feb 12, 2005
    11,017
    Kansas City
    Before retiring had saved some impellers for some reason, they were plastic, split hub with a pinch bolt. That close to shaft centerline not sure how much a hose clamp would throw it out of balance. :hmmmmm Don't beat yourself up, 50 techs on seniority list 10yrs ago, there's 5 left. :lol3 :dunno
    #12
  13. dtysdalx2
    Aug 1, 2004
    28,657
    Moneyapolis, MN
    Our new supervisor let the PM's fall to sh*t when he took over. We usually remove the fan covers and clean them. When they get plugged up the plastic gets brittle and takes the motors out.
    One thing I don't like about production places. Need to get product out the door, doesn't matter what the maintenance guys think. Production first, maintenance :dunno
    At least I got raises the last time I threatened to quit. :D
    Those Stubbe pumps are about $2000 and from ze germans.
    #13
    caycek5 and katbeanz like this.
  14. Beezer
    Oct 26, 2004
    10,610
    looks quite a bit like an alternator fan. the bore would be the problem. or bore vs diameter. if you have an auto-electric rebuilder they might have some examples laying around. a clever guy could prolly make one fit. in the meanwhile... order about 5 of those pumps for spares & see what the boss says ha ha
    #14
    local1 and dtysdalx2 like this.
  15. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    13,228
    Omicron Persei 8
    #15
  16. Laconic
    Laconic .
    Sep 28, 2007
    29,281
    NCNC
    We had those plastic fans disintegrate on motors where I used to work. We ordered direct fit cast aluminum replacements. Damned if I can remember where from, but they're out there.
    #16
    katbeanz likes this.
  17. Yamarocket630
    Yamarocket630 Honey Badger
    Sep 15, 2011
    3,289
    Workin in the Chute Lube factory
    Ignore it till the motor fails. Order new pump. Problem solved.
    #17
    Beezer, local1 and dtysdalx2 like this.
  18. dtysdalx2
    Aug 1, 2004
    28,657
    Moneyapolis, MN
    Already did that. :lol3
    First shift jerry rigged some sort of fan for the motor.
    Except for the order new pump part. :bluduh
    #18
  19. scottbc
    scottbc advanced lurker
    Feb 14, 2007
    76
    Abbotsford,BC
    Whatever motor rewind shop you use should have something. Metric motors are everywhere now. They probably have a scrap bin full of burnt out motors to pick from. Maybe swipe one off a spare in your stores?
    As stated above a 120V muffin fan tie wrapped to the end bell for the meantime.
    #19
    dtysdalx2 likes this.
  20. anonny
    anonny What could go wrong?
    Mar 20, 2007
    6,959
    Beautiful Revelstoke BC
    3D print a new one
    #20
