Shinko Failure
Discussion in 'Equipment' started by AluminumMike, Dec 19, 2011.
  1. Jud
    Jud Long timer
    Dec 22, 2007
    3,930
    Arkansas Ozarks
    You know,,,, that might just explain thing. :shog:D
  2. Harvey Krumpet
    Harvey Krumpet Long timer Supporter
    Dec 26, 2011
    1,972
    The Shaky Isles
    Well, all good after best part of 1000 k's two up & loaded. Very hot on the trip too, had to keep stopping to wring my sodden under cracks out. The new shinko has only just rubbed off it's little spiky bits & performed faultlessly even in a sudden down pour on traction free city roads.
  3. Gildus
    Gildus Been here awhile
    Feb 5, 2012
    852
    Oregon Territory
    My BRP does love to shred tires but I don't see it happening any faster with the Shinko 244s than with the TK80s. I can shrug off replacing a Shinko but when buying a series of TK80s I simultaneously reach for my Xanax and the speed dial for the florist. :lol3
  4. DualSportDad
    DualSportDad Long timer
    May 11, 2007
    2,637
    Cape Coral, Fl.
    i took a long ride on the interstate today and my shinko 700 is starting to have the center lugs seperate one is missing a chunk.
    i know it's hard to see but the center lug between my sosn's fingers is seperating the worst and it has a chunk missing.
  5. WARRIORPRINCEJJ
    WARRIORPRINCEJJ Forsaken
    Jun 29, 2009
    28,604
    Leanna Decker's panties
    Just outta' curiosity (because I'm runnin' the same rear tire)...
    Average speed?
    Tire pressure you were runnin'?
  6. DualSportDad
    May 11, 2007
    2,637
    Cape Coral, Fl.
    i was running speeds between 70-85 mph, 30 psi. i ran 70 miles round trip and then noticed the tearing and chunking. i also had no extra weight on the bike, just me (165 lbs). i'm going to continue riding on it for now but i will be contacting shinko soon.
  7. Benjava
    Benjava ?
    Jul 22, 2006
    1,920
    Location Location
    I wouldn't expect any tire to withstand 70-85 mph with less than 36 psi. for long
  8. NordieBoy
    NordieBoy Armature speller
    Dec 2, 2006
    7,234
    Kiwiland
    I wouldn't expect my bike to withstand those speeds for long either :evil
  9. hansi
    hansi Teurer Abenteurer Supporter
    Jan 1, 2010
    1,037
    State of Jefferson
    :huh 30psi at those speeds on blacktop will cause the rubber to get rather hot and super soft. I don't care if it's a Shinko, Metzler or Pirelli, that is just asking for tire failure.
  10. Benjava
    Benjava ?
    Jul 22, 2006
    1,920
    Location Location
    hey my bike resembles that remark :D
  11. wibby
    wibby BrotherFromAnotherMother
    Mar 20, 2005
    10,943
    Grass Pants Orygun
    glad you made it home ALIVE! :lol3
  12. Jud
    Jud Long timer
    Dec 22, 2007
    3,930
    Arkansas Ozarks
    Be sure to take in account the total weight that's on the tire. A 350lb DRZ with a 170lb rider doesn't need near the same pressures as a fully loaded, two up DL1K that weighs around 850lbs. I run alot of Shinkos on several different bikes and I would consider that 30psi plenty for a DRZ weight bike at those speeds IMO.
  13. WARRIORPRINCEJJ
    Jun 29, 2009
    28,604
    DSD, thanks for the post.
    When I ride in the Texas Hill Country, I usually have to do about 50-70 miles of slabbing, just to get there. I find myself running between 70 and 80 MPH, very much like you. And, like you, I am running 30 lbs. in my rear tire.
    When I read your intial post, I went and took a good look at my rear 700. All looks well. However, I only have about 500 miles on it. We'll see how it goes...
    Your posts made me think of something, that I have read on ADV, many times...
    For the most part, every tire I have ever owned has had a sidewall marking that reads something like, "Max load-___pounds @ ___PSI cold".
    I have always "tried" to keep my tire inflation below 90% of the above PSI number (to allow for expansion, from heat). So, for instance, my rear Shinko 700 reads, "Max load 677 pounds @ 33 PSI cold". Because of that, I would try not to inflate that tire to more than 30 lbs., cold (about 90%).
    Yet, throughout the years, on ADV, I have heard many folks inflating similar tires to 36, 38, 40, and even 42 lbs.
    Y'all wouldn't be concerned about putting 36 lbs. of pressure (or 38 or 40) in a tire that reaches it's max load rating at 33 lbs.? At what point is there a concern of rupture?
    I'm not judging, or being critical...just curious.
  14. DualSportDad
    May 11, 2007
    2,637
    Cape Coral, Fl.
    I should come back here and Post.... keep in mi d my bike is the e model so its 250 lbs dry. I am also running the tubeless tire with a tube..... if that matters.
    Last weekend I did the same ride again but farther and havent checked my tire pressure since before I made this post. I rode about 40-50 miles at 70-75 mph and then a buddy of mine had a bad crash while we were in the woods so I had to go get my jeep and trailer and rode about 70 miles home through gravel, rocks and mostly highway at 75-90 mph. The tire doesn't look like it got any worse. I was keeping a good eye on it throughout the day. I still havent contacted shinko.
    Sent from my Motorola Photon using Tapatalk
  15. Jud
    Jud Long timer
    Dec 22, 2007
    3,930
    Arkansas Ozarks
    Hey, sometimes ya fell like a nut,,, sometimes ya don't. I'm one of the people that look at that "______ max load at ____ max psi" as a guide line. When I'm playing, off road or on, I generally run less pressure than the max listed on the sidewall as that usually gives better traction. But, at accelerated wear due to carcass flex and greater friction and yes, it can, possibly result in a very pissed off tire and I have had that happen, several times when heat caused chunking. That experience was just with the Shinko brand either. I've chunked Michelins, Kendas and Metzelers too.
    On the other hand, I have wanted better tire life and I have run either the max pressure shown or the tire, or over time, I gradually raised it even higher a little at a time just experimenting and have discovered that even though I'm well over the manufacturer's recommendations, the sky didn't fall,,,,, the atmosphere didn't catch fire and no nuns nor kittens died. And in return for experimenting with those higher pressures {many would say more like gambling} I saw less traction but better tire life. Sometimes much better.:1drink
    For example, I regularly run well over 45 psi in the rear tires of my DL or my FJR when on trips trying to get better tire life. I have run as high as 50 or so and yes,,,, I lived to tell the tale.:eek1:rofl
    Seriously though,,,,, I always colored outside the lines, always took advice with a grain of salt and I usually didn't believe something unless I had first hand experience with it. Some people "leave it to the experts" and simply will not meander from the beaten path due to "safety}. Others look at the path as just a easy, idiot proofing means of getting somewhere intended for those that live in black and white in a Technicolor world and that's exactly why some choose to ride rather than drive. There are alot of roads that led to Rome, some are prettier than others, some are faster than others,,,,, many choices might not lead you down the right path. You have to figure out your route on your own based on your experiences, skills and ability to accept the unknown.:deal
    Thanks for not passing judgment on those that choose experimentation rather than blind adherence to the "experts".:wink:
  16. Harvey Krumpet
    Dec 26, 2011
    1,972
    The Shaky Isles
    I've been getting some advanced instruction of late & one of the things that has come up is tire size & pressures. Now, I have never been certain of how to gauge the correct pressure for different loading's.
    The guy who has been teaching me has a wealth of experience & does huge mileages in all conditions, his rule of thumb is if when hot the tire pressure has increased by 4 psi or more it is to soft, conversely if it does not increase by more than 2 psi it is to hard. I'm not stating this as cast iron fact but it gives a reasonable gauge & food for thought, bearing in mind the mileage this guy does, his pace & the fact he really does not like wasting money.
  17. Cabrito
    Cabrito On the mend 76% Supporter
    Jul 25, 2007
    470
    415
    Well...
    Went to ride to work this morning and spotted one of the lugs coming apart.
    Tire is a Shinko E-705 Bias Ply manufacture date 24th week of 2011 (not radial) with 4100 miles on it. Tire was just about toast before I left on my last ride which was 516 miles last weekend with a mix of 65mph slab, goaty roads and dirt roads, and a few hundred miles on two lane highway 45-60mph. Running 36psi on the slab and 28psi off-pavement.
    I decided not to ride to work on this tire. I think I'll go ahead and change it out with the new 705 I got last week. However.. I think these will be the last Shinko 705's that I run.
  18. NordieBoy
    Dec 2, 2006
    7,234
    Kiwiland
    What bike?
    Is the new 705 a radial?
  19. Cabrito
    Jul 25, 2007
    470
    415
    Not a radial - KLR650
  20. NordieBoy
    Dec 2, 2006
    7,234
    Kiwiland
    Wonder if over inflation could cause as many problems as under inflation?
    It would focus the heat in a smaller area?
    In Jan (middle of summer) I did a 2,300km, dirty long weekend and the rear was 8,000 km old when I started. 24psi on seal, 18psi off.
    The DR clicked over 100,000km on the trip and about 30,000km of that has been on 705's.
    Conditions varied from hot temps and seal to below freezing in a snow storm and scree slopes, rocky climbs and descents and lots of coarse gravel.
    We don't get the extremes of ambient temps here though.
    Actually, I'm not sure I've heard of anyone over here having a delaminating issue.
    Yet.
    A Fullbore clone will be my next rear on the DR as they're cheaper and I want to see how they go distance and grip wise compared to the 705's.
