Shock difference between SE-R & SM-R?
Discussion in 'Crazy-Awesome almost Dakar racers (950/990cc)' started by Kiwiktm, Jun 25, 2018.
  1. Kiwiktm
    Kiwiktm Adventurer
    Jan 16, 2017
    22
    Just picked up a nice used SM-R 950 rear shock . Mostly for the 130-215 spring to try in my SE.
    Besides the spring rate, what are the differences between the two shock absorbers on these models ?
    Thanks in advance!
  2. mousitsas
    mousitsas Long timer
    Oct 10, 2008
    3,972
    Athens, Greece
    The sm shock is basically a shorter version of the se shock by about 15-20mm.
    The tail height falls down by about 60mm on my se with the sm shock fitted.
    Maybe the smr shock is slightly longer than the sm though and slightly more stiff in the valving.
  3. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,084
    Windsor, United Kingdom
    Valving is softer / faster on the SM Shock compared to the SE. And as Mousitsas stated, its internal spacer makes it shorter than the SE. Same Spring length as you know...
