Should I fear fallen leaves on the Blue Ridge Parkway?
Discussion in 'Southeast, The Lair of the Dragon - The Blue Ridge' started by nathan8752, Oct 3, 2021.
  1. nathan8752
    nathan8752 n00b
    Oct 3, 2021
    1
    Illinois
    Adventurers,
    I plan to be riding the Blue Ridge Parkway October 11-14, so I'm leaving in just a few days from northern Illinois. I'm concerned about leaves and/or wet leaves on the road wrecking my trip by causing me to wreck my bike. Does anyone out there have a good guess as to whether I should expect to have that problem on those dates?
    Thanks.
  2. Bar None
    Bar None Long timer Supporter
    Mar 2, 2007
    15,747
    SWFL WNC
    There will be leaves and maybe they will be wet. You have the same conditions on the roads in Illinois. Adjust your speed to the conditions.
  3. R65_Steve
    R65_Steve Been here awhile
    Sep 1, 2019
    457
    Northern VA
    I wouldn't sweat it at all. Enough traffic through there that any leaves would blow off with a camper rolling by
  4. WonEvil
    WonEvil n00b
    Jul 21, 2016
    2
    I’ve ridden the parkway for years and never found it to be an issue. Ride on!
    greasyfatman likes this.
  5. knybanjo
    knybanjo kinda slow
    May 8, 2006
    38,724
    out in the clover patch
    Watch out for the grass clippings!!
  6. heatmizr
    heatmizr n00b-tastic
    Jan 5, 2012
    1,076
    CLT, NC
    Dry leaves have never caused me a problem, and most likely blow off the road up there since it's usually dry and windy.
    What I will warn you about is a massive number of leaf lookers in cars, trucks, and RVs littering the parkway. And everyone on the parkway will be clumped up behind a vehicle doing 29mph. Make sure you alot enough time for a very low average speed over your distance.
    That said, if you've never been, it really is a national treasure. I was up there last weekend and will be out there another couple weeks from now. Stop at some overlooks (there are tons, so if you miss one just keep going to the next one), and read ahead of time on the attractions and pick a couple, you probably can't stop at all of them.
  7. mica
    mica Weekend Adventurer
    Aug 26, 2008
    4,214
    Berryville-ish, VA
    The leef peepers will likely be a bigger concern.
    SCPancho, bwringer, RedEX and 3 others like this.
  8. 4PawsHacienda
    4PawsHacienda Inadvertent unrepentant wanderer
    Oct 20, 2008
    1,609
    SE Guilf Co NC or Fancy Gap VA BRP MM199
    All quiet on the BRP right now. Be prepared for moist conditions.
    #8
  9. TheBear
    TheBear Been here awhile
    Apr 24, 2013
    102
    Sydney Australia
    I once saw someone in front of me on an RD350 go straight off the edge on a corner under full brakes. That was on Brown Mountain in southern New South Wales, a road notorious for wet leaf litter. So never discount it.
    #9
    Bar None likes this.
  10. jdrocks
    jdrocks Gravel Runner
    Jul 6, 2007
    9,119
    and don't forget all the deer and bears, plus cagers slamming on the brakes to get the photos.
    #10
    SCPancho and spokester like this.
  11. MayorOfBBQ
    MayorOfBBQ Come at me bro
    May 7, 2014
    1,158
    ASHEVILLE
    if they are wet they can be pretty slippy. If they are dry, all the traffic keeps them blown clear.
    The parkway will be PACKED on the weekend for sure, but Mon-Thurs is a good run, ya did good there picking those dates.
    My favorite stretches are from Mt.Pisgah/Pisgah Inn south to Maggie Valley and from Mt.Mitchell State park north to the Viaduct. There will be a LOT of traffic around Asheville (Mt.Pisgah to Mt. Mitchell) and around Blowing Rock/Boone. Most of the leaves will be down/gone at the highest elevations by 10/10 but you still have fantastic views of the lower areas from up there. North of the VA boarder its mostly rolling farm land road, the NC portions are the best.
    BRING RAIN GEAR, it supposed to dry up after this week, but spotty rain and for sure MORNING FOG & MIST are a given on the BRP
    #11
  12. chainslap
    chainslap BlessedarethesicK Super Supporter
    Apr 23, 2009
    5,281
    The Dirty South
    Yes. Very dangerous. Probably best to stay in Illinois. Actually much safer if you just quit riding motorcycles altogether.
    #12
  13. treebumper
    treebumper Macro Trav
    Feb 17, 2008
    13
    NC Piedmont/Blue Ridge
    His mistake was hitting the brakes so hard. I live in the Carolinas, and have never had an issue with leaves or cut grass, wet or dry. I's almost like driving on ice or snow, when the debris is present, no hard sudden turns & slow down slowly as you can.
    #13
  14. heatmizr
    Jan 5, 2012
    1,076
    CLT, NC
    I must admit a riding buddy of mine when I was a bit younger did have a small low side from leaves going up a twisty mountain road here in NC. However, he was absolutely hauling ass in first and second gear on a sport bike, and was leaving no room for error.
    And honestly I don't know if the leaves caused it or if he just ended up in them.
    #14
  15. 4PawsHacienda
    Oct 20, 2008
    1,609
    Actually the weather here is gorgeous right now and riding conditions perfect. A bit early for leaf peepers, I recommend the BRP as a great road thru the middle of some fantastic riding areas. Get off the Parkway and explore some, leave the peepers on the slow road.
    #15
    ZanderMan likes this.
  16. peejman
    peejman i wanna ride
    Oct 25, 2012
    880
    East TN
    Beware wet leaves and wet tunnels.
    #16
  17. jkbeaudin
    jkbeaudin Adventurer
    Sep 22, 2012
    19
    Buckeye, AZ
    My major caution for anyone riding the Blue Ridge: be careful in the blind corners because there, you will find leaves, gravel and vehicles crossing the center line into your lane! 2nd, it will take you longer than you planned to go the distance, be patient and enjoy the slow moving ride.
    #17
    Baloo likes this.
  18. Baloo
    Baloo Itinerant jackass Supporter
    Jan 12, 2006
    8,423
    I cover the waterfront in Norfolk Virginia.
    The bane of Scotty P’s existence.
    In my experience, I have never found such an amassed amount of wet leaves on the road to be of concern. But I do take caution with any clippings or things of that nature. No crazy breaking or turns when those are present.
    #18
    knybanjo likes this.
  19. spagthorpe
    spagthorpe Long timer
    Aug 9, 2002
    20,479
    San Diego
    This is a big one. With everyone moving at a snails pace, it's easy to ride up on people, and people will slam on brakes because OMG a real deer eating on the side of the road.
    They should go out on the BRP at night, because there are thousands of them all over the place.
    #19
    RedEX and Boatman like this.
  20. jdrocks
    Jul 6, 2007
    9,119
    in all the parks, there's more wildlife along the shoulders because people are feeding them through the windows. i can recall many instances where i was coming around a blind curve or over the top of a hill only to find a car, truck, motorhome stopped dead in my travel lane, people throwing apples to the deer or elk. same thing for photos, don't pull off on the shoulder, might scare the poor animal away, miss that all important facebook moment...it never once occurs to these nuts that they might kill someone by parking in the road.
    also, i nearly hit a car that did a tire smoking dead stop in the middle of the road to get a photo of a bright red/orange maple tree.
    #20
    RedEX and ArielNut like this.
