Show us your sidecar suspensions!
Discussion in 'Hacks' started by rantingsmith, Mar 18, 2017.
If you bought an existing sidecar, have you upgraded, or thought about upgrading its suspension
  1. No, it performed well enough.
    18 vote(s)
    30.0%
  2. Yes, but not sure how to.
    10 vote(s)
    16.7%
  3. Yes and I have.
    27 vote(s)
    45.0%
  4. No, but I woud if I could get a bolt on upgrade.
    5 vote(s)
    8.3%
  1. rantingsmith
    rantingsmith Quadrilingual blacksmith seat of pants engineer
    Feb 27, 2017
    408
    UK for now but not from here
    As the title says, please post pictures of your sidecar chair suspensions.
    The sidecar design tread covers some options on this but a picture says more than a thousand words. ADV has quite a lot of info on hacks/sidecars and I believe a collected tread of suspensions is still missing.
    Not so much the tug or leading link forks but the tub/chair suspensions specifically. Any construction pictures, even plans etc welcome.
    Cheers,
    Rant.
    pops likes this.
  2. Bobmws
    Bobmws Curmudgeon At Large
    Jun 6, 2005
    4,825
    Same trailer, different park, FL
    Here you go, 2005 Hannigab Conde Classic. Stock Progressive shock replace with a YSS from Klaus at EPM.
  3. rantingsmith
    Feb 27, 2017
    408
    Thanks Bobmws for the first post! Is that an air ride system to change ride height or preload beside the conventional shock? I have seen a few pics of these units on hacks but not sure whet the benefit is..
  4. Bobmws
    Jun 6, 2005
    4,825
    No, that's the electric camber control that raises or lowers the hack wheel, changing the bike's angle to compensate for road crown.
  5. rantingsmith
    Feb 27, 2017
    408
    Is this an automatic thing or manual?
  6. Bobmws
    Jun 6, 2005
    4,825
    Manual, uses a toggle switch on the left handle bar.
  7. davebig
    davebig Another Angry Hun !
    Jan 19, 2004
    11,981
    Minnesota
    Claude or Freedom sidecars trailing arm automotive QA1 shock the rocker adjust ride height.
    another view different shock the arm in back attaches sway bar,uses standard 1" wheel bearings at pivot,
    Claude sells hardware and will discuss ideas if you call him.
  8. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    13,908
    Omicron Persei 8
    I have the same Works Performance shock as DB shows here. They are awesome, but I'm partial as I was friends with the founder. I've got them on all 3 corners
    #8
  9. JustKip
    JustKip Long timer
    Apr 28, 2007
    9,194
    Fresno, CA
    I have the same set-up as davebig, on a very different bike. Like it a lot
    #9
  10. rantingsmith
    Feb 27, 2017
    408
    Cool, thanks for the replies guys, quickly finding out that Claude's experience carries a lot of weight around here and rightly so, most of his ideas and rigs seem very well thought out and put together. I wish I had the disposable cash to have him sort my rig out but unfortunately I don't. I do have access to a decent-ish machine shop and can weld pretty good so am not at all adverse to fabricating my own setup. My Watsonian chair came with a setup that was great.. in 1968, shocks and tyres have moved on since then so I figure an update is needed. I wont be building it into a HP rig or an offroad rigbut it will be low to the ground (about 4" under the engine) and I would like the chair (currently at 8" with a 10" wheel) to end up with similar ground clearance but a more conventional 14-15" car wheel/tyre combo so a bit of fabrication is definitely in order.
    And just so it is here, OEM Watsonian Monaco suspension, no brakes (not my picture, I have already dismantled my setup):
    #10
    pops and Old Mule like this.
  11. DirtyDR
    DirtyDR Dana Supporter
    Feb 17, 2003
    3,390
    Hotchkiss Colorado
    CSC torsion suspension. Shortened VW springs.
    #11
    doynebruner and pops like this.
  12. davebig
    Jan 19, 2004
    11,981
    Minnesota
    #12
  13. DirtyDR
    Feb 17, 2003
    3,390
    Hotchkiss Colorado
    Easy enough to convert to a modern torsion suspension but why when this one works just fine.
    Besides I still have all of this to put back together after I spend another $1,000.00 or so.
    #13
    Bobmws likes this.
  14. Prmurat
    Prmurat Long timer
    Oct 28, 2011
    4,022
    Scottsdale, AZ
    After waiting almost 6 minutes months from the "mothership" for the suspension pivot I was able to put the Monza together: a basic motorcycle shock absorber and the stock drum (not linked) and wheel
    Sent from my iPad using Tapatalk
    #14
  15. m_cliffhanger
    m_cliffhanger Momentary Lapses of Reason
    May 6, 2016
    73
    Pemberton, BC, Canada
    No idea on how or even if it will work, but here is my interpretation. They are air shocks that I found on Ebay, and I have about 6" and 4 1/2" of travel respectively. I like the idea of infinite spring rate settings, and since the shocks are exposed, little fingers can't be pinched.
    A significant testing program is part of the build process, and sometimes an angle grinder is the only remedy. :imaposer IMG_8415.jpg IMG_8414.jpg IMG_8416.jpg
    #15
  16. Pete-NZ
    Pete-NZ Long timer
    May 8, 2011
    1,371
    my ADV leaner unit... to hang on the side of my Yamaha XT660R....
    Adjustable ride hight/leveling , shock has spring preload adjustment as well as rebound & compression damping adjustment...
    Build thread is in my sig at the bottom...
    #16
  17. brstar
    brstar Long timer
    Aug 17, 2007
    3,138
    Shoalwater Western Australia
    This is what I adapted for my current leaner set up.
    Ebay fournales shocks and modified Chiang Jiang earles forks I got cheap locally.
    ( need to redo the pivots as the bearings are tiny)
    It works very well as a leaner as it just seems to float alongside the bike.
    But I will I think at some stage if I can find my rountuit, convert back to a rigid outfit.
    The issue I found then is an anti swaybay is needed to stop excess leaning like in a Citroen 2CV.
    Excess lean generally seems to mess the steering geometry while turning and even with camber changes especially with a lot of suspension travel.
    #17
    pops likes this.
  18. foodog2
    foodog2 Been here awhile
    Aug 23, 2011
    197
    Huntsville, AL.
    I used a rubber torsion half axle.
    #18
  19. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    10,139
    Tacoma, WA
    Here's a picture of a pretty much standard trailing arm suspension with actuator from DMC--
    #19
    pops likes this.
  20. pops
    pops Long timer
    May 15, 2007
    1,929
    Stirling North South Australia
    I havent looked at my sidecar suspension for a while.
    Does it show ?
    #20
    brstar and Bobmws like this.
