Show us your sidecar suspensions!
Discussion in 'Hacks' started by rantingsmith, Mar 18, 2017.
If you bought an existing sidecar, have you upgraded, or thought about upgrading its suspension
  1. No, it performed well enough.
    18 vote(s)
    30.0%
  2. Yes, but not sure how to.
    10 vote(s)
    16.7%
  3. Yes and I have.
    27 vote(s)
    45.0%
  4. No, but I woud if I could get a bolt on upgrade.
    5 vote(s)
    8.3%
  1. davebig
    davebig Another Angry Hun !
    Jan 19, 2004
    11,981
    Minnesota
    Claude should answer that , as he has before but a Ford engineer I know told me exactly what Claude did.
    Leading arms ride better and the majority of touring sidecars in production use them, trailing is more HP and less problematic, I've had 3 trailing and 1 leading the leading was the EZS Summit rode like a big German sedan and caster increased as it was compressed.
    #41
  2. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    13,908
    Omicron Persei 8
    Which way is easier over rough terrain, pushing a wheelborrow or pulling it? :ear
    #42
  3. davebig
    Jan 19, 2004
    11,981
    Minnesota
  4. Squily
    Squily Squily Supporter
    Sep 18, 2006
    2,988
    Esperance WA (Down Under)
    I reckon there might be a reason why VW beetle front suspension was (and still is) used widely for off-road buggies and cars.
    So I was figuring I'd stick with that trailing arm design/principle when building mine (still gathering info/data and haven't started yet).
    Now you guys have me all confused
    #44
  5. Strong Bad
    Oct 29, 2007
    13,908
    Omicron Persei 8
    VW front ends, AKA: Beam front end. They are not commonly used in off road in new builds. Except for a couple of limited classes, A-arm front ends are now the off road buggy standard.
    I had the privilege to co-drive in Baja Bob Gordon's Chenowth for the 1st 4 years of the NORRA Mexican 1000 in which we won 3 of those 4 years! Here is a pic of me & Butch Arciero in Bob"s "beam car" known as "Betsy":
    RIP Bob, you are missed.
    #45
    manx16, pops, Bobmws and 1 other person like this.
  6. Squily
    Sep 18, 2006
    2,988
    I wasn't implying they are the standard/rage. Just that they are still used and surely wouldn't be if it wasn't a good/decent design?
    From Kalgoorlie 400 year before last:
    Like I said - I'm confused now as to which way to go on the sidecar (trailing vs leading)
    #46
    manx16 and Strong Bad like this.
  7. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,999
    This should really raise some eyebrows ..
    This is the sidecar suspension I’m using on my next build.
    I built it for my first build and it worked very well !!
    SIMPLE,SIMPLE,SIMPLE !!.
    #47
    pops, Old Mule and Squily like this.
  8. davebig
    Jan 19, 2004
    11,981
    Minnesota
    This isn't rocket science ! Your way over thinking this ! Just build a Ural clone DMC has succeeded with that philosophy.
    Why do you want to build your own ? Is this going to be a square tube, no miters ,butt joint obviously no structural welding experience deal ?
    I put people and things I care about in my sidecar and haul them all over hell, I like to think its well built .
    Good weldors are worth the money !
    #48
  9. Strong Bad
    Oct 29, 2007
    13,908
    Omicron Persei 8
    Like I said limited classes (classes 12, 1600, & 9) still use them but those classes are dying out rapidly, I haven't seen a Class 9 entry in Baja for several years. Most popular limited class is Class 10 that uses A-arms and Ecotech motors. State of the art in Class 1 (unlimited). I was the "Co-dog" with Terry Householder in this car for 2 years. A-arms LS-7 motor with 6 speed sequential Albins transmission, no clutch, uses a torque converter instead. Car got a little sketchy at 125mph across the desert as air would get under the front end causing it to lift enough to make the steering scary light! Sorry about the sidetrack, off road racing is one of my passions. Householder Class 1.jpg
    #49
    manx16, pops, claude and 3 others like this.
  10. Squily
    Sep 18, 2006
    2,988
    I rode a Ural with a sidecar and can't say I cherish the experience.
    As to why build one? I'm getting older and the knees are making it harder and harder to go off-road. So I want a sidecar for more stability and safety. I was leaning towards this type of design:
    My ideal requirements:
    • frame as light as possible
    • allow bike to lean (better for off-road riding and can still use the pegs for better control)
    • wheel on sidecar probably 18" for compatibility with the bike (e.g. tube/tyre size, bearings etc).
    • sidecar room to be used for fridge, fuel, etc.
    • sidecar wheel intermittently driven by hydraulic pump (will help in sand when going slow)
    • wheelbase (bike/rack width) about the same, but slightly less than a 4x4 (wheel rut compatibility)
    I haven't seen anything for sale out there that fits the bill
    #50
    davebig and Pete-NZ like this.
  11. Pete-NZ
    Pete-NZ Long timer
    May 8, 2011
    1,371
    mine.... was till I sold it...
    builds below in my sig....
    #51
    Squily likes this.
  12. Bobmws
    Bobmws Curmudgeon At Large
    Jun 6, 2005
    4,825
    Same trailer, different park, FL
    I don't think a leaner is going to give your knees any relief. :dunno
    #52
    pops likes this.
  13. Squily
    Sep 18, 2006
    2,988
    No no no no!!! Not what I want to hear....
    #53
  14. davebig
    Jan 19, 2004
    11,981
    Minnesota
    I was going to suggest you needed to see FR700's leaner DR 650, he took care of that :-):-)
    #54
    Bobmws and FR700 like this.
  15. claude
    claude Sidecar Jockey
    Mar 17, 2002
    5,756
    Middleburg, Pa. (Snyder County)
    #55
    Deadguyale likes this.
  16. claude
    Mar 17, 2002
    5,756
    Cool looking outfit. Love the body design!! Can you give the masses here what would be examples of 'as and when required' as stated earlier.
    #56
  17. claude
    Mar 17, 2002
    5,756
    How far do we want to go with this stuff ?
    #57
    OzCRU and Squily like this.
  18. claude
    Mar 17, 2002
    5,756
    #58
    OzCRU, davebig and Squily like this.
  19. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,999
    Suspension porn !!
    #59
    largemouthbass, pops, claude and 5 others like this.
  20. Hellracer.nl
    Hellracer.nl What the hack???
    Aug 25, 2012
    1,421
    Netherlands
    Here is the suspension system that I build for my leaner.
    Since a leaner is very sensitive to weight change, I made the suspension adjustable. The damper/spring itself is the same as the bike it's connected to, the length of the swing is also the same.
    #60
    pops, Pete-NZ, brstar and 3 others like this.
