Show us your sidecar suspensions!
Discussion in 'Hacks' started by rantingsmith, Mar 18, 2017.
If you bought an existing sidecar, have you upgraded, or thought about upgrading its suspension
  1. No, it performed well enough.
    18 vote(s)
    30.0%
  2. Yes, but not sure how to.
    10 vote(s)
    16.7%
  3. Yes and I have.
    27 vote(s)
    45.0%
  4. No, but I woud if I could get a bolt on upgrade.
    5 vote(s)
    8.3%
  1. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,999
    What weight ( pound ) axle did you use ???
    I tried one marked 250# and it wouldn't move with 300# jumping on it!!!
    Sent from my iPad using Tapatalk
    #61
    pops likes this.
  2. Sport_Rider
    Sport_Rider Been here awhile
    Jul 26, 2016
    475
    NC
    champion escort swingarm. this one has brake and adjustable tilt on it.
    #62
  3. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,999
    My latest sidecar suspension.
    #63
  4. Neptune03
    Neptune03 Been here awhile
    Sep 1, 2009
    168
    Smith Mountain Lake, Virginia
    #64
    Old Mule, rg sw wa., brstar and 3 others like this.
  5. High Octane
    High Octane Long timer Supporter
    May 31, 2013
    3,202
    South Dakota
    #65
    rg sw wa. likes this.
  6. Neptune03
    Sep 1, 2009
    168
    My previous Yamaha GTS100 Sidebike Mega Comete and my current Yamaha FZ1 home built dual sport and current Hayabusa with RDS Neptune
    #66
  7. High Octane
    May 31, 2013
    3,202
    South Dakota
    I’ll have to go back and review your build thread. Did you modify the rear swingarm on the dual sport FZ1? I’d like to get room for a wider tire on my Bumblezookie. Did you build the chs yourself of did Bill build it?
    #67
  8. Neptune03
    Sep 1, 2009
    168
    The only modification to suspension / swingarm on the FZ1 was longer shock links to increase ground clearance. The leading link front end and rest of the sidecar was cobbled together by me. The CHS as well as the steerable sidecar wheel, frame and sidecar suspension on both of the street bikes were built by Sidebike for the Mega Comete and RDS for the Neptune.
    #68
    Old Mule, rg sw wa., brstar and 2 others like this.
  9. High Octane
    May 31, 2013
    3,202
    South Dakota
    What size is the rear tire on the FZ1?
    I wonder if I could cobble one of those FZ1 swingarms into my Bandit??
    Really some nice work. Sorry to have missed you last fall. Maybe we will have time to take a run up to VA when I visit Alabamer in November.
    #69
  10. Turbomachine
    Turbomachine Stirring the noodle
    Nov 23, 2009
    616
    FL
    Simple. Flexi-ride FR-550-S torsion half-axle, for a lightweight leaner. Doesn't provide a ton of damping but I've managed to tune it to ride reasonably well on smooth roads, which is all I do.
    #70
  11. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,999
    #71
    rg sw wa., FLYING EYEBALL and pops like this.
  12. FLYING EYEBALL
    FLYING EYEBALL out of step
    Mar 18, 2008
    12,799
    north of seattle
    Al,
    How bout sharing how you assembled the Box and what materials you used?
    #72
    rg sw wa. and pops like this.
  13. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,999
    I built it out of 5/8” CDX and sealed the inside with flex seal.
    I gave the outside 3 coats of bed liner.So far it’s been watertight!!!.
    #73
  14. Haul N Ride
    Haul N Ride n00b
    Feb 1, 2019
    7
    Australia
    Hi there Rant,
    I have a wheelchair accessible sidecar. I purchased the tub on gumtree for $650. The swing arm shocky setup was all there in place. I will upload some pics for you. This setup carries 140 kg sidecar and 110 kg wheelchair and the occupant 55 kg. It has a pump up shocky, which is essential for the sidecar's purpose. Pumped to 80 psi when laden. This puts the sidecar on a huge lean when empty. So let it down to 50 psi and the sidecar sits horizontal when empty. IMG_20130223_110028.jpg IMG_20130223_110052.jpg IMG_20130223_133122.jpg IMG_20130223_133141.jpg
    #74
  15. Haul N Ride
    Haul N Ride n00b
    Feb 1, 2019
    7
    Australia
    #75
    FLYING EYEBALL and rantingsmith like this.
  16. Haul N Ride
    Haul N Ride n00b
    Feb 1, 2019
    7
    Australia
    #76
    Old Mule, cateyetech, pops and 4 others like this.
  17. Haul N Ride
    Haul N Ride n00b
    Feb 1, 2019
    7
    Australia
    Now that I do like, I have a motorcycle trailer that carries a motorcycle behind my bike. I looks the same. My trailer has a big square solid rubber pushed into a square tubing just like your photo. The shocky has carried an iron 883, Ducati 750, Suzuki Intruder, Virago, 140 kg sidecar, huge logs to keep us warm in winter. I think the torsion shocky works extremely well.
    You can check out my trailer here: https://www.haulnride.com/motorcycle-trailers-ride-n-tow
    Cheers Dave
    #77
  18. moffit virtue
    moffit virtue Japa
    Feb 20, 2011
    106
    Northern tablelands N.S.W.Australia
    Corrugated dirt roads and i did not say the wife is fat,, 100_1359.JPG 100_1358.JPG
    #78
  19. rantingsmith
    rantingsmith Quadrilingual blacksmith seat of pants engineer
    Feb 27, 2017
    408
    UK for now but not from here
    #79
    rg sw wa. and FLYING EYEBALL like this.
  20. moffit virtue
    moffit virtue Japa
    Feb 20, 2011
    106
    There it is Naked 1984 GS1100GK with a 99 oswald sidecar. 2017 monarchs sidecar rally.jpg 032.JPG
    #80
