Show us your sidecar suspensions!
Discussion in 'Hacks' started by rantingsmith, Mar 18, 2017.
If you bought an existing sidecar, have you upgraded, or thought about upgrading its suspension
  1. No, it performed well enough.
    18 vote(s)
    30.0%
  2. Yes, but not sure how to.
    10 vote(s)
    16.7%
  3. Yes and I have.
    27 vote(s)
    45.0%
  4. No, but I woud if I could get a bolt on upgrade.
    5 vote(s)
    8.3%
  1. XLRACER2
    XLRACER2 Adventurer
    Jul 11, 2019
    16
    Trelawnyd, North Wales,UK
    Early Watsonian Monza tied to anXV535 Virago, with an upright shock,and 31/8" pcd hub, The wheel recently broke up so I made an aluminium hub with 4" [CD and fitted a mini cooper 3.5" steel wheel, and got the offset sightly wrong so had to thin out things on the inside toprevent tyre rubbibg. Heavy steering was sorted by angling the steering stem 5 1/2deg forward in the yokes. Sidecar shock is a Gazi race car shock
    #81
  2. XLRACER2
    XLRACER2 Adventurer
    Jul 11, 2019
    16
    Two more IMG_3987[1552].JPG IMG_3994[1556].JPG IMG_3987[1552].JPG IMG_3994[1556].JPG pictures IMG_3987[1552].JPG IMG_3994[1556].JPG
    #82
    pops, Old Mule, rantingsmith and 2 others like this.
  3. skychs
    skychs chuck smith Supporter
    Mar 15, 2010
    2,687
    Glen Allen Va (N. Richmond)
    Good old Torsion bar suspension for this mid 60's Globe GS200 sidecar. No complaints from the wife who loves to ride in it. X7bcHOnAS3+1cBVFi+mi+g.jpg
    #83
    pops, Old Mule, XLRACER2 and 5 others like this.
  4. rantingsmith
    rantingsmith Quadrilingual blacksmith seat of pants engineer
    Feb 27, 2017
    408
    UK for now but not from here
    So if I get this correctly there's a torsion bar arrangement in the swing arm mounting plus a rubber buffer (grey cylindrical thingy) and two rubber stops at max and min travel? Plus the back of the tub is suspended by rubbers? Is there any adjustments or is it just set?
    Cheers,
    Rant.
    #84
  5. PowderMonkey
    PowderMonkey Been here awhile
    Jun 13, 2015
    316
    Maine
    Custom Ural bell crank setup.
    I wish I’d seen this thread when I’d made my my suspension.
    #85
  6. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    13,863
    Omicron Persei 8
    I would gusset that tower just like the hoop
    #86
    FLYING EYEBALL and rantingsmith like this.
  7. PowderMonkey
    Jun 13, 2015
    316
    Maine
    It’s bracketed to the hoop, in double shear. Already in paint, and in service. View attachment 1781702
    #87
    FLYING EYEBALL likes this.
  8. skychs
    Mar 15, 2010
    2,687
    That’s correct. No adjustments that I see. I guess that was the technology back in the early 60’s.
    #88
    rantingsmith likes this.
  9. Metalcarver
    Metalcarver Geezer Berserker Supporter
    Jun 19, 2010
    2,239
    Port Angeles, WA
    Not sure if this is where you post brain farts but I went and had one but searched youtube and like most of my other ones, somebody had a better one. This will probably trigger one of your own:
    #89
  10. Strong Bad
    Oct 29, 2007
    13,863
    Omicron Persei 8
    In 2010 with the Oshkosh LCTV we raced in Baja we used an active suspension system. Each shock had position sensors and accelerometers so a computer could know how fast the shock piston was traveling through the stroke and an adjustable orifice would change the damping. Additionally the amount of steering input was used so the damping of the shock could be used to reduce the body roll and eliminate the need for anti-sway bars. Pretty good as each wheel carried a 2,000 lb load and had 36" of travel!
    #90
  11. Metalcarver
    Jun 19, 2010
    2,239
    Port Angeles, WA
    If you put together an outfit, I'm putting a big red triangle on the back of mine.
    #91
  12. rantingsmith
    Feb 27, 2017
    408
    As mentioned in the video Citroen already did this, here's a video of some Citroen 3 wheelers using this suspension in action:
    #92
    pops and rg sw wa. like this.
  13. pops
    pops Long timer
    May 15, 2007
    1,929
    Stirling North South Australia
    I must have been on some good drugs ,when i built this conglomeration.
    Time for a redesign i think.
    #93
  14. mikepa
    mikepa SideCzarist Supporter
    Dec 10, 2001
    885
    Seattle, WA in the Great Pacific NorthWET (USA)
    Chair's suspension on my Stepler/LBS Zijspantechniek English-designed/Dutch-built sidecar. I purchased the prototype and had it shipped to me here in Seattle, and we're still in the throes of re-finish and re-build. Did have the opportunity to test-drive the first production rig in Holland recently, impressive handling, though I didn't get a chance to run it on the freeway or off-road:
    #94
  15. rg sw wa.
    rg sw wa. Long timer Supporter
    Feb 9, 2011
    2,048
    Southwest Washington
    :clap
    #95
    FLYING EYEBALL and mikepa like this.
  16. arbalest
    arbalest Long timer
    Mar 19, 2009
    1,462
    Windham, Maine
    Austin Mini had this years ago.
    #96
  17. Jimr80gs
    Jimr80gs Been here awhile
    Feb 19, 2010
    324
    North Central MT
    So what % sag should be on SC shock, loaded?
    Seems to fit this thread, didn't find in the design thread.
    #97
  18. mthure
    mthure Adventurer
    May 23, 2015
    50
    Puerto Penasco, Mexico
    Looks like they adapted a BMW final drive into a billet block of aluminum, without the pinion. Talk about doing it in the most expensive manner possible.
    #98
    pops and rantingsmith like this.
  19. WILL_S
    WILL_S OUTLAW POSTIE 001
    Feb 16, 2009
    3,654
    goodly satisfactory place, qld
  20. rantingsmith
    Feb 27, 2017
    408
    What exactly are you referring to with 'this'?
    rg sw wa. likes this.
