Show us your TransAlp modifications!
Discussion in 'Japanese polycylindered adventure bikes' started by modrover, Apr 13, 2004.
  1. Fiftyfatponies
    Fiftyfatponies Been here awhile
    Mar 13, 2019
    106
    Sweden
  2. Ladder106
    Ladder106 It's a short cut, really
    Jan 31, 2005
    6,043
    Davis, CA
    The Twin Air looks good.
    And, yeah, I think I'd just take off the tank. I've got the RD04 tank on mine but even then it only takes 30 min. or so to remove it.
    Maybe not the perfect set-up but also fairly easy to do at camp even if out on the trail for a week.
    Then again - if I built an aluminum tank in place of the air box, I could actually cut up the AT tank to make access. But. somehow the though of welding on a gas tank gets me a mite concerned.
  3. 2old2Bbold
    2old2Bbold was 2bold2getold
    Dec 10, 2011
    5,007
    Arlington, Texas
    My thoughts exactly. It would be fun to make a lower tank (under seat, behind shock). There have been a couple of those done in the past. But I'm not gonna cut up my tank to do it. I've got the time and the tools so who knows...might give it a go some day. Guess I better hurry up and get on it while I still can. :D
  4. 2old2Bbold
    Dec 10, 2011
    5,007
    Arlington, Texas
    Something like gpmucci did with one of his many AT customs.
  5. 2old2Bbold
    Dec 10, 2011
    5,007
    Arlington, Texas
    Or this one
    Squily and MotoPolo like this.
  6. xNOKIAx
    xNOKIAx Been here awhile
    Sep 26, 2010
    177
    slovakia
    thats 650 TA. i think its easier for air filter mods. frame is different
  7. 2old2Bbold
    Dec 10, 2011
    5,007
    Arlington, Texas
  8. xNOKIAx
    Sep 26, 2010
    177
    slovakia
  9. MotoPolo
    MotoPolo So many places, so little time Supporter
    Jun 4, 2015
    914
    Portland OR
    2O2BB
    someone mentioned a USD fork tube that fits this triple tree - does anyone have photos for this conversion? Can someone provide OEM model numbers? Are there any real advantages of the USD forks over what you did which has a nice period look? thanks
  10. MotoPolo
    Jun 4, 2015
    914
    Portland OR
    2O2BB
    I LIKE THE LOOK OF THIS - do you have any more info on this bike - maybe a build thread? Now that my AR17 is done I'm itching to modify something and looking at son's TA and wondering what could be.
  11. 2old2Bbold
    Dec 10, 2011
    5,007
    Arlington, Texas
    I think some of the XR650L guys are doing the USD fork mods....might get more info there. I wasn't really interested in doing that to my bike.
    MotoPolo likes this.
  12. 2old2Bbold
    Dec 10, 2011
    5,007
    Arlington, Texas
    He's an Italian guy (I think) with a nack for aluminum work. He used Africa Twins for a base for his modded bikes. They were/are abundant in his area.... https://advrider.com/f/search/75643197/
  13. plumer1kt
    plumer1kt Adventurer
    Feb 11, 2015
    1,339
    Hellas
    Not USD but it is a WP EXTREME on the XRL.With the same mod (KTM triple clamps) i could have done a USD WP .
    I tried it on the 650 but the XR600R forks are matching better on the TA due to the triple clamp offset .
    USD= less unsprung weight.
    Those extreme's are way too heavy...
    You can search for CRF forks too.Check the XRV thread.
    MotoPolo and benedikt.m like this.
  14. Fiftyfatponies
    Mar 13, 2019
    106
    Sweden
    Apparently the XRL and the Transalp should have identical stem and steering head bearings, so what's done to the XRL should also work on the Transalp. (Not considering fork length, travel, offset etc)
    In theory this USD set should work to put a set of crf forks on the transalp.
    http://www.rswracing.com/xr650l.htm
    Or there is "fork conversion bearing set" to convert from XRL to CRF, using the CRF triples, that should also work on the transalp. But the CRF stem is longer, so there is more work to be done.
    https://www.allballsracing.com/forkconversion/
    This is all in theory, I have a complete crf front that i will work on during winter.
    Just changed tyres on the bike and took the opportunity to weigh the wheels. The front wheel on a 99' with double disks weighs 12kg, just wheel and tyre. While the complete CRF front weighs 17 kg. Including triples, stem, brake caliper. The rear wheel is just terrible...
  15. xNOKIAx
    Sep 26, 2010
    177
    slovakia
    you can look in my thread. but i used KTM WP front. just need take off 1mm from bottom triple clamp for bearings
    https://advrider.com/f/threads/rebuild-honda-transalp-600-98.1358675/page-2#post-37031174
  16. xNOKIAx
    Sep 26, 2010
    177
    slovakia
    I was riding this week and I discovered my bike is starting very hard. Sometimes engine stop. I did not know what happened. It was suddenly. Was working till now without problems. Today I was looking closely and discover burning regulator connector. It happened last year. I exchanged regulator and connector. I did 10k Km on it and it’s again. While running motor I had 13.2V. I used new regulator today (made in china) and it’s showing now without lights 14V and with lights on 13.9. Is that ok? Does somebody know what can be wrong please? Do I have to check alternator somehow? Or just new better quality regulator will solve it?
  17. MotoPolo
    Jun 4, 2015
    914
    Portland OR
  18. Fliegenfischer
    Fliegenfischer Adventurer
    Jul 19, 2009
    66
    Hannover
    an other idea to use K&N filters
  19. Son of MotoPolo
    Son of MotoPolo The mountains are calling...
    May 1, 2016
    192
    Sonoma, CA
    I've heard the TAs are very sensitive to changes to the airbox. Have any of you that've switch to K&N or a modified airbox had any tuning issues?
  20. Fiftyfatponies
    Mar 13, 2019
    106
    Sweden
    Son of MotoPolo likes this.
