Show us your TransAlp modifications!
Discussion in 'Japanese polycylindered adventure bikes' started by modrover, Apr 13, 2004.
  1. Fiftyfatponies
    Fiftyfatponies Been here awhile
    Mar 13, 2019
    106
    Sweden
    @Skyliner : Thank you, that is a lot of useful info. If it only had been a matter of making a spacer or two it would have been easier and cheaper with an xrl rim. And perhaps lighter. Ideally i would like a crf rear wheel but i realize that hub is so much narrower that it's not doable.
    But you are right, it's easier to have the original hub to work with. I have done a couple of downhill mtb wheels and it's basically the same but on a larger scale. But how do i "watch for the angle of the spoke holes"? They are what they are right? There is no specified angle on a new rim and i don't have any value to start with anyway right? How do you solve it? Drilling the holes?
    @plumer1kt : Thank's for the tip, that seems like a nice affordable rim!
    @TransAfrika : Thank you. Yes africanqueens have some really nice builds and parts! I remember like 20 years ago they had AT and Varadero builds that were on a level with the new crf 1000 AT. But i have a feeling that it would be quite expensive to first buy a decent wheel and then send it to the pro's. I definitely want 2 sets, one 17" for the tarmac and one 18" for the dirt. And perhaps even a 19" front to go with the 17". But there is alot of work before that!
  2. 2old2Bbold
    2old2Bbold was 2bold2getold
    Dec 10, 2011
    5,016
    Arlington, Texas
    The Transalp, XR650L and KLR650 all use a 17mm axle....Nothing that can't be overcome but one more thing to think about.
  3. jagerb
    jagerb Adventurer
    Jun 12, 2019
    31
    Amsterdam
    For the TA 650 guys on here. (especially plumer1kt :) )
    Do you need to remove the cat if you want to flip the rear dog bone? Will you be able to put it back on after?
  4. plumer1kt
    plumer1kt Adventurer
    Feb 11, 2015
    1,339
    Hellas
    Yes.
    No if you plan to stay with oem downpipes.
    Unless you are going to cut/weld/cut/weld all the time.
    And of course you have to lower the bike again to reinstall the cat.
    Is MOT tests what you afraid of? Emissions?
  5. Geo-Nemesis
    Geo-Nemesis Adventurer
    Jun 17, 2012
    59
    hi folks, I have a weird issue my alp, i suddenly "lost" 10km/h or gained 1000rpm, can't understand whats wrong. i only know that the instruments always said 6000rpm @ 120km/h and know i am at 7000.
    I noticed that the rev counter goes all the way over the red line. doesn't the Transalp have a rev limiter?
    gearing il stock 15/48
    what am I missing?
  6. jagerb
    jagerb Adventurer
    Jun 12, 2019
    31
    Amsterdam
    I couldn't care less about the emissions haha. I'm planning to remove the pair system aswel. They don't check that kind of stuff in the Netherlands.
    It's just that i don't want to spend a lot of money on new downpipes.
  7. plumer1kt
    Feb 11, 2015
    1,339
    Hellas
    No need to and don't do unless you like this...
    :D
  8. TransAfrika
    TransAfrika Been here awhile
    Jun 23, 2013
    190
    Wesel / germany
    Hi I did that. It was not so difficult, u have to make plates to close the openings on the topside of the cylinders. I use some Aluminium plates between the outlet and the valve cover.
    Next close the holes in the airfilter case and on the vacuum outlet on the front cylinder .
    That sound played in the video i dont have.... I sync my carbs and the engine is running fine.
    I have ABP tubes and they are a direct fit, remove the original tubes and cat. And again i dont have this backfire problem.
    If u have questions send a PM.
    Here a link to the ABP homepage:
    https://www.abp-racing.de/leistungskrümmer/
  9. Dudley
    Dudley Long timer Supporter
    Nov 22, 2006
    1,024
    Chaska, Minnesota, Palm Desert, California
    Can some one tell me the rear tire size for a 1989 Transalp. I am ordering tires and the bike is in California and I'm not.
  10. 2old2Bbold
    Dec 10, 2011
    5,016
    Arlington, Texas
    Manual says "Rear tire size...130/80-17 65s.
  11. Dudley
    Nov 22, 2006
    1,024
  12. Dudley
    Nov 22, 2006
    1,024
    PM sent
  13. Ladder106
    Ladder106 It's a short cut, really
    Jan 31, 2005
    6,043
    Davis, CA
    How old is your clutch?
  14. Geo-Nemesis
    Jun 17, 2012
    59
    hi ladder, the clutch has 4 years and 35k kms.
    this weekend after 400kms of bumpy trails everythink went back to normal. I am back to the old 6000rpm @ 120km/h...what should i look for?
  15. Ladder106
    Jan 31, 2005
    6,043
    Davis, CA
    First check the clutch lever freeplay at the lever. I wouldn't expect a clutch problem with so few kms. Are you the original owner?
    Best is to find a slight uphill section of road. 2nd gear at about 3000 rpm then quickly go to full throttle. You can also add a bit of rear brake (gently) to add a bit more load. You're looking for a sudden increase in rpm without a corresponding increase in acceleration.
    You can also open the dipstick and have a sniff for anything smelling burnt.
  16. xNOKIAx
    xNOKIAx Been here awhile
    Sep 26, 2010
    177
    slovakia
    I just put new filter for testing. It’s only quick fitting. Proper fit after test ride. I let you know how it is after some drive.
    Fiftyfatponies likes this.
  17. Ladder106
    Jan 31, 2005
    6,043
    Davis, CA
    Interesting
  18. gkam
    gkam Been here awhile
    Feb 14, 2010
    135
    And simple and smart!
    However, the intake air may be warmer
  19. Ladder106
    Jan 31, 2005
    6,043
    Davis, CA
    That was my concern, also
  20. Fiftyfatponies
    Mar 13, 2019
    106
    Sweden
    Does anybody know the fuel pump capacity of the 600? I have an idea about a different fuel tank and need an external pump.
