1. ** Enter to win a $250 gift card! We want to hear from you, please take this survey **
    Take this survey which covers a range of questions about improving the community, the things that interest you and anything else you want to share with us. All responses will remain anonymous.
    Click here to take the survey
    Dismiss Notice
Show us your TransAlp modifications!
Discussion in 'Japanese polycylindered adventure bikes' started by modrover, Apr 13, 2004.
  1. Clem Kevin
    Clem Kevin Nude With Boots
    Aug 17, 2007
    1,365
    Petrolia, CA
    Could someone tell me what the manual states for piston clearance. Just dropped off my cylinders for boring.
  2. 2old2Bbold
    2old2Bbold was 2bold2getold
    Dec 10, 2011
    5,301
    Arlington, Texas
    I like to set my motors up pretty tight but .0004" sounds too tight to me. ??? Especially if you're not using oem pistons. After market pistons should have a stated clearance with them.
  3. Clem Kevin
    Aug 17, 2007
    1,365
    Petrolia, CA
    Went with OEM. I'll consult the machinist, but he says he prefers to run right. But damn that is TIGHT.
  4. 2old2Bbold
    Dec 10, 2011
    5,301
    Arlington, Texas
    Agreed, .015" - .002" is my go to. Anything under .001" is pretty tight. Probably need careful break in.
  5. Clem Kevin
    Aug 17, 2007
    1,365
    Petrolia, CA
    Thanks for the piston clearance info, I appreciate it guys. Cylinders are ready to go.
    Next step is customizing the wiring up front. I'm switching to a Trailtech unit, and wanted to add an extra switch that is hidden for the ignition. I'm inexperienced with electronic schematics, but please help me out here...
    Which of these is actually sending power to the on/off switch on the handlebar, and which one is the starter button? I have my guesses, but I'm just looking to be sure.
    Red/Yellow goes to the starter relay switch
    Black/Red goes to the fuse box (fuse d)
    White/Green goes to the fuse box (fuse b)
    Black/White goes to the CDI unit
    Blue/White goes to the handlebar switches and powers hi/lo (I'm not actually sure what that means).
    Another thing that I'm feeling a little confused about is the lack of ground wires up front. Can I run my own ground wire for powering the trailtech unit, and does it need to return to the battery or can I just use the frame ground points?
    Finally, if anybody else is experienced with this wiring diagram, is the black wire up front just a circuit for everything that's controlled by a switch? I'm assuming it's doing the same job as the brown wire?
  6. 2old2Bbold
    Dec 10, 2011
    5,301
    Arlington, Texas
    expand ^^^
    Thanks for the color diagram. :clap
    Clem Kevin likes this.
  7. Skyliner
    Skyliner Adventurer Super Supporter Supporter
    Feb 26, 2010
    95
    Woodside California
    Why would you guys second guess the Piston Clearance Specs from Honda? I went through all my manuals from 1989 to 2013 and they all call for pretty much 0.0004 - 0.018 with 0.04 as the Service Limit.
  8. 2old2Bbold
    Dec 10, 2011
    5,301
    Arlington, Texas
    Experience.... 30 years building VW (and other) motors. :dunno
  9. aggrohead
    aggrohead Inside Sucks
    Apr 26, 2010
    153
    Tri-Cities, WA
    Fuel Capacity question:
    So I was coming home from a long trip (250ish miles), the first of that kind of length I have done with this bike. On the way home I had to switch into reserve going down the highway. Bike started sputtering out like it was losing fuel, but would surge every now and then so I assumed it was just really low on gas.
    I go to fill it up, and it took 3.51 gallons of gas. Everywhere I look says that these bikes have 4.8 gallon tanks with .77 of that being for reserve, so what gives? I should have had another gallon of gas, which would have been enough to get me home, even my buddy I was riding with said "you shouldn't need gas yet!" his bike is a 2016(?) Tiger 800 and has close to the same range and capacity on paper. My tripmeter showed 135 miles, which gives me 38.46 mpg, whereas the week before I filled up and got 49.2. The engine got a little toasty at times on the trip, so I stopped a few times to "check the scenery," but I never let it get into the red, but the temp needle was in the upper 3/4 area if that makes sense.
    So basically my questions are, am I using the reserve wrong or something? Could a vent hose be pinched somewhere? Could the heat that I was riding in have that much impact (but still doesn't explain the 3.51 gallon refill)?
    This is the first bike I have owned that I have done long distance stuff on, so I apologize if these are noob questions. I am just kinda confused here.
    Also here is a pic from the ride! Found this awesome set of switchback fire roads, and I got to try out my new Tusk Pilot bags and some new camping gear.
  10. tag3
    tag3 Doofus
    Jan 17, 2014
    16,925
    Inland from the coast of Santa Cruz and Trona.
    135 sounds about right. As soon as I put bags on mileage suffers.
    aggrohead likes this.
  11. Skyliner
    Feb 26, 2010
    95
    Woodside California
    You have to be pulling a boat to only get 38 mpg. My TA 750 with cloth bags gets gets 45-46 mpg. My Varadero 1000 gets 33 mpg with cases, top box Passenger and fully loaded.
  12. Skyliner
    Feb 26, 2010
    95
    Woodside California
    Experience.... Factory Trained Honda Mechanic 1975
    aggrohead and 2old2Bbold like this.
  13. DaleE
    DaleE TransAlp Adv
    Jan 13, 2006
    763
    Boulder, CO
    Wind, speed, temps and weight all can have a huge impact on mileage. There's a rpm point, around 5000+, where the mileage on mine drops dramatically if held there for a while. If you were trying to keep up with your friend on the hwy, especially if there was a headwind, that mileage isn't out of range. The tank capacity is what it holds, not what you can use. If it's hot, it's also hard for the little vacuum pump Petcock to maintain pressure on a low tank.
  14. 2old2Bbold
    Dec 10, 2011
    5,301
    Arlington, Texas
    So you would set up motors at .0004" (less than 1/2 a thousands inch) piston to cylinder clearance ? Does that work out ok ?
  15. Skyliner
    Feb 26, 2010
    95
    Woodside California
    I've never found anyone with that kind of precision machining. But I've definitely had some that were less than 0.001". Now my Wiseco Big Bore High Compression pistons need more space. Even then, Wiseco recommends 0.002". A stock low compression Piston can handle less. Your talking less than a 3" piston.
  16. 2old2Bbold
    Dec 10, 2011
    5,301
    Arlington, Texas
    I think our experiences are very similar. Most of the piston and cylinder sets I used were .0015" - .002". Honda probably has the expansion rate figured a little better than the German Mahle sets and much better than the Brazilian and Mexican sets, but those piston/ring sets were good for 100k miles even back then.
  17. Skyliner
    Feb 26, 2010
    95
    Woodside California
    I don't think Honda would run 0.002" - 0.003" clearances and then say "We'll tell them it was 0.0004" - 0.0018" just to ƒuck with their minds".
    I was just looking at my V-Strom 1000 manual and it says it has a service limit of 0.12" for piston clearance.
  18. 2old2Bbold
    Dec 10, 2011
    5,301
    Arlington, Texas
    I think they were smart enough to use compatible alloys of piston and cylinder material so the thermal expansions were not detrimental. That sounds like a real art to produce a system that will not bind up at -40f and +120f, especially at those small clearances.
  19. 2old2Bbold
    Dec 10, 2011
    5,301
    Arlington, Texas
    Guessing that's supposed to be .012".
    .120" might be a little sloppy. :D
    Sorry my technical brain just naturally pics up on silly little details. :dunno
  20. Skyliner
    Feb 26, 2010
    95
    Woodside California
    You're Right, Sorry. It was 0.12mm (0.0047") . It was late.
    2old2Bbold likes this.
