Sidecar Design Formula - IMPORTANT!
Discussion in 'Hacks' started by Get Back, May 25, 2009.
  1. Old Mule
    Old Mule Long timer
    Mar 24, 2013
    1,575
    Overland Missouri, home of 1950s sidecar tech.
    I was just thinking, reading about e bikes- it is past time for every sidecar company, big manufacturer or small shop, to conference up and standardize a big under-floor battery pack- with standard inputs and outputs, standard sizes, tray for quick replacement, standard wiring harness, and get ahead of the game. The room and good weight placement that hacks have for batteries- it could put them ahead of bikes and cars.... think 2024, you techies.
    BMWBUD and Flyin' Monkeys like this.
  2. GearHeadGrrrl
    GearHeadGrrrl Long timer
    Feb 3, 2007
    1,171
    SW MN & Flatistan when it snows
    Problem is right now if you were going to use the typical 400 to 800 volt battery pack and propulsion system it would cost more than the whole sidecar. For folks that want to experiment, it doesn't take much of a crash to total out a Nissan Leaf EV and they sell cheap...
    Flyin' Monkeys likes this.
  3. Jack Grinder
    Jack Grinder Adventurer
    Aug 9, 2017
    15
    Rockledge, Florida
    I'm with Mule, what better platform than a sidecar.
    Old Mule likes this.
  4. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    11,211
    Omicron Persei 8
    Now if you just had the technical know how for all of the controlers and 'puters that go along with it, you might not get electrocuted in you shop!
    BMWBUD and Bobmws like this.
  5. rantingsmith
    rantingsmith Quadrilingual blacksmith seat of pants engineer
    Feb 27, 2017
    399
    UK for now but not from here
    I agree about the suitability of the sidecar platform and some of the advantages this would bring.
    Maybe the thing to actually design would be a range enhancing sidecar battery pack for electric motorcycles. Make it a leaner and it might even prove successful with the traditional two wheeled crowd...
    Jack Grinder likes this.
  6. rantingsmith
    Feb 27, 2017
    399
    Reading about a discussion on strut angles ( here: Sidecar strut angles
    https://r.tapatalk.com/shareLink?sh...dex.php?threads/Sidecar-strut-angles.1382211/ )
    This threw up another question for me, are certainty types of joints better on certain mounts, I.e. Tube clamp style slip joints(? not sure that's what to call them) vs threaded eye (? clevis) or rose, ball joints??
    I suspect, experience dictates one has greater rigidity vets easier adjustability.. but on an ideal build what or rather what combination is preferable?
    I suspect the lower mounts as larger tube within tube slip/clamp style and the upper ones of an easier adjustment style but frankly I don't know so what do some of the experts think?
    Cheers,
    Rant.
  7. BMWBUD
    BMWBUD I couldn't hack it. Back on two wheels.
    May 15, 2006
    2,569
    Mid-Wurst Southern Illi-noise
    Quick ? I'm getting ready to adjust the lean out on my rig and know that when that is set correctly, I may need to adjust toe in. The question is do you measure toe in at the center of the contact patch of the front wheel or somewhere further ahead or behind.
  8. FLYING EYEBALL
    FLYING EYEBALL out of step
    Mar 18, 2008
    12,424
    north of seattle
  9. BMWBUD
    May 15, 2006
    2,569
    thanks
    FLYING EYEBALL likes this.
  10. rantingsmith
    Feb 27, 2017
    399
    Anyone?
  11. Old Mule
    Old Mule Long timer
    Mar 24, 2013
    1,575
    Screw type adjusters are stronger than clamp-type ones, used on the connecting arms. Rose joints and ball joints have published specs, it's easy to find the strength and recommended uses of each size and type.
    rantingsmith likes this.
  12. Strong Bad
    Oct 29, 2007
    11,211
    Omicron Persei 8
    Although many of our USA sidecar mfgrs. use two male rod ends, a clevis male/female style is better as the bolt holding the two ends are in double shear rather than single shear.
    Old Mule, Bobmws and rantingsmith like this.
  13. davebig
    davebig Another Angry Hun !
    Jan 19, 2004
    11,039
    Minnesota
  14. FLYING EYEBALL
    Mar 18, 2008
    12,424
    north of seattle
    :lol3
    FR700 likes this.
  15. davebig
    Jan 19, 2004
    11,039
    Minnesota
    On the EZS K connections with double shear you can also adjust the toe without complete detaching the mount.
    Loosen the big nut give it a tap loosen the lock nut on your adjuster and adjust in or out. :hmmmmm:hmmmmm tighten the large nut again.
  16. sidecar
    sidecar Adventurer
    Nov 20, 2007
    43
    Raymond Alberta
    Just in case you didn't know, the guy that wrote the article used to race off road sidecars in England, has worked on sidecars all his life, has built custom made dedicated rigs that most people could only dream of. I understand if it's all a little to technical for you.
    Hvymax likes this.
  17. Bobmws
    Bobmws Curmudgeon At Large
    Jun 6, 2005
    4,279
    Same trailer, different park, FL
    Dude, you went back to page one of a thread started 10 years ago to call someone out on their comment?! :fpalm
    Really?! :twitch
    Oh, and it's "too". :augie
    Hey Drone, did I get that right? :D
    brstar likes this.
  18. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    8,995
    Tacoma - ish, WA
    It's important to observe a cooling off period before jumping down somebody's throat. 10 years is about right. :lol3
    Old Mule, Bobmws and brstar like this.
  19. Strong Bad
    Oct 29, 2007
    11,211
    Omicron Persei 8
    The Canooks are all getting a little grumpy these days, I guess they are about ready for spring by now.
    brstar and Bobmws like this.
  20. Hvymax
    Hvymax Been here awhile
    Sep 22, 2016
    453
    La Plata MD
    I'm going with trial and error. Im going to attach the suspension/axle assembly with clamps about where the conventional formula dictates. I'll throw a few hundred pounds on it and try it out. If needed I can make any adjustments until I'm happy and then weld it up. I cut and redid the rear pivot about 6 times. IMG_20190608_161741299.jpg IMG_20190608_161840384.jpg
    Squily likes this.
