SidecarLeigh's KLR 650 sidecar Project
Discussion in 'Hacks' started by SidecarLeigh, Sep 15, 2018.
  1. SidecarLeigh
    SidecarLeigh Been here awhile
    Mar 10, 2017
    177
    Adelaide
    Cheers nicj, all the best to you too!
    About to head to the shed to give it a good clean which normally means I spend the next couple of day after trying to find things!! I think we've all done that
    #61
    pops and norton(kel) like this.
  2. SidecarLeigh
    Mar 10, 2017
    177
    Adelaide
    image.jpeg image.jpeg Well got through Xmas and New year OK, hope everybody else did as well!
    So my sidecar hub was machined at a "mates place" on his CNC, pretty happy with the end result, need to drill the spoke holes tommorow, then off to get some spokes soon after. Hopefully it will look the goods. Yah, then get stuck into the front end.
    #62
    NikoRedStar, OzCRU, pops and 11 others like this.
  3. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    18,166
    Your imagination.
    Hubba, hubba :knary
    #63
    XSive, brstar and FLYING EYEBALL like this.
  4. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,691
    What wheels are you going to use
    #64
  5. SidecarLeigh
    Mar 10, 2017
    177
    Adelaide
    Standard 21" front and 17" rear and 17" rim off the rear of a DR650 with my own hub(as above). Tubes all round.
    The main reason is I'm trying to keep costs down on the build and 21" tyres and tubes are/should be available in the outback etc. Hope it works I guess.
    Still machining bits and I have returned to work after the Summer break, so it may slow a little bit but I must keep moving on the build. Hub, rim have now been polished, so off to the anodiser tommorow, then spoke it
    #65
  6. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,691
    I just converted over to 3 17” cast tubeless wheels off a Suzuki GS500.Pretty easy swap with a little fabrication.
    #66
    NikoRedStar and bomber60015 like this.
  7. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,691
    #67
  8. SidecarLeigh
    Mar 10, 2017
    177
    Adelaide
    Looks good, I just don't want a little front wheel and I like spoked wheels. That's just me
    #68
    Hi-De-Ho, BigFatAl and FR700 like this.
  9. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,691
    Finished the 17” wheel conversion today.
    Now I have 3 matching tubeless wheels on the rig.
    #69
  10. NikoRedStar
    NikoRedStar Adventurer
    Aug 9, 2011
    15
    Y’all are my Sidecar heroes. Very cool builds!
    Can any of you provide some insight on the upper front mount on a Gen 1 KLR650? How are you mounting to frame on upper right side behind faring, beneath the tank? Has anyone had success mountain with an over sized tank?
    Trying to keep a velorex hack from folding in on itself. Everytime I get it to where I want, it slips in a few inches. Thanks for any pics, leads, or input!
    IG: redstarsidecar
    #70
  11. CCjon
    CCjon Gypsy Rider Supporter
    Apr 29, 2007
    1,199
    Under the Texas Sun
    RedStar,
    DMC sells the connections you need for the front upper strut mount for a KLR. I have one, it works great.
    Don't know about it fitting an oversize fuel tank though. Ask them.
    #71
    NikoRedStar and BigFatAl like this.
  12. NikoRedStar
    Aug 9, 2011
    15
    Did you you also purchase the subframe, or just the upper front mount? Do you know of anyone else that makes them and can share some ideas? I talked to DMC today. Researching around
    #72
  13. NikoRedStar
    Aug 9, 2011
    15
    Have any of y’all ever attempted to build a sidecar from the complete rear end of a Gen 1 klr650 frame/rolling chassis? Essentially cuttting off front half and mount to the frame?
    Seems like a decent idea since the swing arm, suspension, brakes, lighting, wiring, mud guard, and ability to attach luggage is all there...
    #73
    brstar likes this.
  14. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,691
    Contact Claude Stanley at Freedom Sidecars .
    http://freedomsidecars.com/
    #74
    NikoRedStar likes this.
  15. NikoRedStar
    Aug 9, 2011
    15
    Thanks BigFatAl,
    I did talk to Claude a while back. He gave me great insight and let me know just how crappy these velorex mounts can be, but how to “fix” them. He also gave me the confidence that I can solve (most) of my problem with an upper front mount. Using solely the Velorex mounts currently. However, he said he didn’t want to just make a part and throw it my way and hope it works. He said he’d help if he could see it in person. I’m half a continent away so that probably won’t be happening. I want to get a DMC, but not sure how to make it work without having a stock tank...and they sure are pricey. If I could just see how they mounted I could wrap my head around it a bit better. Anyone have a pic?
    #75
    BigFatAl likes this.
  16. NikoRedStar
    Aug 9, 2011
    15
    Can you send a pic of where the upper front mount, mounts to frame beneath the tank? Would really appreciate it. Thanks for your insight.
    #76
  17. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    18,166
    Your imagination.
    :fpalm
    #77
  18. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,691
    I will take a pic of mine ( DMC) top mount on a stock tank and send it you.
    ALSO my son works at DMC,if all you need is a top mount I can see if he can get me a deal on one and pass it on to you.
    #78
  19. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,691
    DMC Mount
    #79
  20. BeezaJohn
    BeezaJohn Been here awhile
    May 20, 2011
    164
    Sth Aust
    Thought this was Leigh's thread. :*sip*
    #80
