Smartphone as navigation device and durability
Discussion in 'Mapping & Navigation' started by serrge, May 15, 2019.
  1. Jdhuff
    Jdhuff RAT BRAIN
    Aug 1, 2013
    160
    Mississippi
    I have 48k miles on my iphone 6 with a ram 6" handlebar mount. It slung out of the mount twice on some really bone jammer hits. Luckily the charging cord held it. I use a Lifeproof case. They rock.
    #21
    JSL and BobcatSig like this.
  2. Addapost
    Addapost Been here awhile
    Jun 20, 2016
    968
    Massachusetts
    I have 3200 miles (about 1200 off-road) on an iPhone 6s in a lifeproof case mounted to my handlebar with a Ram mount. No issues. I'm using it to do the MABDR and TAT this summer.
    #22
  3. DCrider
    DCrider Live from THE Hill
    May 7, 2008
    11,109
    Washington, DC
    Read the Kyocera phone thread and several others on this topic and beyond.
    #23
    ohgood and BobcatSig like this.
  4. BobcatSig
    BobcatSig 4th gear singletrack
    Aug 15, 2014
    5,988
    Puddle Town, PNWet
    I'm tempted to run my iPhone 6 as a non-cellular, stand-alone GPS. That would preserve my iPhone X and save me from having to shell out nearly $500 for a Garmin Montana 680t.
    #24
  5. markbvt
    markbvt Long timer
    Sep 26, 2007
    4,757
    Georgia, Vermont (that's one town, not two states)
    Definitely doable. Scenic and OSMand are good apps. Screen brightness may be an issue in direct sunlight though.
    --mark
    #25
  6. BobcatSig
    Aug 15, 2014
    5,988
    Puddle Town, PNWet
    Valid point. I've come to use both Gaia GPS for following tracks and recording tracks. I use Avenza some, as well.
    #26
  7. SoccerNerd
    SoccerNerd Adventurer
    Sep 13, 2015
    40
    Montreal, Canada
    I swore I'd not got through another season without a dedicated GPS but lots of people here think a smartphone is the better way to go. The issue for me is rain. My Samsung S5 is water resistant but when the port detects moisture it stops charging and drains in a matter of hours even with the screen turned off. It's a constant struggle and source of anxiety to keep it charged when touring. Any suggestions?
    #27
  8. webmonstro
    webmonstro A Aventura Continua....
    Jul 21, 2008
    1,292
    Portugal
    Round magnetic USB cable . Silicone the adaptor on the fone side
    #28
  9. ohgood
    Sep 21, 2010
    10,361
    alabama
    buy extra batteries. no drama, no cords, easy peas
    #29
    Albie likes this.
  10. scootertrog
    scootertrog Jedi Fart Master
    Mar 26, 2011
    2,106
    Springfield, MO
    Just got back from a 1,000 mile trip using the Kyocera Duraforce Pro. Mounted on my handlebar in a SlipGrip cradle on a RAM ball/arm. Ran Guru Pro and TomTom Go apps. Everything worked perfect, even in the rain. One day, there were a few minutes that the screen was a little hard to read due to the sun, so just held my hand over it or leaned body over it for a couple seconds, no big deal. Starting with a full charge at the beginning of each day, the battery wouldn't get down to 20% for a good 5-6 hours. The el cheapo Bikemaster USB charger port had no trouble getting it up to nearly full charge, never needed to plug it into my main USB port.
    #30
    DelHess likes this.
  11. DelHess
    DelHess Been here awhile
    Nov 29, 2011
    644
    Millersville, PA
    i made a nice cordless charger mount with an xgrip and a qi charging puck glued on, and i think i may not bother with my zumo anymore. the thing i like about the gps is i could leave it on without a route and see the next corner or two whenever i looked down. is there an app that works that way? in other words, displays your position, rotates to direction of travel, and can be zoomed in and out, all without a route loaded? it would be a plus if it panned like a gps, not just a map view, but that's not a dealbreaker.
    #31
  12. scootertrog
    Mar 26, 2011
    2,106
    Springfield, MO
    ^ Every nav app out there should show your position and the road you are on, in real time, wether you have a route loaded it not
    #32
    JSL and DelHess like this.
  13. DelHess
    Nov 29, 2011
    644
    Millersville, PA
    thanks @scootertrog. i guess i had a blonde moment. only nav app i use (other than google maps) is osmand and i now remember how to make it will rotate to direction of travel, just have to find the setting.
    #33
    scootertrog likes this.
  14. SoccerNerd
    Sep 13, 2015
    40
    Montreal, Canada
    Thanks for the tip. I've just bought one plus a battery pack at Amazon.
    Just to be clear, do you mean dielectric grease or silicone caulking, which would make the adapter permanent. I understand the concept but the two options are quite different.
    #34
  15. SoccerNerd
    Sep 13, 2015
    40
    Montreal, Canada
    Because the cord description indicated you can't do data transfer through a magnetic connection (only for charging), so I don't think the permanent install is desirable.
    #35
  16. DelHess
    Nov 29, 2011
    644
    Millersville, PA
    #36
  17. SoccerNerd
    Sep 13, 2015
    40
    Montreal, Canada
    #37
  18. webmonstro
    Jul 21, 2008
    1,292
    Portugal
    I use RTV Liquid gasket . I just transfer by WiFi . You can still pull it out in a pinch with your finger nail . Just a little around the base of the plug . If the connector is on the bottom of the phone you may not even need it
    #38
  19. SoccerNerd
    Sep 13, 2015
    40
    Montreal, Canada
    Thanks for this. I ended up picking up a Kyocera Duraforce Pro on eBay for $50 and will use that as a dedicated GPS device, so I don't mind gluing the adapter in, especially if it solves my main problem.
    #39
  20. Tripped1
    Tripped1 Smoove, Smoove like velvet.
    Aug 6, 2009
    53,311
    Andalusia
    Nothing you can't do with WiFi in my experience anyway.
    #40
    petertakov likes this.
