Snowmobile Engine in a Dirt Bike
Discussion in 'Some Assembly Required' started by ScottyWarpNine, Aug 22, 2018.
  1. ScottyWarpNine
    ScottyWarpNine Where's the trail?
    Aug 15, 2015
    148
    NE Ohio
    I'm putting a snowmobile engine in a dirt bike. 290cc, 2-stroke, 2 cylinder, Kohler.
    Frame is a 1984 Honda XR200R.
    The secondary variator pulley and a countershaft with the front sprocket is gonna go right there.
    I'm looking for a project name. I'm thinking "Red Snow" or "Satan's Sled"
    Discuss.
  2. 9Realms
    9Realms Drawn in by the complex plot
    Jul 23, 2010
    6,027
    Central Minn.
    You'll poke your eye out!
    I mean, it's going to go like hell, and be a danger to children, the environment and small animals.
    COOL :clap
  3. NorthernTraveler
    NorthernTraveler Long time Adventurer
    Jan 1, 2009
    731
    The Big Mitten
    My ARMY recon motorcycle in 1977 was a Rokon RT-II.
    It had a Sachs 340cc single snowmobile engine with the belt/clutch setup.
    Pulled out of the bottom end and just kept going. Faster than hell. 80 or so.
    Good luck!
    PS - I have an 84 XR200 chassis around here.... made to engine mounts to use the standard 2 valve engine - the 4 valve was POS!
  4. Tanshanomi
    Tanshanomi Your Favorite Uncle Supporter
    Jul 22, 2009
    2,889
    Heart of America
    I have toyed with the same idea for years. Mounting the driven pulley will take some serious frame fabrication. Bravo to you for taking on the challenge!
  5. XR4EVER
    XR4EVER 919 excuses to ride!
    Aug 29, 2012
    1,302
    Post Falls, ID
    :lurk
  6. Luke
    Luke GPoET&P
    Aug 25, 2004
    5,137
    Beaverton, OR
    2nded. That's a great name for this.
    :lurk
  7. MacNoob
    MacNoob piney fresh
    Jun 2, 2010
    2,791
    The mosquito-y Center of Canada
    :lurk
  8. fast1075
    fast1075 Not a Lemming Supporter
    Dec 28, 2013
    2,007
    Flaw'da
    #8
  9. Fast Idle
    Fast Idle Since the Sixties Supporter
    Nov 9, 2012
    3,083
    The Great Land
    That will be a fun project! Better have some good brakes. :photog
    No hijack intended here, I had a bike with snowmobile torque converters once.
    Had two Suzuki 500 Titan motors with the transmissions cut off. Got it on a trade but never rode it. It needed new cylinders and I couldn't afford them so I traded it off a few months later. Here we go with the 20/20 hindsight again.:baldy
    #9
  10. fast1075
    Dec 28, 2013
    2,007
    Flaw'da
    It needs chambers, radical ports and a pair of lectrons! and some Klotz Green Label for the good smell!!!
    #10
  11. ScottyWarpNine
    Aug 15, 2015
    148
    NE Ohio
    I'm calling the lower engine mount done. I still need to make some sort of a mount for the top of the engine that bolts to the head. I'm going to try to mount the starter motor under the engine inside the mount, but if I can't do it I'll just ditch it. I was thinking of running without a battery anyway.
    Before anybody says anything, I'm definitely not a professional welder. This was done using a cheap Harbor Freight stick welder. They're ugly, but it seems pretty strong. Once everything is fabbed up, I think I'm gonna paint it all with red bedliner.
    That just looks right, doesn't it? I finally have a use for this crappy old CB750 tank. I didn't put the Punisher decals on it.
    #11
    smilin jack, JagLite and FR700 like this.
  12. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    8,536
    Anchorage Alaska
    One thing I have learned about welding, the more I do, the better I get with my grinder! :imaposer
    #12
  13. bk brkr baker
    bk brkr baker Long timer
    Jul 19, 2006
    10,533
    The Bluegrass
    Ted Wilkins hillclimber. I saw Ted run many years at the Devil's Staircase in Ohio.
    #13
    smilin jack, h0lger, jays100 and 11 others like this.
  14. dirt hokie
    dirt hokie Long timer
    Oct 3, 2007
    2,296
    Eastern shore of MD
    a welder and a angle grinder is all anyone needs to achieve the impossible.
    #14
    FR700, Junglejeff1 and JagLite like this.
  15. ScottyWarpNine
    Aug 15, 2015
    148
    NE Ohio
    I just bought a used Hobart Handler 140 MIG welder, so future welds may be slightly prettier.
    #15
  16. fast1075
    Dec 28, 2013
    2,007
    Flaw'da
    A 40 grit flap disc for your angle grinder would go a long way towards good surface prep.
    #16
  17. fast1075
    Dec 28, 2013
    2,007
    Flaw'da
    That is one wild hill climber!!! Did it burn nitro? Love me some 2 smokes!
    #17
  18. jimroid
    jimroid Long timer
    May 14, 2013
    1,102
    Pisgah Forest,N.C./USA
    Good luck, I am an engine transplant kind of a guy . 4756F558-6232-4173-8347-847017A38D74.jpeg
    #18
    JAGwinn, smilin jack, h0lger and 9 others like this.
  19. gmk999
    gmk999 ____ as a Rotax
    May 2, 2011
    5,188
    New England
    Will it reverse?
    #19
  20. more koolaid
    more koolaid Been here awhile
    Nov 5, 2015
    474
    Bel Air Md.
    "Ted Wilkins hillclimber"
    Is it me or is that motor upside down?
    #20
