Snowmobile Engine in a Dirt Bike
Discussion in 'Some Assembly Required' started by ScottyWarpNine, Aug 22, 2018.
  1. Tanshanomi
    Tanshanomi Your Favorite Uncle Supporter
    Jul 22, 2009
    2,889
    Heart of America
    Never used Castrol R myself. I've been a Golden Spectro user since my very first two-stroke.
    #41
  2. sieg
    sieg Wearing out tires......2 at a time, day after day. Supporter
    Jul 9, 2008
    7,887
    Southern Illinois USA
    I always use bean oil in my RZ 350 and I have the pump out put turned up, with the smoke and smell it turns heads. Smokey, smelly exhaust saves lives. :imaposer
    #42
    smilin jack and cprbusa like this.
  3. lesman
    lesman Live easy, Brake Hard
    Sep 7, 2006
    4,023
    Baja Okahoma
    When I was in high school . There was a kid who always smelled like castrol. He usually finished last. I always liked the smell of Castrol 2 stroke.
    It was always a purpose driven smell. If you smelled gear lube. You knew it was a car guy with a blown tranny or rear end. When you smelled bean oil you knew it was a moto crosser or perhaps a flat tracker with no silenced chambers (actually had one flat tracker in high school, he was bultaco rider). Bean oil meant to be loud and proud.
    #43
  4. fast1075
    fast1075 Not a Lemming Supporter
    Dec 28, 2013
    2,007
    Flaw'da
    I had Pursang that tried to kill me on multiple occasions. That thing was like a rank bull, it didn't like anyone on it. I sold it. The first time the new owner took it to the track, it broke his leg. Rank Bull.
    #44
    JagLite and cprbusa like this.
  5. ScottyWarpNine
    ScottyWarpNine Where's the trail?
    Aug 15, 2015
    148
    NE Ohio
    I think I'm going to have to turn the engine upside down to fit the secondary clutch. It is slightly too big to fit in line with where I need the front sprocket to be, and I don't want to add another countershaft to the equation. Problem is I either need to chop the frame to go around the single carb, or come up with a dual carb setup, which would mean custom manifolds. Also, I don't really like the idea of the airfilters right behind the front wheel to begin with, but I do like the straight line that the exhaust would go through around the rear shock and under the seat.
    I'll have to look into the overheating in summer temps thing. I do know that sled engines have been used a lot in paramotors with success, so maybe I'll see what they're doing to keep them reliable.
    #45
    smilin jack likes this.
  6. sieg
    Jul 9, 2008
    7,887
    Do you realize that twin carbs may change the engines HP and torque characteristics? Like most probably less low end grunt, but on the other hand if the intake winds up longer because of it you may overcome that loss.
    #46
  7. ScottyWarpNine
    Aug 15, 2015
    148
    NE Ohio
    Yeah, at this point I'm only looking at it as a packaging solution to fitting around the existing frame tube. It seems like a fairly common modification on these sled engines, but without actually doing it I cannot know how it will effect the engine's power or power band, or how that will impact the amount of usable power I have with the variator.
    #47
    sieg likes this.
  8. Tanshanomi
    Jul 22, 2009
    2,889
    Heart of America
    I would think that at this point, a different/custom frame would be the lower effort option.
    #48
  9. ScottyWarpNine
    Aug 15, 2015
    148
    NE Ohio
    I think you're right. It shouldn't be too hard to chop the down tube and have it split above the intake.
    #49
    JagLite likes this.
  10. jays100
    jays100 Been here awhile
    Aug 1, 2006
    415
    CT
    #50
    Kegler and cprbusa like this.
  11. CDN Rick
    CDN Rick Canoodia Eh?
    Jan 8, 2015
    21,269
    Niagara, Canada
    My neighbor ownes this... he says it’s mine for $1800USD. I told him there are far cheaper ways to kill myself. Yet still i’m considering it.
    Note the rear sprocket size. Apparently it can be heard running from a few miles away.
    #51
  12. Tanshanomi
    Jul 22, 2009
    2,889
    Heart of America
    That's the problem with CVTs on bikes – the width. They are really tough to package cleanly in a bike chassis.
    #52
    Richarde1605 likes this.
  13. tinwelp
    tinwelp Professional Idiot
    Dec 5, 2010
    721
    Deepest Southern France
    NEVER try to turn right... :fpalm
    Unless you only like going in straight lines, run away.
    Cheers... Paul
    #53
  14. CRW
    CRW I dont want a pickle
    Oct 8, 2005
    915
    Cotati Ca. USA
    It the heater for the future side car haha
    #54
    CDN Rick and JagLite like this.
  15. XR4EVER
    XR4EVER 919 excuses to ride!
    Aug 29, 2012
    1,302
    Post Falls, ID
    Turn it 90° and run a shaft drive. :evil
    #55
    CDN Rick likes this.
  16. Tanshanomi
    Jul 22, 2009
    2,889
    Heart of America
    Then the problem becomes the distance between the two pulley centers, and the diameter of the driven pulley.
    #56
  17. CDN Rick
    Jan 8, 2015
    21,269
    Niagara, Canada
    I feel like safety probably isn't the #1 concern for people putting a sled motor into a bike. Jus' say'in... :lol3
    #57
  18. anonny
    anonny What could go wrong?
    Mar 20, 2007
    6,784
    Beautiful Revelstoke BC
    This guy is squeezing 600’s into dirtbikes, pretty sure he’s done 800’s too.
    #58
    dpforth likes this.
