So im thinking of scubadiving and made myself a snorkel for the R1200gsa
Discussion in 'GS Boxers' started by 2712, Jul 24, 2012.
  1. 2712
    2712 Been here awhile
    Jan 12, 2011
    374
    Belgium
    Hello all,
    Im going to iceland, and i am a bit worried to drown the bike, so i made myself a snorkel.
    I used a piece of pipe that i cut of the vacuum cleaner of a friends swimming pool vacume cleaner:rofl
    I alsow installed the touratech foam airfilter with that.
    First i connected the hoze to the snorcle under the right side, since it almost is a straight fit with wise... unfortunaly i had to cut off 2 inches of the oem snorcle, in order to make the hose being able to make a turn down under the tank and back up.
    I hope my pictures will make my horribel accent more understaindeble.
  2. aGremlin
    aGremlin Long timer
    Mar 26, 2012
    1,041
    New Zealand!
    From previous threads I'll offer you some advice.
    The position of the opening is going to let very little air into the hose (behind the windscreen). It also looks like it will affect your steering. The rough surface inside the tube is going to mess with the air flow...
  3. turbojugend208
    turbojugend208 Been here awhile
    Apr 6, 2012
    119
    denver
    please put the pipe down
  4. Stinkyb
    Stinkyb GS"eh" rider
    Aug 19, 2009
    370
    Grande Prairie
    Not to mention the harmonics of air being sucked across every flexible rib....
    I still dont understand taking your 25k motorbike with sophisticated string of electronics purposelythrough a river...and have fun:huh
  5. BitesTheDust
    BitesTheDust Been here awhile
    Aug 3, 2008
    203
    Fraser Valley, BC
    Interesting :huh
    Probably the most sensible thing I can offer up is - take lots of pictures :D
  6. wjherrick
    wjherrick Long timer
    Dec 23, 2009
    2,439
    NW US
    And send pic's! I'm sooooo jealous.
    Bill in OR
  7. 2712
    Jan 12, 2011
    374
    Belgium
    Ive been thinking about that, however, the end of the oem snorkel sits under/behind the tank with only an inch or 2 space left for air to be left in. On the GSA the airflow is already messed up by the huge tank and crashbars.
    I didnt lose any ability to steer, i guided the hose true the fork legs and then up from right under to left upper in a way that i can turn in any direction without the hose touching a thing. She only touches the right fork leg when turning all the way to the left, but i added some electric tape to the tube and the forkleg to prevent rubbing damage.
    Ive checked and checked and checked, im all clear on that one
    Lets not forget that i will remove the tube after i got back from my trip.
    Now that ive this hose, i didnt lose much power. It does wissle when i go up higher then 6000rpm.
    The reason why i didnt make the hose facing the riding direction next to the shield, is that then i would catch up way more dirt and bugs. And since im going to ride on volcanic ash/plume stone onderground for a month. Il do anything i can to avoid volcanic dust in my engine.:wink:
    Im adding a nylon sock to the end of the tube for chunks of debri, il add that as soon as i convinced a girl to donate one to me.
  8. bemiiten
    bemiiten League of Adventures
    Jul 10, 2003
    5,757
    Hamilton NJ.
    When your out in the middle of nowhere , turning back or going another way may not be a option. I doubt he wants to play submarine , but instead he's addressing a real shortcoming on what is supposed to be a adventure bike.
    #8
  9. on2wheels52
    on2wheels52 Long timer
    Jun 14, 2006
    4,128
    northern Arkansas
    A field expedient, if you will. I couldn't do a better job.
    Have a great time; a trip report in the works?
    Jim
    #9
  10. 2712
    Jan 12, 2011
    374
    Belgium
    +1
    Im not planning on submerging my gs in water at all!
    I do expect water that will be above the axel, maby even as high as the tire.
    If you go into water as high as the front tire, it will go great with the oem setup, until you drop it to the right side... water will be sucked in instantly leaving you stranded with a bike in the middle of the river that you have to PUSH out of the water... alone with some bad luck... i once tryd to push my bike upwards onto a steep driveway, impossibru! now imagine a riverbed with rocks and slippery mud..., im already crapping my pants:lol3
    My setup will hopefully give me some slack in case i drop it, the panniers will hold the bike up a little, and when dropping i might have 1 or 2 extra seconds to push the killswitch.
    I will feel safer on the bike with the setup than without.
    ps: a full field report will follow! with lots of pictures!
    #10
  11. 2712
    Jan 12, 2011
    374
    Belgium
    one question to the mechanics, can a mod like this lean out my engine?
    #11
  12. Lensgrinder
    Lensgrinder Long timer
    Aug 8, 2007
    1,533
    San Marcos, California
    I would think that if anything it would run a little richer, unless the computer compensates for it.
    There are others who would know more about how it calculates fuel/air mixture.
    I look forward to hearing about your trip and seeing photos.:lurk
    As a side note, looking at the joint between the snorkel and the hose, you may want to think about some heat shrink tubing over your electrical tape to make sure it doesn't start to unwind do to the elements.
    You don't need to hold the heat gun to close as too not damage the hose.
    Good Luck
    #12
  13. JimVonBaden
    Feb 11, 2005
    96,327
    Alexandria, VA
    This has been done before, with a different tube, but similar. The person who did it claimed no noticable difference unless at high RPM.
    I doubt it will hurt the bike, though you very well may notice a drop in mileage. I would make it removable for street only, and easily installed once off road.
    Jim :brow
    #13
  14. Big Daddy D
    Big Daddy D Been here awhile
    Nov 18, 2011
    409
    under the sea
    'Lean' betekent te weinig brandstof. Jij zal hoogstens teveel benzine verstoken.
    Ik zou ook een kapje meenemen als je buiten parkeert in de regen ;-)
    Foto's en RR worden verwacht natuurlijk! Succes!
    Verstuurd van mijn GT-P7510 met Tapatalk
    #14
  15. 2712
    Jan 12, 2011
    374
    Belgium
    Im thinking of getting a used undamaged airbox snorkel to swap when im at home doing work - home traffic:D
    #15
  16. STUFF2C
    STUFF2C We Ain't Left Yet!!
    Aug 12, 2004
    3,476
    O-lando
    Yeah what he said :huh
    #16
  17. Wallowa
    Wallowa Diver Down
    Nov 30, 2006
    6,095
    NE Oregon
    Hey, good job. It is after all your 'adventure' bike and you had the spine to make changes based on real world issues [riding alone then getting water into the cylinder and bending some very important parts!].
    As stated by others, perhaps you can find a position for the inlet to be in the air flow when you are moving, big bonus. Small thing, but you mention diving. Dive snorkels or any breathing tube/hose [regulators or surface supplied] should be smooth bored, laminar vs turbulent flow. To fine turn your set up I would find a smooth bore tube. I also use an oiled air filter, UNI [from Oz], and it has a pre-filter foam sleeve [fits over distal end of air horn] which would really help with any fine dusts and prolong the effectiveness of your air filter. I assume you carry extra oiled filter foams in a zip-lock bag to change out on the road if necessary. Not mentioned, but the OEM paper filters stop working if they get wet, oiled filters can keep going if wet.
    FYI.. UNI says that the restriction of the pre-filter reduces Hp by about 5 Hp. I have never noticed the loss of power.
    Lastly my '07 GSA air horn does have incoming air flow even though it is sandwiched between enging and gas tank...but without a snorkel, it can catch any splashed puddle water or suck it up if bike is dropped in water.
    Enjoy your adventures! :wink:
    #17
  18. cratliff
    cratliff Adventurer
    Jun 3, 2012
    70
    Southwest VA
    wtf........:D
    #18
  19. JustKip
    JustKip Long timer
    Apr 28, 2007
    9,191
    Fresno, CA
  20. cobrags
    cobrags Lost ADVR
    Jun 16, 2009
    667
    SE MN, On the road less traveled
    There we have it!
    Snorkel works and get a clean bike!
    #20
