So Show US Your 4x4 Adventure Then!
Discussion in 'Adventure On Four Wheels' started by Bovino, Oct 14, 2019.
  1. Bovino
    Bovino Been here awhile
    May 11, 2013
    804
    Spain
    I always enjoyed taking my Suzuki Vitara to the old Sahara:
    Now it's mostly tame stuff in my Hilux. Like here, Picos de Europa in northern Spain:
    Or some sandy tracks in Poland:
  2. eatpasta
    eatpasta Lawnmower Target
    Jul 5, 2006
    16,059
    Santa Barbara, Ca
    My first car - had it since I was 15 and yes, absolutely been an adventure.
  3. jkam
    jkam Nomadic Man
    Jul 8, 2001
    8,573
    Somewhere out there
    I grew up in Tucson. My first vehicle was a Bronco.
    I was pretty crazy then, it lasted almost a year.
    I had a nice 4wd van I fixed up. It was fun but I couldn't stand up inside, so sold it for the RV i have now.
  4. moosey
    moosey Superconcentrated Bitch
    Jun 2, 2002
    156
    Spooner, WI
    i started off on 2 wheels (sold):
    Then I added a wheel (2005 Triumph Tiger with DMC sidecar)
    Finally to a 2014 Jeep Rubicon with an Ursa Minor J30 top:
  5. jkam
    jkam Nomadic Man
    Jul 8, 2001
    8,573
    Somewhere out there
    After the Bronco I got a big truck to help keep me from rolling so often.
    It was big alright, heavy too.
    To really help to keep me in check, I put a cabover camper on it.
  6. jkam
    jkam Nomadic Man
    Jul 8, 2001
    8,573
    Somewhere out there
    For fun, I added a 48 CJ2A to my growing fleet.
    This was way more fun than the F 250.
    By then, I had learned not to roll over.
  7. MrPulldown
    MrPulldown Long timer
    Aug 18, 2009
    8,285
    Truckee
    RFVC600R, tjzondrz, DyrWolf and 3 others like this.
  8. Chillis
    Chillis Long timer Supporter
    Aug 25, 2005
    13,429
    Las Vegas
    #8
    Redoubt, RFVC600R, oic and 5 others like this.
  9. Chillis
    Aug 25, 2005
    13,429
    Las Vegas
  10. Chillis
    Aug 25, 2005
    13,429
    Las Vegas
  11. Chillis
    Aug 25, 2005
    13,429
    Las Vegas
  12. gmk999
    gmk999 ____ as a Rotax
    May 2, 2011
    5,134
    New England
    Had a 3-b in HS ('53).. still can't smell Bondo today without thinking of that thing..and smiling
    #12
    scarysharkface likes this.
  13. Tallbastid
    Tallbastid Stay Grateful Supporter
    Apr 5, 2011
    9,873
    Vermont
    Assuming this is your truck, can you give us some more information on this build?
    #13
  14. MrPulldown
    Aug 18, 2009
    8,285
    Truckee
    06 Nissan Frontier Nismo King Cab 4wd. 6 speed manual transmission. 4.0L V6
    Factory rear locker on a Dana 44 variant. Armored aluminum diff cover.
    Stock size 265/75r16 (32") tires.
    Bilstein 5100 in front set at 1.5" of lift. Custom shock top spacer for another 1/2" of lift.
    Total Choas front Upper Control arms.
    Bilstein 5125 (softer than 5100) in rear. Firestone airrite airbags for variable lift and load control.
    Lokka auto locker in front diff. 3.69 gearing
    Shrockworks Engine Skid, Transfer case skid, Gas tank skid.
    Custom sliders.
    Extra hook in front and hidden hitch trailer hitch as recovery point in rear with shackle receiver.
    You can find me at clubfrontier.org @nissan4life
    #14
    VDG, FLYING EYEBALL, A.T. and 11 others like this.
  15. Tallbastid
    Apr 5, 2011
    9,873
    Vermont
    Beautiful build, very tastefully done. I have the same truck but in CC, this post may cost me money.
    #15
    FLYING EYEBALL likes this.
  16. MrPulldown
    Aug 18, 2009
    8,285
    Truckee
    The truck is a somewhat DD, so I didn't go CRAZY. Also money is a limiting factor for me. I also did not want to really stand out. In my teens and 20s="look at me". In my late 30's when I first got the truck I wanted to be as low key a possible. There is indefinitely an order of things to upgrade/protect, based on how hard you plan to wheel your truck. Do you have a pro4x/nismo? First mod should be steel engine skid, even if you have the factory one. Love to talk this stuff.
    #16
  17. OhBoy
    OhBoy Got Out
    Mar 30, 2009
    1,871
    Merrimack Valley, NH
    #17
  18. Tallbastid
    Apr 5, 2011
    9,873
    Vermont
    Yeah, I'm in the same boat. Used to own a fairly built TJ that was way more offroad oriented than anything I'd drive today. My '16 Frontier has a levelling kit and 32" all terrains, that's about it. It's not a Pro4X but does have the 6sp M/T which is just awesome. I'm not likely going to wheel this truck, I just like tinkering and seeing what others do to their Frontiers. I think the truck is undervalued in general and has proven reliable from what I've read up on it. If/when I do something I'd likely add a motor skid/locker/A-arms to replace the spacers PO installed, but lots of other things to take my money first. :D
    #18
  19. MrPulldown
    Aug 18, 2009
    8,285
    Truckee
    Now a days I would rather have a auto than a manual. Pretty hard to wheel/rock crawl a manual. Other 4 wheel non 4wd adventures from last couple of weeks. Dump run. Pile #6. You can see how wavy my sliders are from bashing on rocks. I did not use DOM tubing. Also passenger side gets twice as many hits as driver. I have some shrockworks extended type sliders ready to go on. But I have been stalling due to the fact that those have very noticeable look. ANd I want to go low key.
    Wood haul. That is probably 2000lbs in the bed with the camper shell and the tongue weight of the trailer. Those airbags make the truck a lot more capable. The tires where the weak point here.
    #19
  20. scarysharkface
    scarysharkface Faking it/Making it
    Nov 22, 2005
    14,497
    Indiana
    Had a Jeep that I loved dearly. Took me/us to some interesting places.
    Sold it to buy the R1200GS. Bought a used Subaru, then a used Lexus RX300 and now have an Xterra that I kind of love. Replaced the GS with a WR250R and will be hauling it to exotic locales on the back of a van.
    John
    #20
