So we've all heard/seen the 650 xchallenge...let's see your XCOUNTRY!
Discussion in 'Thumpers' started by Olas, Dec 3, 2007.
  1. ranex
    ranex Adventurer
    Feb 21, 2015
    24
    Spain
    Nice day in Spain....
    Defender63, DGR, Bli55 and 4 others like this.
  2. leafman60
    leafman60 Long timer
    Aug 14, 2005
    3,974
    Ok Ranex. Great pics. Please educate us on what we are seeing?? Where is that?
    cgguy09 likes this.
  3. ranex
    ranex Adventurer
    Feb 21, 2015
    24
    Spain
    This is the natural park of Duraton River in Guadalajara. The third photograph is the monastery or Nuestra Señora de los Angeles de la Hoz and the fourth photograph is San Frutos hermitage.
  4. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    1,977
    Герма́ния
    I wish it wasn't 1900 kms away from where I'm sitting :(
  5. 3dogrider
    3dogrider Been here awhile Supporter
    Oct 24, 2013
    135
    Salida, Co.
    gG
    Glad you like my screen. I'll try to get a photo of how I mounted it. Mine too, touches the turn signal but has not been a problem. Thanks,
  6. lewiss66
    lewiss66 Been here awhile
    Jan 22, 2008
    484
    French Alpes
    Great part of the trip in the Alpes:
  7. leafman60
    Aug 14, 2005
    3,974
    ranex likes this.
  8. 3dogrider
    Oct 24, 2013
    135
    Salida, Co.
    20160605_175850.jpg 20160605_175557.jpg 20160605_175906.jpg Sunbrother, This looks like a flimsy setup, however, it works great. Did part of the TAT last fall and other dirt roads around here without any issues. Let me know if this helps. Thanks
    keepshoveling likes this.
  9. sunbrother
    sunbrother Been here awhile
    Feb 22, 2010
    127
    That helps me a lot...I have mine different position right now...but I am going to adjust like yours....thank you so much.
  10. 3dogrider
    Oct 24, 2013
    135
    Salida, Co.
    put some locktite on the mounting screws. Mine came loose first time out.
  11. Kalts
    Kalts Adventurer
    Oct 4, 2010
    20
    Estonia
    I have seen two posts which talk about making the al. subframe M6 holes pass-through and using bolts'n'nuts with big washers. One from Colebatch and another here. It is straightforward for the two rear holes but the front ones would cut straight into the weld of a cross piece which supports seat lock. I do not see pass-through holes in this picture either, maybe were drilled out later?
    I am a bit concerned about structural integrity of the subframe as the welds (or the nearby areas to be precise) are the weakest. Would the drilling through the welds and shaving the cross piece to fit big washers weaken the subframe? Drilling through the middle of the pipe will not weaken the pipe much, that's common knowledge. But it is a bit more involved in this case...
  12. tbarstow
    tbarstow Two-wheelin' Fool Super Supporter
    Jul 9, 2007
    5,070
    Mesa, AZ
    Just drill and tap them to 8mm or even 10 mm holes with no issues.
  13. Dutchgit
    Jun 24, 2012
    1,977
    Герма́ния
    Erik from Hotrod welding uses steel inserts if the thread is farked. They are from Wurth but need a special tool to install IIRC.
  14. Jim Lad
    Jim Lad Adventurer
    Jul 22, 2013
    78
    Hampshire, UK.
    Dutchgit and keepshoveling like this.
  15. Jim Lad
    Jim Lad Adventurer
    Jul 22, 2013
    78
    Hampshire, UK.
  16. cgguy09
    cgguy09 Scientiæ Cedit Mare
    May 25, 2010
    1,514
    Astoria, OR
  17. Dorito
    Dorito Dreamer and Doer
    Jul 31, 2010
    7,368
    Maryland
    Anybody replaced the exhaust hanger on their SR Racing exhaust? My busted yesterday, and I didn't even fall on it! Somehow these zip ties actually got me home without melting.
    The muffler also has a tendency to want to rotate, so I think that the replacement will need a hanger with a better offset much like Akrapovic does.
  18. Adamskivan
    Adamskivan n00b
    Apr 30, 2015
    7
    North Vancouver
  19. Shmikes_1
    Shmikes_1 Perpetual Novice
    Jan 9, 2013
    54
    Ridey Bikes Moto
    Hey everyone... Maybe i'm just tired but can't seem to find a straight answer pon de tinternet... How much fork oil goes into the xcountry forks?? They're standard btw....
    Cheers
  20. Shmikes_1
    Jan 9, 2013
    54
    Ridey Bikes Moto
    Hey lewiss66, Nice vid... Where abouts were you... I'm taking the beast to the alps in august.
    Cheers
    Mike
