So we've all heard/seen the 650 xchallenge...let's see your XCOUNTRY!
Discussion in 'Thumpers' started by Olas, Dec 3, 2007.
  1. NZSpokes
    NZSpokes Been here awhile
    Sep 13, 2017
    418
    Auckland New Zealand
    You have removed the second return spring? Much better after that.
  2. underontop
    underontop Adventurer
    Jan 2, 2008
    79
    Nelson, NZ
    Second one ? I can't even see the first one. They don't seem to show up on the parts diagrams....where is the removable one ?
  3. DGR
    DGR G650X
    Oct 19, 2009
    519
    Netherlands
    @underontop , it's on the left side of the throttlebody. You don't even need to remove it, just unhook it.
    NSFW likes this.
  4. underontop
    Jan 2, 2008
    79
    Nelson, NZ
    Well that was an easy excercise ! Thanks Gents ! My refurbished shock with heavier spring arrives tomorrow.
    DGR likes this.
  5. ERU
    ERU Adventurer
    Nov 1, 2009
    79
    Bucharest
    Funny enough, i just did that last night, after job in the last minutes preparatios before trip.
    Albania here i came........
  6. NSFW
    NSFW basecamp4adv Super Supporter
    Feb 20, 2007
    24,747
    Burbank CA
    Is that just a matter of removing the seat and unhook the spring? Pls say so.
    tbarstow likes this.
  7. underontop
    Jan 2, 2008
    79
    Nelson, NZ
    Take off LH side cover . I unhooked one spring with two small screwdrivers. Easy.
    NSFW and tbarstow like this.
  8. NZSpokes
    Sep 13, 2017
    418
    Its easy to do. I did a quick turn mod to the throttle tube and now it really barks. Mind you i have a powercommander and custom tune.
    I saw on Bryce's page he was working on a X shock so that must be your's.
    NSFW likes this.
  9. tbarstow
    tbarstow Two-wheelin' Fool Super Supporter
    Jul 9, 2007
    5,039
    Mesa, AZ
    Left side of the throttle body. The RepRom has a pic of it, as does one if the G650X threads. Pop o e spring off and leave it. Reassemble motorcycle, resume riding with a less-than-PopEye right forearm.
    NSFW likes this.
  10. NSFW
    Feb 20, 2007
    24,747
    Burbank CA
    Simple enough but kicking myself for not getting it done 1800 miles earlier in the last 10 days.
    The folks at the store were wondering where I found the XCo.
  11. underontop
    Jan 2, 2008
    79
    Nelson, NZ
    The latest and possibly last hand-easing job has been to swap the oem clutch lever (and subsequent aftermarket adjustable one) for a "proper"
    OEM G650GS adjustable lever which has decent geometric leverage . Clutch action is now luvly & smooth & SOFT. Just like the throttle.
  12. NSFW
    Feb 20, 2007
    24,747
    Burbank CA
    Good to know. Thanks.
    Do you have the part number of the lever?
  13. underontop
    Jan 2, 2008
    79
    Nelson, NZ
    The BMW part is #32727688439. The knob on the end of my X's cable was minutely fatter than the cavity in the new lever, I drilled the cavity bigger to suit, and had to take a couple of swipes with a file across the flat of the lever where it slots into the the cheeks of the hinge on the mount. Took all of 10 minutes to swap levers.
    DGR and NSFW like this.
  14. computer_freak
    computer_freak Been here awhile
    Jun 23, 2016
    253
    Dutch
    My G650GS and X-Country are both from 2008. Both partly assembled in China. And the GS is smoother. My guess is that it's mainly the ECU mapping + heavier flywheel and heavier bike that smooths out acceleration and deceleration.
    The X-Country feels more twitchy and jumpy to me. Both characteristics have their advantages.
    The X-Country does have a very linear throttle curve. On the GS its very calm and tame up until I twist the throttle above 75% open and then it's like all the horses are let out of the barn. Like riding with V-TEC. The bike suddenly gets very aggressive. The X-Country doesn't have this.
    It's nice to see that you have both bikes and use both. I hardly use the GS and was thinking of getting rid of it, but I'm also thinking about keeping it as a Euro city-trip bike.
  15. NZSpokes
    Sep 13, 2017
    418
    I believe the X has a much smaller flywheel and stator. Not sure but I think the throttle body is bigger as well.
    Also the X are much lighter.
  16. computer_freak
    Jun 23, 2016
    253
    Dutch
    I have to redact what I said. I mentioned that the X is not as smooth as the GS. Now I have been having fuel issues for a couple of weeks. It just wasn’t as smooth as I wanted it to be. At low RPM it would be a bit hesitant. Tried injector cleaner but it didn’t work fully.
    So yesterday I climbed up to 2770 meters. Bike was fine. Went down and the bike lost power constantly. Bucking like a mule that was angry. So I coasted to 1900 meters and since it was getting dark, I found a place to sleep.
    Next morning still the same issues. It even had issues keeping idle. Perhaps because of the cold weather. Drove it carefully at 50kmh in second gear because it was happy there. After 20 kilometers, the bike was great again! I was at a slight lower altitude.
    But later on I climbed to 2300 meters and the bike stalled. Red light on the dashboard, o shoot. But it started right back up again.
    Fixed it on the mountain summit. The X is smooth as butter again. Guess what it was. Free fix, no parts needed and only basic hand tools required.
  17. underontop
    Jan 2, 2008
    79
    Nelson, NZ
    Let me see now, arr...pocket of air trapped in the spark plug cover expanded at altitude and popped the lead off ?
  18. computer_freak
    Jun 23, 2016
    253
    Dutch
    Hint; The fix had nothing to do with the spark plug, injector or fuel filter. The air box stayed on during the repair.
  19. NZSpokes
    Sep 13, 2017
    418
    Clogged tank vent?
  20. DGR
    DGR G650X
    Oct 19, 2009
    519
    Netherlands
    @computer_freak , good to hear you're enjoying your bike out there! :ricky
    Was it a loose battery terminal?
    You could also try the Sol2be accelerator module, costs very little. It smoothed things out for me because its not running as lean anymore.
    computer_freak likes this.
