So we've all heard/seen the 650 xchallenge...let's see your XCOUNTRY!
Discussion in 'Thumpers' started by Olas, Dec 3, 2007.
  1. computer_freak
    computer_freak Been here awhile
    Jun 23, 2016
    271
    Dutch
    Free ice cream for @DGR ! I feel like the injector cleaner was a placebo. And all the altitude stuff had nothing to do with it. All I had to do was tighten the positive terminal. Easy fix on the top of Col d'Izoard.
    While working on the bike I also spotted another X-Country! A black one from Germany. I was very excited but he just said ha and rode on :(
    NSFW and DGR like this.
  2. NSFW
    NSFW basecamp4adv Super Supporter
    Feb 20, 2007
    25,269
    Burbank CA
    Glad it’s fixed. That’s the 2nd XCo died on the top of the Alps.
    The good news was an easy fix and continued their journey.
  3. underontop
    underontop Adventurer
    Jan 2, 2008
    93
    Nelson, NZ
    Well I have a dead bike. Hasn't moved from the shed since I last used it & turned off about a week ago. Turn key on, nothing. Battery 12.8v,
    leads tight. Took back off dash looked at ignition switch connector, no power there. Looked at fuses. 15amp fuse for starter relay & indicator lights has blown. Replaced it. Nothing. Thought I'd ask here before embarking on "learning to use a multimeter 101"
    Update. new fuse has blown. What are the chances of a crook starter relay ?
    Update. Put another fuse in, got a few seconds of "A65" and various dash lights with the key OFF. So, one ignition switch removal operation about to commence.
    Update. Plastic bottom half of ignition switch is sitting on the kitchen table. What a prick of a thing to take to pieces. The soldered wire connections are good.
  4. computer_freak
    Jun 23, 2016
    271
    Dutch
    I blew that fuse when I messed with the accessory socket next to the oil tank. Bike did nothing. Perhaps something to look for.
  5. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    2,006
    Герма́ния
    Check the wiring loom where it goes around the airbox on the right side of the bike. Also where it dives under the front mounting points of the rear subframe.
  6. underontop
    Jan 2, 2008
    93
    Nelson, NZ
    Loom is all fine .It seems like the ignition switch blew that fuse. With the switch out and the switch connector bridged everything is fine. Strange because I can't see any burn marks on the switch innards. Anyway, I have a simple on off Yamaha switch coming. I'm not going to have any more of that awful oem thing. I'll be in there with a Dremel tomorrow hacking that security bolt out.
  7. nordic1
    nordic1 Been here awhile
    Apr 30, 2015
    335
    The Natural State
    I just placed my ‘09 XCountry up for sale on the forum if interested
  8. NZSpokes
    NZSpokes Been here awhile
    Sep 13, 2017
    424
    Auckland New Zealand
    Did mine yesterday. The bolt is alloy so easy to get out.
  9. underontop
    Jan 2, 2008
    93
    Nelson, NZ
    Can someone please advise what this vacant screwhole in the airbox means ? The parts fiche show a large headed screw in there but no indication
    of what it does.......do I put a screw in there, or do I bog it up ?
  10. DGR
    DGR G650X
    Oct 19, 2009
    540
    Netherlands
    @underontop , Thats the point where Xch/Xmo owners mount their seat. The seatpan has a slot that slides under the large flat bolt.
    I think it's redundant on the Xco and can be left empty, but perhaps an Xco owner can confirm this.
  11. miniboxer
    miniboxer Been here awhile
    Jan 15, 2011
    104
    DGR is right!
  12. NSFW
    Feb 20, 2007
    25,269
    Burbank CA
    Mrs Merkel is giving me headache again. The ride has been great for vet 3 weeks until today.
    Here in Salzburg and the bike quit 3 minutes after I put a full tank of gas.
    It turns over and fires up for a second, then just cranking.
    My guess is chamber not getting any fuel. Possibly clogged up injector or fuel filter. It has about 17k miles. I could continue to trouble shoot but it’s dark and cold.
    I left the bike at a gas station about 5 miles from the hotel room. In the morning, take a taxi and see if there’s spark.
    I may end up staying here for another day.
    Thanks in advance.
  13. NSFW
    Feb 20, 2007
    25,269
    Burbank CA
    Who wants to guess?
    All is good again.
  14. bikerdude
    bikerdude Adventurer
    Aug 22, 2005
    16
    Does the ECU learn that it's getting more fuel and eventually cancel it out?
  15. sanjoh
    sanjoh Purveyor of Light
    Feb 13, 2007
    8,909
    ADVmonster, CFL, WNC
    Do you have any more info on the Yamaha switch? Got a broken key, no backup.....
  16. DGR
    DGR G650X
    Oct 19, 2009
    540
    Netherlands
    Not sure to what degree the ECU is able to compensate, but that is a possibility.
    However, before mounting it the bike would sometimes stall when cold. It's never stalled since then so there must be some effect remaining.
  17. underontop
    Jan 2, 2008
    93
    Nelson, NZ
    It's a generic simple electrical on-off switch with just two wires, no mechanical steering lock. Dr Google will find dozens that will do the job.
    It's suspended in the yoke hole by a threaded neck hanging onto a large washer which is silicon rubbered in place. A couple of crimps ....
    See this link for info ...https://www.trademe.co.nz/Browse/Listing.aspx?id=2304903162
    sanjoh likes this.
  18. underontop
    Jan 2, 2008
    93
    Nelson, NZ
    You put diesel in ?
    Javdet likes this.
  19. Dutchgit
    Jun 24, 2012
    2,006
    Герма́ния
    Looking at the smoke, that might well be a possibility.
    Javdet likes this.
  20. NSFW
    Feb 20, 2007
    25,269
    Burbank CA
    I made it to a disco fog machine.
    Diesel aaaargh. Diesel in CA is green nozzle. In EU it’s the opposite.
    underontop and Sparqq like this.
