1. eNewsletter Sign Up
So we've all heard/seen the 650 xchallenge...let's see your XCOUNTRY!
Discussion in 'Thumpers' started by Olas, Dec 3, 2007.
  1. computer_freak
    computer_freak Been here awhile
    Jun 23, 2016
    239
    Dutch
    I should stop posting messages at 1AM.
    cpallen and cyclopathic like this.
  2. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    7,427
    Non-plus Mitas e07 are not available in 130/80 only plus you will have to go to 140 if you want it.
    I'm running Sava mc60 front/E07 Dakar rear on my other bike in 110/80 140/80 and want to go to common size.. at least for rear.. will keep front as 100/90 is better off pavement and IIRC front rim is 2.0" not 2.5".
    Since the mc60 are no longer available I am thinking Anakee Wild/E07 Dakar f/r with tubeless kit.. will see
  3. cpallen
    cpallen Nearly Adventurer
    May 26, 2003
    1,728
    Panora, IA
    "Non-plus Mitas e07 are not available in 130/80 only plus you will have to go to 140 if you want it." - it's listed on the Mitas website - I should know later today what the dealer says. The part numbers are 24133 for the standard 130/80-17 E-07 and 24135 for the E-07+. I don't see a Dakar version listed in that size. Specs say (I haven't measured it myself) that the Xcountry front rim is 2.5" wide. The 140/80 is too wide for the 3.0" rear wheel (again, specs say IDK that personally). I'm going to stick to the OEM sizes if at all possible until I get to know the bike in it's standard form.
  4. computer_freak
    Jun 23, 2016
    239
    Dutch
    I have the E07 100/90 in the front and E07+ 130 in the rear. Good combination, works great.
    cyclopathic likes this.
  5. Red Sand
    Red Sand Been here awhile
    Jul 20, 2010
    416
    Atlanta area
    There is no yellow on mine
    It has removable rear foot peg holders
    It's a real hoot to ride!
    Zeus99 likes this.
  6. cpallen
    May 26, 2003
    1,728
    Panora, IA
    So then that would be the 1st generation - or in the USA, 2007 or 2008 model year.
    Red Sand and Zeus99 like this.
  7. cyclopathic
    Dec 23, 2007
    7,427
    Any suggestions on inexpensive (generic?) bigger windscreen?
  8. Zeus99
    Zeus99 Been here awhile
    Apr 3, 2015
    169
    Croatia
    Take a look at Givi A660
  9. waylongway
    waylongway madmax Supporter
    Dec 16, 2009
    4,049
    NorCal
  10. cyclopathic
    Dec 23, 2007
    7,427
    So does it really fit, have you tried?
  11. Zeus99
    Apr 3, 2015
    169
    Croatia
    If you're considering a windshield that small a good option might be Puig 0869.
    I have one on my Xco now.
    It's fantastic off road and I even prefer wind protection on road to the much larger Givi A660.
    Very cheap and very easy to install.
  12. cyclopathic
    Dec 23, 2007
    7,427
    Bike already has OEM windscreen I am looking at something bigger for winter.. like Givi 147A
  13. Zeus99
    Apr 3, 2015
    169
    Croatia
    That's cca 6cm taller than the A660 I was using.
    I think that's a very good choice.
    The A660 was directing the wind to the top of my helmet, creating a lot of buffeting and noise at speed.
    The extra 6cm would take care of that.
    The A660 comes with a kit for steel handlebars, that's too small for our aluminium bars so I had to get a set of adapters. It's probably the same for 147A.
  14. cyclopathic
    Dec 23, 2007
    7,427
    147A is for R1200R and should mount to stock bracket
    Zeus99 likes this.
  15. NSFW
    NSFW basecamp4adv Super Supporter
    Feb 20, 2007
    24,354
    Burbank CA
    I ended up getting the complete OEM kit.
  16. cpallen
    May 26, 2003
    1,728
    Panora, IA
    How stiff is the sidewall on the rear? And how do they work on wet pavement vs on (easy) trails?
    I have accumulated most of the parts for a maintenance marathon.
    Still waiting for spark plugs and the oil filter compartment o-ring.
    » Oil and filter change (10-40 Mobil 1 motorcycle oil). Switching to a Touratech flush drain plug.
    » Cooling System Flush
    » Replace Air filter
    » PM: Clean Throttle body and idle air actuator, install crankcase breather filter
    » Tires/tubes/rim strips. Check wheel bearings and spacers. Check/replace? Cush rubbers.
    » Brake pads front and rear
    » Brake fluid flush (Non-ABS)
    » Chain Maintenance, maybe swing arm bearing clean and repack?
    » Front fork service (oil change, seals seem to be fine)
    I have an XChallenge Skid plate and touratech luggage rack to install. I substituted my Krauser top box mounting plate for the touratech piece. Bolted right up with only a minor enlargement of two mounting slots. Not sure if the Aprillia hanguards will fit.
  17. computer_freak
    Jun 23, 2016
    239
    Dutch
    Don't know about the sidewall, I guess it's stiff? Works nice on wet pavement. At on point I was on a concrete section of the autobahn in the pouring rain, a rear wheel drive Mercedes had spun out but I didn't feel anything wrong with my bike. I have had some traction issues with slick asphalt in Mediterranean countries.
  18. cyclopathic
    Dec 23, 2007
    7,427
    Depends on which one (Dakar or not) you get but they both stiff moFu to the point that I will never install one with tubes again.
    They work fine on pavement as long as you don't run high (36psi+) pressure. People were running 32psi on S10 so for XCO I wouldn't go more than 28 rear/22 front.
  19. cyclopathic
    Dec 23, 2007
    7,427
    The r1200r kit? XCO kit with short screen? could you elaborate thnx
  20. NSFW
    Feb 20, 2007
    24,354
    Burbank CA
    i think there's only one kind for the XCo. it's that one.
    you'll see it in my recent EU RR.
    DGR, cyclopathic and Tritwin like this.
