So we've all heard/seen the 650 xchallenge...let's see your XCOUNTRY!
Discussion in 'Thumpers' started by Olas, Dec 3, 2007.
  1. NSFW
    NSFW basecamp4adv Super Supporter
    Feb 20, 2007
    24,835
    Burbank CA
    +1
    i got spoiled by TKC80s.
  2. cpallen
    cpallen Nearly Adventurer
    May 26, 2003
    1,884
    Panora, IA
    This is my first departure from TKC 80's and I'm not sure why. I hope they live up to their reputation.
  3. K12Pilot
    K12Pilot Without a Care
    Feb 12, 2009
    368
    The Rotten Apple
    Question for y'all.
    When did bmw switch from the rotax to the China motor?
    I am looking at an 09 X Country
    She needs some love been sitting a while, any advice?
  4. cpallen
    May 26, 2003
    1,884
    Panora, IA
    I think that it may have been in 2008, but for sure your (and my) 2009 is a Loncin Chineese manufactured motor. Doesn't seem to be an issue as far as I have heard. Mine is also a barn find that had been sitting for several years. Fresh gas and new battery and it started right up - but it needs at a minimum an oil change, brake fluid flush, and new tires before it's ready and safe to ride. I'm also replacing brake pads, air filter, and cush drive rubbers. Cooling system flush is probably also in order. Fork oil too. It has an aftermarket 14T sprocket and so I will inspecting that to make sure it's tight and greased, and will also service the swing arm bearings because IDK that it was done when the chain and sprockets were replaced a couple thousand miles and several years ago.
    Let's see a picture of yours and tell us more about it and it's history. And welcome to the G650X fold.
    K12Pilot likes this.
  5. K12Pilot
    Feb 12, 2009
    368
    The Rotten Apple
    I will get some pix up, waiting on some better detailed ones.
    it looks like she got a salt bath before she was put away 5 years ago.
    I am looking at this for my daughter, she is busting my onions to teach her to ride... ( I am reluctant from what I see on the road every day ((
    I tell her, I can teach you to ride, but not how to stay alive (. IDK what I would do if she got hurt..(
    Not new to the BMW gig, I have & had have several including the 450X. here are some of the current herd ;)
  6. computer_freak
    computer_freak Been here awhile
    Jun 23, 2016
    265
    Dutch
    My G650GS has a Chinese assembled motor, bought it at 55k kilometer, now at 80k kilometer and never missed a beat. Same with my X-Country but it is not at that milage yet.
    To be honest I'm more worried about all the Italian parts on the bike!
    waylongway, Dutchgit, DGR and 2 others like this.
  7. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    7,940
    +1
    Just had to replace rear rotor to pass inspection was 0.41mm below minimum at 21k.. oh wait it isn't Italian my bad.
  8. ERU
    ERU Adventurer
    Nov 1, 2009
    79
    Bucharest
    Wow a lot of activity in a very short period of time here.
    I second Duchgit, E07 Dakar is a very good tire, and not hard to mount.
    Also if someone is interested i have a original BMW windshield + subframe leftover from my brother bike, but i consider that the best windshield is that:
    https://www.radegarage.com/parts/ktm-690-fairing-kit/
    And is fairly easy to adapt.
    Zeus99 likes this.
  9. NSFW
    Feb 20, 2007
    24,835
    Burbank CA
    I would be interested on the windscreen.
  10. cpallen
    May 26, 2003
    1,884
    Panora, IA
    So as it turns out, the rear 130/80-17 is an E-07+ after all even though the non-plus was ordered. It has one hell of a stiff sidewall and I'm thinking that if I do get a flat I will probably never know it. I will certainly not be able to fix a flat trailside so I guess I'll just have to carry some Slime and pay the price of that afterwards. Or maybe just ride out on the flat. The front 100/90-19 is fine (non=plus, non Dakar) but I have never gotten a flat front tire on a motorcycle that I can recall. I'm not good/fast/hard enough of a rider to air down.
    I had a time of it taking the wheels off the bike. The axle nuts were so tight I had to use my motorcycle jack handle for extra leverage. One of the front axle pinch bolts was corroded and snapped off at the transition to the threaded portion. I was using a 1/4" drive ratchet and did not turn it the wrong way. Luckily, it looks like the bolts that secure the cover for the ABS sensor on the rear swingarm are the same (if it's on my non-ABS bike). I ordered two of them along with an OEM 15T XChallenge countershaft sprocket to replace the aftermarket 14t that's on the bike now. Hopefully the splines will be ok. There is also some wear on the spacers but I think they'll be ok for now. Should I lubricate them on reassembly? I can't recall. I may order some of the stainless steel Scheffelmeier Metall spacers at some point. The cush rubbers seemed a little - gummy? So I'll replace them but clean these up and save them for later.
  11. cyclopathic
    Dec 23, 2007
    7,940
    Once I had a flat on E07 Dakar rear on Strom.. only realized when bike started feel funny at 70mph; pulled over it had 10psi.
    Mitas sidewalls are really stiff I ran 32/32 on pavement on big bikes and 17/25 now on Superdual which about 35lbs heavier than XCo.. if you run more they became fiddly, loose grip and wear faster.. just saying.
    My 140/80 is coming soon haven't decided on front yet.. too bad AW doesn't come 100/90.
  12. cpallen
    May 26, 2003
    1,884
    Panora, IA
    They do come in 110/80 which should work just fine. However then you would have a radial front and a belted rear. IDK how significant that is.
  13. cyclopathic
    Dec 23, 2007
    7,940
    Ended up getting E-10 for $72 shipped so the same sizes like on Superdual. Also ordered 3M tape and valves $20 on Amazon to seal rims.
  14. K12Pilot
    Feb 12, 2009
    368
    The Rotten Apple
    Some pix for ya.
    She was sitting 5 years after a salt bath ((
    What say ya'll ??
  15. K12Pilot
    Feb 12, 2009
    368
    The Rotten Apple
    couple more pix 5F9B52A1-756D-4148-947B-8563DD960C67.jpeg FA51A858-D17D-47BC-A347-AE68E98623CF.jpeg 885506F9-ED8E-40C8-998C-787EDB1B9E7D.jpeg
    cyclopathic likes this.
  16. cyclopathic
    Dec 23, 2007
    7,940
    @K12Pilot you can probably remote most of it with penetrating oil/steel wool and elbow grease.. then touch-up with engine paint where needed and rust converter on steel parts.
    I would be more concerned with the electric connectors but then there aren't many which could have gotten exposed and dialectic grease is cheap. Hope you are getting a good deal there are not many of them left around.
  17. DGR
    DGR G650X
    Oct 19, 2009
    525
    Netherlands
    @K12Pilot , shame to see a bike neglected like that :( Hope you got a good deal on it!
    In the end it appears to be mostly cosmetic damage so a weekend's worth of touch-up work should go a long way.
    Enjoy it!:ricky
  18. K12Pilot
    Feb 12, 2009
    368
    The Rotten Apple
    I am thinking the same thing.. Although the header flange bolt over the starter & a couple head bolts look real crusty ((. take a look see, Also the fuel system is going to need a GOOD go through also. I am hoping for $12-1500 ish considering parts prices on Max and A&S.
    NSFW likes this.
  19. K12Pilot
    Feb 12, 2009
    368
    The Rotten Apple
    NSFW likes this.
  20. cyclopathic
    Dec 23, 2007
    7,940
    I just got mine inspected for registration and all she needed was rear brake pads and rotor. Pads were cheap (FA213 listed as direct replacement but FA208 will fit) ceramic from Sixity $8 shipped but unfortunately most places list rear rotor interchangeable with 650GS.. and it is not. Haven't found any china sources so EBC MD810C $130 it was. Still cheaper than $318 OEM.
    If you decide to get engine guards for new rider Twisted Throttle has SW Motech for $134 on sale good luck.
