So we've all heard/seen the 650 xchallenge...let's see your XCOUNTRY!
Discussion in 'Thumpers' started by Olas, Dec 3, 2007.
  1. Zeus99
    Zeus99 Been here awhile
    Apr 3, 2015
    179
    Croatia
    I also use endless chain, but had it fitted in a local shop.
    The guy remembered my family name on more than one occasion while fitting it
    Dutchgit and cyclopathic like this.
  2. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    1,930
    Герма́ния
    I don't know because I never changed those bearings but you best look at the parts sheet for it. There's the outer bearing races in there that might need doing too which, I assume, will be a major pain in the bum. (the ones in the swing arm)
    The "bolt" on the right is held in by 3 Allen key bolts which you will likely have trouble with to start. Hammer in a Torx bit that is very slightly bigger and fit new normal Allen head bolts later.
    Inside the large "bolt" is an Allen head which is pretty useless as there is no thread on the bolt. There is thread on the inside (M10 I believe) so you can fit a slide hammer (or make one out of M10 threaded rod)
    The left side does have thread, use penetrating oil on that and take it easy. There is a Helicoil inside the frame piece which does come out in some cases, hence the oil.
    The other bolt is on the bottom of the shock. It can be stuck in there with dirt, maybe even some rust. You want to undo the nut on it first before trying to undo the bolt (through the hole in the swing arm)
    Try to clean out the hole with compressed air and use penetrating oil there as well.
    The needles may fall out of their cages of the bearings so be aware of that in case you can reuse them.
    If there is no play in the swing arm, you might get away by just re-greasing them.
    lewiss66, DGR and cpallen like this.
  3. cpallen
    cpallen Nearly Adventurer
    May 26, 2003
    1,819
    Panora, IA
    Thanks you guys - maybe a job for next year. My X Co has only 13K miles of light street use so hopefully they will be ok, for now.
  4. sanjoh
    sanjoh Purveyor of Light
    Feb 13, 2007
    8,474
    ADVmonster, CFL, WNC
    Endless chain? You can't be serious. A staked master is just as reliable.
    cyclopathic likes this.
  5. DGR
    DGR G650X
    Oct 19, 2009
    511
    Netherlands
    @sanjoh I don't think it's about the chain, it's about forcing yourself to remove the swingarm and check/grease/replace the bearings.
    I checked the bearings somewhere around 20K km's. All the parts came out without a struggle and the bearings were fine. I remounted everything with a fresh dab of grease.
    I think washing the bike with a water hose instead of a pressure washer is good advice if you like your bearings to last.
    Dutchgit and cpallen like this.
  6. Dutchgit
    Jun 24, 2012
    1,930
    Герма́ния
    The whole point here is, as I pointed out, that you are forced to take out the swing arm to fit it.
    So you'd be an idiot not to put some grease in them bearings, which will save you unnecessary issues down the line.
    It's like wearing protective gear when you go out riding.
    The fact that you may have never benefited from it doesn't mean you never will need it.
    DGR, Zeus99 and Gravel Seeker like this.
  7. sanjoh
    Feb 13, 2007
    8,474
    Sounds like BMW logic. I would much rather grease bearings by choice.
  8. lewiss66
    lewiss66 Been here awhile
    Jan 22, 2008
    484
    French Alpes
    ok thanks Ard,
    I'll check that.
    Dutchgit likes this.
  9. gattointelligente
    gattointelligente Adventurer
    Jan 27, 2011
    19
    middle Italy
    Changed the hardened rubber seals. The brown one is VITON made for hight temp.
  10. gattointelligente
    Jan 27, 2011
    19
    middle Italy
    My spare parts supplier is closed because of COVID 19, here in Italy it is a hard challenge! So I have time for a general check up. Clutch dissassembled and checked. There is a faint groove on the metal disck in contact with the judder spring. Hope no problem. I should to remove the swingarm and grease/replace the needle bearings, but I dont want to have too many pieces wandering all around my garage.
    Zeus99 and DGR like this.
  11. cpallen
    May 26, 2003
    1,819
    Panora, IA
    Spent A few hours workining on the barnyard X Country. Installed the Staintune muffler recently purchased from a Facebook friend in Australia. Beautiful piece of work, but pretty loud. Also performed a cannisterectomy, and added the DIN plug under the tank that comes stock on the ABS bikes. Getting close to done and riding weather is right around the corner!
    Zeus99, DGR and cyclopathic like this.
  12. DGR
    DGR G650X
    Oct 19, 2009
    511
    Netherlands
    @gattointelligente , Nice to see people taking good care of their X bikes!:clap
    could you share some details and pics about that storage tube beneath the muffler and how you mounted it? Looks like a nice solution!
    I mounted a 6x50cm plastic tube (actually meant for drawings) to carry my tentpoles. On the picture below it's not mounted yet. Currently using velcro loops to tie it to the rack. It works but I'm not thrilled with it. I'm hope you found a better way to mount the tube :-)
  13. gattointelligente
    Jan 27, 2011
    19
    middle Italy
    @DGR Mine is a sturdy ABS pipe with a watherproof screw cap (there is a large O-ring in it). First I made a frame on the right side for a self made graphite case. Then I used a U-shaped steel pipe, from a bicycle ground-stand, to reinforce the wheel cover and licence plate support. I fixed it with the bolt of tre left grab handle. Here the iron ring supporting the ABS pipe. Thepipe bottom is fixed in a C shaped plate I put betwen the muffler pin support and the rear footpeg. The alluminium long plate should limit heating from the muffler. Maybe pics speak better than me!
    cpallen and DGR like this.
  14. DGR
    DGR G650X
    Oct 19, 2009
    511
    Netherlands
    Thanks for the pics and explanation @gattointelligente ! I love creative DIY solutions like this. Great job on the custom case :thumb
  15. Dutchgit
    Jun 24, 2012
    1,930
    Герма́ния
    On the subject of tent poles: You can get shorter element ones on Ebay or Aliexpress and such. Made out of aluminium or fiberglass.
    It's what I did as I was happy with my tent but not with the long poles as they didn't fit right in my panniers so I got different ones.
    DGR, Zeus99 and cyclopathic like this.
  16. Gravel Seeker
    Gravel Seeker Old, growing older.
    Apr 27, 2002
    9,099
    Dreary old Norway, dreaming of adventures past
    Too easy :thumb:lol3
    Like @DGR says, it's about the fun of creating something
    :scratch :type :hmmmmm :jjen :norton :wings :drink :chace:kat :jkam
    Dutchgit and DGR like this.
  17. DGR
    DGR G650X
    Oct 19, 2009
    511
    Netherlands
    Thanks, I like that idea. I'll have a look at the options. Even though I enjoy tinkering with luggage solutions, I prefer to keep things as simple as possible. Being able to pack the poles in the panniers would be a big plus. It's just one less thing that can go wrong.
  18. cpallen
    May 26, 2003
    1,819
    Panora, IA
    I have always packed my poles in the stuff sack with my tent, and then lashed the tent to my seat with the poles in a safe orientation so they wouldn't get bent.
  19. Dutchgit
    Jun 24, 2012
    1,930
    Герма́ния
    Well, the spot you chose for the tent-pole-pipe is the spot that has my tractor-document-tube which holds my 21" spare inner tube !
    :clap:freaky:beer:happay:pynd:rilla:wave:thumbup
  20. Gravel Seeker
    Apr 27, 2002
    9,099
    Quoted wrong post, mate :D
    Yeah, I did use to have a "tool tube" mounted where the right exhaust went before I replaced it with a single can aftermarket Staintune. But I haven't used a tube in years now. Found the tubes from Agrisupply were too small to really carry any tools I might find a place for it for a spare tube 'cause those are a fucking pain the ass to carry around
    Not same bike as you either :lol3
    Now don't have anything there, but have had a 12 liter aux tank made to mount there. It's for those future adventures in hard to reach places and 100% function over form. Though I like it when the bike is laden for travel. Have some work left to finish the tail end so it works with the tank since the filler/ lid is so high.
