So we've all heard/seen the 650 xchallenge...let's see your XCOUNTRY!
Discussion in 'Thumpers' started by Olas, Dec 3, 2007.
  1. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    1,929
    Герма́ния
    I stand corrected Sir !
    We (my wife) had a Dakar as her first bike ! We got a Defender too :clap
  2. Gravel Seeker
    Gravel Seeker Old, growing older.
    Apr 27, 2002
    9,069
    Dreary old Norway, dreaming of adventures past
    Not my Defender :lol3
    My buddy's who helped me make the tank. He was sand blasting it the other day, so maybe it'll be back on the road soon. Not sure if he'll sell it or kit it out for overlanding.
    I have a Pajero4 mid overlander build :super
    Dutchgit likes this.
  3. computer_freak
    computer_freak Been here awhile
    Jun 23, 2016
    246
    Dutch
    porterrad, blaster11, DGR and 4 others like this.
  4. cpallen
    cpallen Nearly Adventurer
    May 26, 2003
    1,818
    Panora, IA
    The barnyard XCountry is finally back together and I was able to take her for a short maiden voyage around the neighborhood this afternoon! Just in time for spring!
    Zeus99, NSFW, computer_freak and 5 others like this.
  5. computer_freak
    Jun 23, 2016
    246
    Dutch
    The black panels look nice, should've left the factory like that.
    There is still salt on our roads and I refuse to subject my X to that. I hope a good rain will wash it all away so I can enjoy some bike time.
    I'm also jealous of how clean your X looks without any form of rack on the back. The X-Rack the only modification I dislike on my bike, from an aesthetic point of view.
  6. cpallen
    May 26, 2003
    1,818
    Panora, IA
    Thanks, I like the black panels too. I just Plasti-Dip sparayed them to see what it looked like so probably next winter I will strip them down and spray more permanent paint. I would love to be able to buy an X-Rack and X-Tank over here in the USA. I'm going to try and design a rack based on the grab handles that would support soft panniers and a roto-pax can. It depends on how comfortable it is over distance.
    That was the problem with my X Challenge - 100 highway miles at 70 mph with 50/50 tires was pretty rough on this old body. 400 miles in a day on my GSA is pretty tiring too, and then I'm pretty limited as to what I can do off road due to 80/20 tires and loaded weight. Sadly, I think the answer is going to be to make better use of my Kendon trailer.
  7. Gravel Seeker
    Apr 27, 2002
    9,069
    FWIW
    Very clean and minimal
  8. cpallen
    May 26, 2003
    1,818
    Panora, IA
    That pannier rack looks much like what I had in mind. I wonder what the other side looks like.
  9. DGR
    DGR G650X
    Oct 19, 2009
    510
    Netherlands
    Pretty much identical @cpallen
    Really cool bike, a CCM GP450. Same Kymco engine that BMW used in their G450X, but with a lower tune for regular service intervals.
    cpallen likes this.
  10. snooker
    snooker AttitudeIsEverything
    Feb 19, 2010
    2,038
    Loveland, Colorado
    DGR and Dutchgit like this.
  11. computer_freak
    Jun 23, 2016
    246
    Dutch
    Looks like a nice solution but it seems designed to work with smaller bags.
    My XRack with Magadan 2 bags. It's a bit wide on the right side due to the missing XTank.
    Tritwin, Bebbs800, DGR and 1 other person like this.
  12. cpallen
    May 26, 2003
    1,818
    Panora, IA
    :cry
    If only the X-Rack and X-Tank could be purchased in the USA...:cry
  13. Gravel Seeker
    Apr 27, 2002
    9,069
    Isn't the Magadan bags slung over type? You could probably mount them at least 15cm/6in higher judging from your pic and probably even higher. The CCM450 rack can easily be made a little larger to fit the size bag you have.
    It was just meant as a suggestion for @cpallen so he had more than a single source to base his creation on, not a one solution fits all type of deal :thumb:lol3
    cpallen likes this.
  14. computer_freak
    Jun 23, 2016
    246
    Dutch
    This was about as high as I could get them. And this way the bag and the loops for the strap lined up correctly with the horizontal bars of the rack. You also don't want to go much higher with the weight.
    Pictured below I could raise it by around five centimeters but if I do that the loop on the bag is at the same height as the horizontal bar and then I can't use the loop anymore.
  15. Dutchgit
    Jun 24, 2012
    1,929
    Герма́ния
    I have the bottom of the Magadans about level with the bottom bar on the X-rack maybe even an inch (2.5 cm) lower.
    You want weight as low and as close to the center of the bike as possible.
    The higher the weight is, the more weight you will have to move from side to side throwing the bike around, not to mention lifting it up.
  16. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    7,735
    Any suggestions on source for good rear shock bumper stop? Mine disintegrated and OEM is a mushy need something better.
  17. computer_freak
    Jun 23, 2016
    246
    Dutch
    Having a closer look at your pictures: Your seat is mounted incorrectly. This can potentially damage the brackets. The seat needs to be flush with the tank, not have a gap as yours. There are two hooks on the subframe that should latch on your seat. You currently have your seat resting on top of them. If you position the seat correctly, you should only be able to lift the rear section up a little bit. I rode around like this for a month before Hyperbas told me about this.
    And replace your shifter if you tend to go offroad, if you fall on your current one the axle might break.
  18. Dutchgit
    Jun 24, 2012
    1,929
    Герма́ния
    Best ask at a local suspension shop. The shock might be in need of a fresh up as well. Stock shocks are not the best and the stock spring is too weak for most riders.
  19. cyclopathic
    Dec 23, 2007
    7,735
    Well the ZF shock isn't rebuildable and is not leaking.. and shops are closed/covid lockdown
  20. cpallen
    May 26, 2003
    1,818
    Panora, IA
    Good eye and thank you! I noticed that in the photo too and fixed it - I missed the hook on only one side in my rush to go on a ride.
    computer_freak likes this.
