So we've all heard/seen the 650 xchallenge...let's see your XCOUNTRY!
Discussion in 'Thumpers' started by Olas, Dec 3, 2007.
  1. tbarstow
    tbarstow Two-wheelin' Fool Super Supporter
    Jul 9, 2007
    5,070
    Mesa, AZ
    Yes, baking in an oven will help mitigate it.
    Gravel Seeker likes this.
  2. tbarstow
    Jul 9, 2007
    5,070
    Mesa, AZ
    Mechanical removal of the zince plating is way less harmful, as you're not making a cloud of vapor to breathe.
  3. tbarstow
    Jul 9, 2007
    5,070
    Mesa, AZ
    Good articles, but also understand that hydrogen embrittlement is a diffusion based process that requires time and a high concentration of hydrogen. You then have to have something impart enough energy to make hydride compounds with the base material.
    Parts that are quickly dropped in an acid bath to strip zinc won't diffuse enough hydrogen into them. Plating takes hours, as does pickling.
    When you compare the diameter of a hydrogen atoms to the interstitial spacing of iron atoms, hydrogen will go wherever it wants, it just needs to have enough energy to do so.
  4. computer_freak
    computer_freak Been here awhile
    Jun 23, 2016
    266
    Dutch
    I have under my seat:
    - 8mm + 10mm wrench
    - 13mm combination wrench
    - Torx T10, T25, T30
    - Hex 3mm, 4mm, 5mm, 6mm
    - Philips screwdriver
    - Spark plug tool
    - Knippex 86 03 150 wrench
    - Tie-wraps
    Those are the sizes I have come across so far. Should be good for road-side repair.
    For holiday trips I also take the following in a small bag:
    - 1/4" mini ratchet with 100mm extension
    - 7mm, 8mm, 10mm and 13mm sockets (you need a 1/4" 7mm with extension for air filter access)
    - Leatherman Surge
    - Tire pressure tool
    - 90 degree valve stem extension
    - 2 of each type of fuse
    - Microfiber cloth
    And of course WD40 and duct tape.
    cyclopathic likes this.
  5. WADE-O
    WADE-O Been here awhile
    Jun 18, 2011
    722
    SAN DIEGO, CA
    Just got a 2009 x country for my wife and she loves it! I do have a question she was riding it back to our house and my wife was going 65 ish for about 45 mins. It was also like 90 degrees outside. When we get it in the garage it looked like it had leaked a little oil. I'm guessing it's just from the motor being really hot. It doesn't leak after it cools down. Thoughts?
  6. tbarstow
    Jul 9, 2007
    5,070
    Mesa, AZ
    Where's the leak? The oil return to the tank might need an upgrade after 11 years.
    Dutchgit and cyclopathic like this.
  7. WADE-O
    Jun 18, 2011
    722
    SAN DIEGO, CA
    It appears to only be on the left side and it looks like it runs down the exposed piece of frame. I haven't taken any of the plastics off yet.
  8. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    7,953
    As man said there is a return hose to oil tank right above
  9. WADE-O
    Jun 18, 2011
    722
    SAN DIEGO, CA
    We talking about this kinda cloth looking one? It is damp so I'm guessing this is where it is coming from IMG_20200712_175219.jpg
  10. tbarstow
    Jul 9, 2007
    5,070
    Mesa, AZ
    That is correct. That's a rubber hose with a cover on it. Looks like yours needs to be replaced.
  11. WADE-O
    Jun 18, 2011
    722
    SAN DIEGO, CA
    Yep I agree. Not being familiar with these is this something that's best to get from BMW or will an auto parts store have something I could just cut to length?
  12. WADE-O
    Jun 18, 2011
    722
    SAN DIEGO, CA
  13. tbarstow
    Jul 9, 2007
    5,070
    Mesa, AZ
    Fuel line will work just fine.
    WADE-O and cyclopathic like this.
  14. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    1,977
    Герма́ния
    And make sure that it doesn't touch anything on its route.
    I put some spiral wrap around mine to make sure.
  15. WADE-O
    Jun 18, 2011
    722
    SAN DIEGO, CA
    Well the old hose was pretty cracked on the oil container side. 25 dollars later and it's fixed! IMG_20200713_100950.jpg IMG_20200713_100953.jpg
    uski likes this.
  16. uski
    uski Been here awhile
    Mar 19, 2018
    168
    San Jose, CA, USA
    Happy you got it fixed, I had this exact same issue. I detailed the process here, just a few pages behind :
    https://advrider.com/f/threads/so-w...e-your-xcountry.290240/page-668#post-40341107
    I am considering ordering a very high quality hose and quality clamps so that I never have to do this again (the seller of my bike did give me a box of parts a few days after I fixed this and surprise, there was a piece of new BMW hose inside, so I'm pretty sure it's been already repaired at some point before) :
    https://www.aircraftspruce.com/catalog/appages/strato111.php STRATOFLEX 111-4 hose
    https://www.aircraftspruce.com/catalog/eppages/breezelinerhexscrews.php 9406H clamp with protection for the tube
  17. uski
    Mar 19, 2018
    168
    San Jose, CA, USA
    Quick question everyone. I want to do a valve check. BMW quotes 3 hours for this. Is this reasonable ? Looks like a lot...
  18. tbarstow
    Jul 9, 2007
    5,070
    Mesa, AZ
    That is reasonable. You have to dig into the engine and get everything else out of the way to do it.
    uski likes this.
  19. uski
    Mar 19, 2018
    168
    San Jose, CA, USA
    Another question : I can't figure out if we have tubeless or tubed tires.
    I think my current tires are tubeless. However spoked wheels generally come with tubed tires. I just bought the bike and didn't touch the tires yet, so I'm not sure what's inside.
    Do our rims have the safety lip that allows for safe installation of tubeless tires ?
    Are they airtight at the spokes ?
  20. Dutchgit
    Jun 24, 2012
    1,977
    Герма́ния
    Tubes on our XCo's and XChallenges. There is no proper way of making them tubeless.
