So we've all heard/seen the 650 xchallenge...let's see your XCOUNTRY!
Discussion in 'Thumpers' started by Olas, Dec 3, 2007.
  1. underontop
    underontop Been here awhile
    Jan 2, 2008
    145
    Nelson, NZ
  2. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    9,459
  3. underontop
    Jan 2, 2008
    145
    Nelson, NZ
    Mine would be original for sure. Quite dirty but is pinkish. Currently I'm struggling with the springs, getting the cap off.
  4. cyclopathic
    Dec 23, 2007
    9,459
    Mine was dirty but not as much as I would expect.. and it was clear like Maxima.
    Do you still have forks in triples? Undo top triple bolts and loosen up cap with 19mm. If you are not replacing seals or springs and don't need to change sag (mine were at 28-29%) just dump and pump there's no reason to take off caps good luck.
    EDIT
  5. ERU
    ERU Been here awhile
    Nov 1, 2009
    181
    Bucharest
    When i redone the suspension i discused at lenght with my suspension guru and he was very confident that the air gap sould be 120mm optimal and minimum 100 mm.
  6. cyclopathic
    Dec 23, 2007
    9,459
    Is it for '07 or '09? '07 has longer forks.
  7. ERU
    Nov 1, 2009
    181
    Bucharest
    09 but i had changed all internals with a RXV fork
  8. cyclopathic
    Dec 23, 2007
    9,459
    Has anyone tried Adreani cartridges on G650x?
  9. skybo1
    skybo1 Been here awhile
    Sep 21, 2011
    297
    Charlotte,NC
    Broke my license plate light fixture. Anyone? Snooker?
  10. WADE-O
    WADE-O Been here awhile
    Jun 18, 2011
    936
    SAN DIEGO, CA
  11. NSFW
    NSFW who else would love noobs? Super Supporter
    Feb 20, 2007
    26,672
    Burbank CA
    i think this might work. remove the broken housing and light assembly. replace it with this one. i have no experience but they claimed it's bomb-proof.
    https://www.headlightrevolution.com/morimoto-5stop-brake-light-LED-5STOP_2?quantity=1
    i have put a lot of cheap tail lights on my xr400, including a DRC. none of them lasted long due to vibration and water intrusion. right now, it has the 701 tail light take off. if that fails too, i will try the Morimoto 5Stop.
    i just installed the R & G tail tidy on my 701, looks great but the light assembly turned to be a problem. contacted twistedthrottle and never got response. i even sent email to R &G in UK, same no response.
    the bracket is well made and kept it. installed 2 Skeen P3 lights to replace the R & G tail light...expensive fix.....:baldy
  12. markymcd
    markymcd Been here awhile
    Sep 18, 2008
    924
    Vancouver, BC, Canada
    does anyone know if the air filter is the same for 2009 as 2007-08? cheers!
  13. NSFW
    Feb 20, 2007
    26,672
    Burbank CA
    i don't have the bike with me and need to clean up my handlebar layout after picking her up from storage. the heated grips are a last-minute addition and rushed. even though i don't need them now, i still want the controller on the bar or somewhere, permanently or temp. looks like it can be mounted on the left side alum bar of the Barkbuster, sandwiched the bracket/mount between the clamp extension and bar. a longer bolt will be needed.
    also be adding USB outlets and SAE connector in the cockpit. i appreciate if you could post up pics of your aftermarket add ons. thanks.
  14. WADE-O
    Jun 18, 2011
    936
    SAN DIEGO, CA
    what windscreen is that?
  15. NSFW
    Feb 20, 2007
    26,672
    Burbank CA
    aftermarket BMW part, specific to the G650XCo. works for me.
  16. cyclopathic
    Dec 23, 2007
    9,459
    Does anyone have part # or good source for ignition key blank? Is it the same as for F650GS?
  17. tbarstow
    tbarstow Two-wheelin' Fool Super Supporter
    Jul 9, 2007
    5,420
    Mesa, AZ
    I think it is an Aprilia key.
  18. computer_freak
    computer_freak Been here awhile
    Jun 23, 2016
    353
    Dutch
    I think they used Zadi locks for the X bikes.
  19. WayneC
    WayneC Long timer
    Oct 3, 2008
    5,882
    Sydney, Australia
    Yes the key blanks are the same as the 6S, the early carb F650, C1 and some R Series, I used R Series helmet locks as a basis for a topbox lock
    cyclopathic likes this.
  20. Stanphil
    Stanphil Adventurer
    Apr 6, 2018
    20
    Smyrna Ga
    Hi, great weekend on the xcountry. Greasy slick red clay ride in N. Ga. TCK 80s to the rescue, I loved the ride.
    I am looking for a bash plate. Any thoughts?
