SoCal Motography Adventures...(post ride from CABDR)
Discussion in 'Ride Reports - Day Trippin'' started by black 8, Jul 12, 2017.
  1. Norty01
    Norty01 RIDERCOACH (RETIRED!)
    Jan 30, 2014
    2,004
    CARLSBAD, CA, USA
    That XT is designed to give many miles of dependable service. It looks like B8 is giving the bike a new lease on life with all the servicing it's finally getting. (I still think the swingarm pivot bolt is serviceable.) I'd likely slather it in a layer of boat trailer wheel bearing grease though. (It sheds water the best.)
    I also think you'll come to the conclusion that the more you ride this bike, the more you'll like it. And you'll find that it ticks a lot of boxes that new bikes just don't. (Reasonable seat height and total weight being 2 of the biggest.)
    Looking forward to seeing your adventures on the little XT, and ride safe!
    If you see some fat guy on a Husky 701, or Triumph Tiger, shoot him the bird, as it's likely me!
    MYUMPH, black 8 and klaviator like this.
  2. black 8
    black 8 coddiwompling motographer
    Dec 11, 2016
    3,051
    33.202738 -117.384040
    Thanks Norty01... will surely do if I spot you on the road...
    all this servicing I'm doing is for my own peace of mind and gives me a chance to get closely acquainted with the XT (wrenching wise) before I get on some lonely trail...
    I'm packing my gear right now to see what fits on the XT. I want to go with minimal gear while riding Sections 1 through 5 of the CABDR... Looking at the temps, they're mild down south (Yuma, Blythe, and even DV) but when you get to Lone Pine and points up north the temps drop to the low 40s overnight...
  3. black 8
    Dec 11, 2016
    3,051
    ~ 15 Oct 2019
    The XT gets a new lease on life...
    The parts I ordered last week finally arrived this afternoon and I was "In like Flint" wrenching in the garage... I managed to knock out some good maintenance today getting thumper back up to spec and the rear swingarm assembly cleaned and lubed... Over the Columbus Day weekend, I took off the rusted muffler and dedicated half a day wire brushing it. Once I was satisfied, I cleaned off the grime and used high heat Rust-Oleum spray paint to give it some new life...
    easy peasy valve clearance checks with those tappets instead of shims...
    new spark plug...
    I couldn't wait to replace those OEM drum brakes after hearing they were prone to delaminating...
    I tried to save the old chain but I decided to replace it instead fearing it could be a point of failure out on the trail...
  4. dano619
    dano619 Long timer Supporter
    Sep 4, 2011
    1,015
    sunny san diego
    Gettin er done!!
    black 8 likes this.
  5. black 8
    Dec 11, 2016
    3,051
    knocked out the service bulletin...
    basically remove the right case cover and drive a 6mm roll pin into the crankshaft oil gallery to prevent oil starvation to the top end...
    done and done...
    bobw, The Virginian, B10Dave and 2 others like this.
  6. black 8
    Dec 11, 2016
    3,051
    some before and after stuff...
    I had to get rid of that black fuel line and huge fuel filter, it kept getting in the way of the choke...
    after...
    before...
    after...
    bobw, The Virginian, B10Dave and 7 others like this.
  7. black 8
    Dec 11, 2016
    3,051
    time to hit the trails to see what this little XT can do...
    I still need to install new fork seals, heavier fork oil (10W to 15W), lube the steering head, and clean the carburetor before I'm able to take the XT on the CABDR... I'm glad that I'm going through the bike with a fine tooth comb, so far I've found a bolt missing from the headlight bezel that keeps the headlight in place and the missing oil seal in the swingarm... My confidence level in taking this XT out on the trail keeps getting elevated as I fix the niggles on the bike...
    So now I'm waiting on a spanner wrench to remove the steering head nut and carb rebuild kit. Both are on the slow boat from Taiwan, at least I got free shipping when I ordered them on eBay... this gives me some time to ride and adjust the preload on the rear monoschock...
    :beer
  8. eaglescan
    eaglescan Borrego rocks Supporter
    Jun 17, 2009
    565
    Langley,B C
    Looking good. the new chain looks tight, maybe just the photo?
    black 8 likes this.
  9. black 8
    Dec 11, 2016
    3,051
    It's the photo...
    The Clymer Manual says between 2 - 2 3/8 free play and I have it measured at 2 inches of free play...
  10. sealsam
    sealsam Sam...I am. Supporter
    May 30, 2010
    6,545
    seal beach, ca.
    Suweeeet Rudy! XT is looking fantastic!
    Heads up, if headed Borrego way this weekend, it's Borrego Day's. An annual event that draws some pretty sizable crowds(from what I understand), I've never been to one, and I won't be at this one.
  11. Norty01
    Jan 30, 2014
    2,004
    CARLSBAD, CA, USA
    Be careful with that XT. With all the fixes and shining up your doing, you may end up with a museum piece!
    That bike is already "Too purty to ride!"
    black 8 likes this.
  12. black 8
    Dec 11, 2016
    3,051
    Thanks for the heads up Sam...
  13. black 8
    Dec 11, 2016
    3,051
    Don't worry, its gonna' live primarily in the dirt... I just wanted to stop the corrosion in the muffler so it doesn't rust through...
    okiegtrider and klaviator like this.
  14. black 8
    Dec 11, 2016
    3,051
    yuppp... I can't wait to see how the XT does out on the trails vs my own experience with the KLR...
    B10Dave and klaviator like this.
  15. rodrigzj
    rodrigzj Been here awhile
    Dec 13, 2014
    307
    Culver City, CA
    I enjoy seeing old bikes or cars come back to life!
  16. black 8
    Dec 11, 2016
    3,051
    I was uneasy about owning a vintage bike thinking I was biting off more than I can chew, but I have to admit I enjoy working this oldie....
    sealsam, popscycle, MYUMPH and 2 others like this.
  17. rodrigzj
    Dec 13, 2014
    307
    Culver City, CA
    It’s pretty satisfying to watch it transform and start looking and running as they should.
    Not to much bling. But just enough to make it look clean.
    Good job!
    dano619 and black 8 like this.
  18. klaviator
    klaviator Long timer Supporter
    May 28, 2008
    13,970
    Huntsville , Al
    And we are enjoying following along as you do this!
    B10Dave, sealsam and black 8 like this.
  19. ADK
    ADK .........................
    Dec 5, 2005
    9,266
    How about a big bore kit? :evil
    black 8 likes this.
  20. black 8
    Dec 11, 2016
    3,051
    Nahhh, that's what the other bikes are for... I like how mellow the XT is just for just puttin' along... :ricky
    If I need ludicrous speed I can take out the Duc... :pynd
    Zubb, MYUMPH, klaviator and 2 others like this.
