Solar powered battery maintenance for multiple bikes
Discussion in 'The Garage' started by mokosai, Sep 30, 2019.
  1. mokosai
    mokosai Been here awhile
    Jun 22, 2009
    222
    America's Cornbasket
    So, I need to park motorcycles over the winter in a spot that has no electricity. I would like to hook up battery tenders to the bikes, and I was considering the easiest way to be a cheap bastard and yet have a solar panel maintaining motorcycle batteries.
    How about a single 60 watt solar panel, and two cheap battery charge controllers hooked up to it in parallel, with a motorcycle hooked up to the battery connections of each of the 3-stage charge controllers? I think the two battery charge controllers can probably share a solar panel. I guess that when there isn't full sunlight hitting the panel to charge controllers won't really be doing anything for the battery, but that's okay, because I'm really just trying to maintain charge.
    Or alternatively, can I be really really cheap and hook up both motorcycles in parallel with one another to a single charge controller? The only problem I can foresee is that the batteries will try to equalize when connected first connected in parallel, so I probably want a current limiting resistor somewhere in series to make sure that the two batteries can only transfer charge between themselves at a couple of amps max.
    Thoughts?
  2. 51%
    51% ReadyToRide
    Nov 17, 2011
    535
    Somewhere in North America. Probably.
    Just buy two cheap solar battery maintainers, they’re only like 10w more or less.
    Solar controllers usually state do not connect to the PV panel with the battery bank not connected. Potentially when you unplug a bike -if the PV panel is lit up and connected- you could kill the controller.
    SmittyBlackstone likes this.
  3. JR356
    JR356 Long timer
    May 4, 2005
    6,973
    Way Northwest
    Best idea is to pull all the batteries,bring them home and rotate them on a single charger,or get one of the multi bank chargers from BatteryTender or ?
    JR356
  4. mokosai
    Jun 22, 2009
    222
    How embarrassed should I be that this didn't occur to me as the cheapest and simplest option of all?
    MoikonaBoik likes this.
  5. MrPulldown
    MrPulldown Long timer
    Aug 18, 2009
    8,323
    Truckee
    Or you can just do nothing. That is what I typically do. If I want to do a little more, then I unhook the battery and leave it in place. Next option is to pull the battery, tape up the terminals (so there is no accidental shortage), and set opn the garage shelf. I never leave a battery on a charger. Doesn't seem like there is a reason for the battery to discharge over the winter. If I have the battery pulled I will give it a charge before I install it in the bike. If I really wanted to "take care" of the battery, I will probably throw a trickle/tender on it for a couple of days each month.
    Grinnin and gonerydin like this.
  6. RetiredandRiding
    RetiredandRiding Retired to Ride Supporter
    May 22, 2015
    1,557
    Da Lat, Vietnam
    Don't hook up two batteries to the same tender at the same time. Could be bad news.
  7. Grreatdog
    Grreatdog Long timer Supporter
    Apr 6, 2007
    35,375
    Annapolis, MD
    If you want to go the solar route, you dont need that much power. A pair of 5w Battery Tender panels with built in controllers kept my pair of boat batteries fresh for ten years.
    Even though they had to run bilge pumps, 5w was enough. I replaced the batteries when I sold the boat just so buyers wouldn't freak at ten year old batteries even though they worked perfectly.
    There are probably better things out there now. This design is at least 15 years old now. But they worked perfectly in a moored boat with no power. In my experience, even this is more power than you need for a maintenance charge:
    https://www.amazon.com/Battery-Tend...ocphy=9007937&hvtargid=pla-436302373665&psc=1
    Johann likes this.
  8. Andyvh1959
    Andyvh1959 Cheesehead Klompen Supporter
    Feb 16, 2012
    4,032
    Da frozen tundra eh? 1.5 mile west of Lambeau
    I'm building my shop garage right now. It will also have four 220watt solar panels on the south of the roof to power the LED lights I am using to light the garage. I already have the solar panels, charge controller and DC breaker panel. I have 11 bikes to keep charged, so I'm thinking of using the solar panel output to also power a bunch of connections for my bikes. Anyone done this? Or am I considering a complicated setup to keep my bikes charged?
    #8
