Sold sold
Discussion in 'Parts' started by greg.279, Aug 28, 2019.
Thread Status:
Not open for further replies.
  1. greg.279
    greg.279 Been here awhile
    Sep 11, 2017
    130
    PNW
    SW Motech “Daypack” model tank bag with gas tank ring for sale. Everything it came with is included (mounting hardware, shoulder strap, rain cover), also the non-electric tank ring adapter for BMW/Ducati/KTM. I had it on a 2019 1250 GS.
    The bag clicks onto and off of the ring easily by pulling a cable release at the front of the bag. It has a wire pass-though so you can run a USB cable to your power source. The bag expands with a zipper around the base. I thought it was a good size for my wallet, keys, phone, GoPro on Dango Gripper helmet mount, and a few other small things. The bag does not touch the gas tank.
    I only used the bag a few times, but something to note is that the base of the bag has to have 4 holes drilled in it by the purchaser in order to attach the plastic block that connects the bag to the tank connector ring, 2 toward the leading edge of the bag, and 2 on the trailing edge. I somehow drilled the rear 2 holes a little off from where the screw holes are on the plastic block, so it’s just mounted to the bag by the 2 leading edge bolts. The block fits tight to the bag, and I never had an issue with just using it as it was.
    I rode on and off-road with the above-mentioned items in it and it held on just fine. Even if you pull up on the rear of the bag, the block stays tight. If you’re handy, I’m sure you can come up with a solution, but it works fine as-is, and I think I’ve priced it accordingly. The other 2 screws are the small black ones in the plastic bag picture. Take a look, and let me know if you have any questions. $90 shipped. Tacoma area for meetup.
    IMG_20190828_172517433.jpg IMG_20190828_172545944.jpg IMG_20190828_172600315.jpg IMG_20190828_172759406.jpg IMG_20190828_172817376.jpg IMG_20190828_172828854.jpg
  2. greg.279
    Sep 11, 2017
    130
    PNW
    Bump $90 shipped
  3. SpEd
    SpEd Purposeless life has its advantages.
    Aug 7, 2005
    394
    Willis, just North of Houston
    Delete
  4. greg.279
    Sep 11, 2017
    130
    PNW
    Bump
  5. Moore_Power
    Moore_Power Adventurer
    Aug 1, 2009
    56
    PA
    I'll take it!
Thread Status:
