    Dismiss Notice
[SOLVED] Changing Rear Tire, Did I fuck up my Tubeless rims?
Discussion in 'The Garage' started by naruse, May 16, 2018.
  1. naruse
    naruse Been here awhile
    Dec 29, 2014
    251
    Little rock, AR 72211
    Hey guys,
    Tried to be as careful as possible and used a cloth but still I managed to scratch the rims :/.
    This is from an R1150gsa rear tire rim. did I fuck up and now my rim cannot be tubeless? :/.
    Looking forward for your knowledge :S
  2. superscott
    superscott Been here awhile
    Jan 5, 2012
    153
    Those aren't scratches, those are gouges. That being said, air up the tire and check the beads for leaks. If its leaking, get some rubber cement and apply it on the tire bead in the affected areas
    REALGRAVEROBBER and naruse like this.
  3. RonKZ650
    RonKZ650 Been here awhile
    Jun 11, 2009
    983
    Lakewood, CO
    Those gouges, scratches, whatever they are, won't hurt anything as far as holding air. You'll be fine.
    dsilver1007, JimVonBaden and naruse like this.
  4. Black Rhino
    Black Rhino Closer to Dairy Queen than Steve McQueen.
    Dec 7, 2012
    5,720
    West of Atlanta , Ga.
    You will likely be just fine. Remove any areas where the metal is bunched up at (you can do this with a sharp razor blade....) to prevent the possible loss of air in those areas. Get "Rim savers" and get spoons with wide heads (the B/M Dunlop knock off is my go to....). I had to file down the inside of my rims to make them tubeless , cleaning up where they were welded together.
  5. naruse
    Dec 29, 2014
    251
    guys, thank you so much for the replies! :), Didnt know it was called gouges (english is not my main lang). Still, thanks for the clarification and help! <3
    ohgood likes this.
  6. REALGRAVEROBBER
    REALGRAVEROBBER LEAVING GRAVES EMPTY
    Nov 1, 2008
    878
    GFY, Montana
    Bondo body filler. Try to not do it again, but it is repairable.
    naruse likes this.
  7. ohgood
    Sep 21, 2010
    10,052
    alabama
    sand down the gouges if you care about appearances, but that isn't the seal area.
    there first hump is the safety bead, then the flat area between the safety bead and the edge of the room is where it seals.
    it's fine
  8. JimVonBaden
    Feb 11, 2005
    92,087
    Alexandria, VA
    Agreed. Next time use leather instead of cloth. I use furniture samples 6X10" in size. I get them in sets from ebay for $20. Enough to last several years and a hundred sets of tire changes.
    #8
    racer1735, ohgood and naruse like this.
  9. naruse
    Dec 29, 2014
    251
    Thanks a lot for this clarification :)!, also @JimVonBaden great suggestion! :).
    #9
    ohgood likes this.
  10. STUFF2C
    STUFF2C We Ain't Left Yet!!
    Aug 12, 2004
    3,463
    O-lando
    Cut up a bleach bottle into strips...
    #10
    ohgood likes this.
  11. Not the Messiah
    Not the Messiah Old enough to know better, but slow learnin'
    Jan 19, 2013
    1,208
    Melb'n, 'Straya
    Then when you're putting the new tyre on, count the buggers like a surgical nurse. If you're one less at the end, the bugger slipped inside the tyre while you were wrestling the tyre irons!
    Oh well, it was a lot quicker the second time but I would've been quite happy without the practice.
    Cheers
    Brian
    #11
  12. LuciferMutt
    LuciferMutt Rides slow bike slow
    Aug 19, 2008
    16,684
    New(er) Mexico
    Empty bleach first.
    #12
    JimVonBaden likes this.
