Sorting out my R90/6 (sprouty115)
Discussion in 'Airheads' started by sprouty115, Sep 13, 2017.
  1. sprouty115
    sprouty115 Long timer Supporter
    May 29, 2012
    6,526
    Providence, RI
    Edit - this thread has moved on from the original question and considering I've been using to ask for help on a number of issues (and I'd like to continue with that), I thought I might change the title.
    Post #1-29: Converting a /6 headlight/instrument cluster to a /5 nacelle. (I've come to my senses and I'm no longer considering any conversion)
    Post #30-87: Timing issue. (turned out to be the flywheel installed one bolt-hole off. Pulled the flywheel, and reinstalled it. Also replaced and repaired rear drive seal, misc stripped threads)
    Post #88-116: Carb balancing questions. (lots of info provided, but it still won't run well)
    Post #117-132: Enduralast charging and electronic ignition install. (a solid upgrade, but the bike still doesn't run like it should)
    Post #133-162: Carb balancing issues leads to a compression/leak down test and eventually to the major issue. I finally took it to Max BMW for a bit of help - 150psi on each side and less than 4% leak down! But a faulty key switch dropping the voltage to the coils was found. $450 later and the bike is running as well as it's ever run...)
    Post #163-176: Leaking shock, brake light always on, carb leaking question.
    Post #177-191: Gauge mount recondition, new low-bars, front turn signals, cable issues and routing
    Post #192-203: Cable issues and routing, turn signal stalk length.
    Post #204-215: Seat options
    Post #216-225: Carb tips
    Post #226-260: Gages, R90 fairing, rear indicator stalk length, dent, rust
    Post #261-273: Handlebar options, non-matching levers
    Post #274-275: Reg/Rec relocation
    Post #276-xxx: Leaking master cylinder
    Original 1st post:
    This is the bike I wanted:
    This is the bike I bought:
    Close inspection will tell you they are not the same bike. But 13.5K original miles, 150cc increase, an extra gear in the transmission and a disc brake won me over. I'm happy with the bike and I'm even enjoying sorting out 42yrs of issues that come from 42yrs of occasional use, however the aesthetics of the /5 are where my heart is.
    So having said that, and with reassurances of not performing anything that would not be reversible (no chopping or bobbing of anything), I'm thinking of basically changing the components that will make the bike appear closer to a /5 in style*. As far as I can tell most items are available (provided you're will to pay) and are a simple bolt-on process.
    But the one thing that seems like it might be a bit more involved is instrumentation/headlight. Which leads to my question: does anyone have any experience on converting the /6 headlamp and gauges to the /5 nacelle?
    * I realize this may be sacrilege to some, but I'm hoping that might be overlooked considering I won't be ruining anything, nor claiming it is an original /5.
  2. UnclePete
    UnclePete Been here awhile Supporter
    Nov 13, 2014
    901
    Plumas County , CA
    I recommend that any new owner ride a bike for a season before doing any modifications .
    Just go through it , service it , ride and maintain it ; get to know it .
    Might like it just the way it is .
    sprouty115 likes this.
  3. Big Bamboo
    Big Bamboo Aircooled & Sunbaked Supporter
    Sep 29, 2010
    14,938
    Big Island of Hawaii
    AND, if you do decide to do the swap, remove the headlight and the main wiring harness together and replace them with a /5 wiring harness (around $70). The /6 wiring has all the later style push on connectors, while a lot of the /5 headlight connections are soldered ends with screws holding them in place. You will still have to butcher the /6 handlebar switches wiring to make them work, unless you go to /5 perches and switches... The neutral light wiring, fork ears and starter relay is different too.
  4. OLD GREEN
    OLD GREEN Long timer Supporter
    Sep 6, 2009
    1,977
    N.W. Oregon
    It's not a cheap proposition obtaining all the necessary parts to convert it but it is doable. The /5 wiring harness that BB mentioned is about the cheapest piece to the puzzle. The bucket, lens, reflector and a usable speedo/tach are getting very expensive unless you luck into them. The fork ears, perches and switch gear will each set you back about a $100 a set. You'd almost be better off finding a ratty non titled /5 to cannibalize and sell off what you don't use than to try and source all the parts individually.
    Texer likes this.
  5. sprouty115
    May 29, 2012
    6,526
    Providence, RI
    TL;DR - that's sound advice.
    So far I've spent some time on the bike but it has some issues that I can't ignore, so I've done the following:
    - inspected all fluids (they looked brand-new, though that was expected as Max BMW had replaced them all a few months before I bought the bike)
    - inspected brakes, wheels, and tires (tires are ok, but not great, everything else seems fine)
    - replaced plugs (both were very black from signaling weak spark or carb issues)
    - replaced plug wires and caps (slightly cracked and definitely old)
    - rebuilt carbs (o-rings, gaskets, floats and float needles)
    - set gap on points
    - balanced the carbs
    Right now the bike runs, but not quite as smoothly as I was expecting, so I started back-tracking. When I set the gap on the points I couldn't even get close with the static and dynamic timing. I assumed I must have been doing something wrong because, as I said, it does run. So after some research, I discovered the issue with the Chinese pints. Now I'm in the process of replacing the points (and condenser) to see if I can get the timing correct. If that all falls into place I'll start riding it
    Good info. I will have a look into the connections.
  6. sprouty115
    May 29, 2012
    6,526
    Providence, RI
    Yup, I had a line on a full nacelle for around $270 but as you can expect on E-bay it doubled in price in the last few minutes of the auction. Hadn't considered a parts bike...
  7. blaine.hale
    blaine.hale Long timer
    Feb 28, 2009
    4,101
    Atlanta, Ga
    I see your problem. You wanted a /5 and got a /6! Silly.
    In all seriousness (I did this) ride and enjoy the r90. It's a powerful beemer and great bike. Maintain it, don't modify anything and keep it clean. A stock, original bike will sell for more. When you're bored, sell it and find the right /5 toaster. Where I live, they're valued similarly.
    sprouty115 and nobbylon like this.
  8. sprouty115
    May 29, 2012
    6,526
    Providence, RI
    I did...not saying I regret it, as doesn't seem like low mileage bikes are common. But it does seem like it might have been easier to start with a /5 and then bump the displacement and swap the transmission, no?
    #8
  9. pkboxer
    pkboxer Been here awhile
    Jun 15, 2011
    123
    cincinnatus oh
    It's really not all that hard and you can undo it if you must. But why? Resale value? Owning the bike isn't about resale value....
    Anyway.
    IMHO the /2 bucket was better, the /5 looks like a snake digesting a giant rat. The instrument is too big for the bucket.
    What I (and some others, Brun comes to mind in Australia) did was use a soviet/china BMW knock off bucket.
    Originally I used just an electronic tach, and now have a speed hut speedo in the bucket.
    Cheaper bucket than a /5 too. I put the /6 wiring board inside the bucket and went from there.
    Here's a few pics, good luck.
    #9
    Jim K in PA likes this.
  10. drhach
    drhach We can't stop here, this is bat country!! Supporter
    Nov 21, 2006
    3,400
    Wadsworth
    That's awfully brilliant. How did you sort out the "Gen" light requirement? Is it one of your idiot lights?
    #10
  11. sprouty115
    May 29, 2012
    6,526
    Providence, RI
    To be clear this has nothing to do with resale, it is simply my preference of aesthetics coupled with the fact that my gauges will require service. So if I'm going to spend money, I'd much prefer to have something that looks good to me. Thanks for the suggestion on the alternate source.
    #11
  12. blaine.hale
    Feb 28, 2009
    4,101
    Atlanta, Ga
    It has a little bit more power and top end than an r75 but you won't miss that in the bump down to an r75. Keep in mind, 4th gear on a /5 is the same as 5th gear on a /6. I personally like the /5 4 speed.
    You're sort of comparing a cow with a slightly smaller cow. I love cows but they aren't the quickest things.
    #12
  13. pkboxer
    Jun 15, 2011
    123
    cincinnatus oh
    on the right side of the bucket you can see a little red bump. That's a self contained LED from the auto store.
    Also have a resistor in parallel in case.
    Funny - once accidentally removed the resistor (before I was using the light) and the bike would shut off. It was self energizing through that circuit.
    The top two lights are green - neutral light and turn signals red - oil pressure.
    #13
  14. BicyclebBob
    BicyclebBob Been here awhile
    Jul 23, 2009
    463
    Yuba City, California
    If you find a parts bike /5 ride the /6 and restore the /5... the 4 speed gearbox and other things you talked about upgrading are what make the /5 awesome. I wouldn't sacrifice a /5 in any condition to make a fake /5.
    #14
  15. Big Bamboo
    Sep 29, 2010
    14,938
    ...or put a "WANTED, BMW motorcycles; Dead or Alive" ad on your local Craigslist, and see what pops up. I paid a total of $1850 for the last SIX bikes I bought, and one was an R60/5 with no title... for FREE! :deal
    #15
  16. spo123
    spo123 Man About Town
    Nov 7, 2006
    1,220
    North Shore Mass. USA
    Usually, DESIRABLE parts WILL double in price, at the last minute....or SECONDS.
    That is how it works, on epay.
    NICE BIKE.
    Leave it alone and deal with what it REALLY needs.
    Have fun.
    #16
  17. Brun
    Brun Been here awhile
    Jun 29, 2012
    767
    BorderBurg, South East Oz.
    G'day Sprouty
    Me too. I'm a /5 tragic blessed with a /6. For me, fate intervened in the form of a black cow on a dark night, resulting in a trashed front end. I've had a couple of chinese headlights and a variety of speedos since but now have a 3D printed bucket and ears with a Speedhut GPS speedo:
    Here's the next iteration, not yet fitted:
    This project is still current - I'm in the process of setting up a bigger and better printer. Here's a thread detailing the adventure so far:
    http://advrider.com/index.php?threads/3d-printing-the-slash-five-headlight-bucket.112399
    #17
  18. bpeckm
    bpeckm Grin! Supporter
    Apr 2, 2008
    7,848
    Road Island
    I have a Slash2 Conversion: I found an off-brand bucket from some other european bike, it looks a lot like the /2 bucket, and then got a cheapy ($15!) speedo from india. The 90/6 speedo cable works perfectly. It does not have a tach, but I haven't needed one (I rev the **** out of it now and then and don't want to know where the needle is going....!). I did my own custom wiring harness and installed all the /6-and-later goodies (kill switch, turn signals on my left perch etc). Full thread is in my sigline if you care to wade through it, but here are a couple of pics of what I did....
    The headlight is a car sealed-beam/LED style.
    #18
    Antti, fxray, sprouty115 and 2 others like this.
  19. Jim K in PA
    Jim K in PA Long timer
    Mar 15, 2011
    4,292
    Pocono Mountains, PA
    And what is the lead time on international orders, Charlie??
    :D
    #19
  20. sprouty115
    May 29, 2012
    6,526
    Providence, RI
    Just to clear, I wouldn't consider sacrificing a salvageable bike as spare parts for any project. I'm merely considering my options - wanted a /5 but ran across a nice /6, so I'm just trying to sort out a compromise. All I've done to-date is give the bike a much needed tune up.
    Again, thanks to everyone for all the ideas - off-brands and 3D printing never occurred to me...
    #20
