1. solo650
    solo650 '17 vstrom 650 Supporter
    Jun 20, 2017
    478
    west central Ill
    Anyone.....need advice....help near Gypsum. Got a tiger 800 with a slipping clutch. What to do?¿?? IMG_20210715_202527435_HDR.jpg
  2. BikePilot
    BikePilot Long timer
    Jul 5, 2005
    12,037
    Golden CO
    First off make sure the cable or hydraulic mechanism that actuates the clutch isn’t failing to fully release pressure on the pressure plate. If that’s not the problem then either the clutch pack is too thin due to wear or the springs aren’t providing enough clamping force, or both.
    Spark plug washers seem to fit most clutch springs and can be used to add preload to get a few more miles out of a weak one. Otherwise new plates and springs is the usual cure. If the plates are badly glazed from riding with it slipping it may help to rough them up a little. Good luck!
    Hair likes this.
  3. solo650
    Jun 20, 2017
    478
    west central Ill
    Thanks.... We have it apart. Planning to hit the plates with 1500grt... Brakleen.... And reassemble....
  4. solo650
    Jun 20, 2017
    478
    west central Ill
    We have ALL cable slack availability.... It still seems right!!!
    BikePilot likes this.
  5. Motopsychoman
    Motopsychoman Not a total poseur Supporter
    Jun 2, 2013
    7,785
    Oaklandish
    I'd use 320 wet-or-dry. Don't want to polish them.
    Good luck.
    Rogue_Ryder and RoadDukie like this.
  6. Motopsychoman
    Jun 2, 2013
    7,785
    Oaklandish
    Forgot to add, make sure that the stack of friction plates slides smoothly up and down in the basket and that the stack of metal plates slide smoothly up and down on the hub.
    And oil the friction plates as you reassemble the stack so they don't burn.
    solo650 likes this.
  7. Qwik
    Qwik Adrenaline Addict
    Apr 27, 2008
    8,467
    Aspen Colorado
    Do you have a place to stay? Tools? I’m in Aspen so not to far. And I have a truck/trailer
  8. solo650
    Jun 20, 2017
    478
    west central Ill
    Staying on BLM land... Outside gypsum..... Gonna hit O'Reilly in a.m.. go from there!!!!
    #8
    Qwik likes this.
  9. solo650
    Jun 20, 2017
    478
    west central Ill
    #9
    HanzoSteel and mitchapalooza like this.
  10. jwrover
    jwrover Long timer Super Supporter
    Jul 30, 2006
    1,143
    Ouray, Colorado, USA
    Just down the highway from Gypsum. Might have a solution or technician to help
    Moto Source
    970-328-8005
    1120 Chambers Ave
    Eagle, Colorado 81631
    Monday 10-6
    Tuesday-Friday 9-6
    Saturday 9-3
    #10
  11. BikePilot
    Jul 5, 2005
    12,037
    Golden CO
    Do you mean it still seems tight? If the cable is tight that’s almost certainly your problem.
    #11
    Qwik likes this.
  12. Qwik
    Apr 27, 2008
    8,467
    Aspen Colorado
    Cable should have a little play when it’s released.
    #12
  13. solo650
    Jun 20, 2017
    478
    west central Ill
    Plates are so thin ... Can't get any slack ,. .... New plates being overnighted to Eagle Co... Be on bdr by 12:00 hopefully!!
    #13
    Joz and Motopsychoman like this.
  14. Motopsychoman
    Jun 2, 2013
    7,785
    Oaklandish
    Did the new friction plates solve the problem?
    #14
  15. solo650
    Jun 20, 2017
    478
    west central Ill
    Sure did... 20 minutes to change plates.. We hit I70 east for 900 miles.
    #15
    Motopsychoman likes this.
