    Dismiss Notice
Sound from front wheel? Does this sound like bearing or brake pad?
Discussion in 'The Garage' started by mangasm, Aug 11, 2019.
  1. mangasm
    mangasm n00b
    Mar 16, 2011
    9
    Hey everyone! Riding 401 Husky Svartpilen.
    Noticed especially while keeping the clutch in a kind of surging squealing/squeaking from the front wheel (pretty sure) while riding. Planning to try and bring by somewhere that can lift it up this week and try rotating the wheel to hone in on the source of the sound but wanted to see if anyone could identify by sound before then.
    It is a squeaking that surges over and over again. Of course most obvious when clutched in and I can hear it quite loudly over anything other than the motor.
    It is lightly through the whole clip but is most noticeable right before the end at maybe 3 seconds (before I let out the clutch). Bike only has ~2100 mi. on it so shouldn't be a loose bearing right? Though that is what it sounds like to my novice ears..!
    https://soundcloud.com/mangasm/motorcycle-wheel-sound
    Thank you for any input!
  2. mangasm
    mangasm n00b
    Mar 16, 2011
    9
    Anyone have any input? Safe to ride down to the mechanic? :eek:
  3. foxtrapper
    foxtrapper Long timer
    Sep 6, 2011
    4,540
    The file won't make a sound for me.
    But, if you can make the noise change/abate by dragging the front brake, it's the brakes. If it makes no difference, it's a wheel bearing. Since you describe pulsing, I'm going to speculate it's the brakes, warped rotor in particular.
    sieg likes this.
  4. Baroquenride
    Baroquenride Everyone dies, but not everyone truly lives.
    Apr 10, 2011
    4,451
    Clark Co, Wa
    All I heard was wind noise. You'll have to get a better soundclip, but I suspect it's a warped rotor if anything.
  5. Johann
    Johann Commuterous Tankslapperous
    Feb 11, 2006
    6,578
    Europe
    Feel the disc after a short ride, if the disc is warped it will probably be hot whether or not you use the brakes. You´d have to get the front wheel off the ground to check the play in the wheel bearing.
  6. dtysdalx2
    dtysdalx2 Only a matter of time.
    Aug 1, 2004
    26,472
    Moneyapolis, MN
    Yeah, sound clip was pretty useless. Wind noise and some flapping around.
    Raise the front, spin it by hand and check for looseness in the bearings. Or anything else.
  7. kenstone
    kenstone worn out
    Mar 3, 2013
    1,928
    Boysee
    that
    Then push the pads back away from the disc, with the kickstand down, tip the bike so the front wheel is off the ground and spin the wheel with your foot...listen for the noise.
    If it's gone it was the brakes, if it's still making the noise it's the bearings.
    jmo,
    :D
    sieg likes this.
