Spares list
Discussion in 'GS Boxers' started by Veter, Nov 7, 2012.
  1. Veter
    Veter Motoviajero
    Oct 14, 2012
    45
    On a relaxed LONG trip all over Latin America
    A decent spares list for 1200gs (1yr trip) anyone?
    Mileage is ~10k mi currently
  2. johnjen
    johnjen Now, even more NOW!…
    Nov 28, 2001
    17,137
    Alternator belt
    volt meter
    head light bulb
    jumper cables w/adapters and appropriate connectors (cell phone chargers etc.)
    tools for routine maintenance
    1st aid kit
    gummy worms and install tool (for tires)
    air pump and/or co2 cartridges and dispenser
    spare oil container
    JJ
  3. Chat Lunatique
    Chat Lunatique aka El Gato Loco
    May 9, 2011
    1,472
    Niagara, Canada
    What year bike,what countries and how far will you be from a dealer??
    A spare fuel pump controller or a by-pass cable depending on the above.
  4. genka
    genka SUV hater
    Mar 25, 2010
    2,082
    Baltimore, MD
    -1 on the headlight bulb. H7 is pretty common everywhere. In a pinch, high and low beam bulbs can be swapped. I'd take a final drive seal.
  5. Veter
    Veter Motoviajero
    Oct 14, 2012
    45
    Thanks guys, I had everything except for the alternator belt and fuel pump controller :clap
    billdonna,
    bike is yr 2011. The plan is to get to all the Latin American countries and take some time in each of them, explore...So at some point I can be really far from civilization let's say in Bolivia or Peru, so that I'm better have all the crucial spares with me
  6. LaurelPerryOnLand
    LaurelPerryOnLand Long timer
    Jun 9, 2009
    3,482
    Denver, CO
    1.Battery tender if you have the space...SAVED ME twice!:clap
    2. 4 Foot section of 1/4" clear tubing for transferring fuel from another bike...in case you run out!
    Note: Not really SPARES...but may save you hind quarters.
    What others have said:
    http://advrider.com/forums/search.php?searchid=20398434
  7. Veter
    Veter Motoviajero
    Oct 14, 2012
    45
    Thanks, man! I have them and installed Shorai battery to be on the safe side :D Also as conversion to ADV tank is a pain I will have 5 jerrycans with overall capacity of 8 gallons so, hopefully, it will be hard to run out of gas :)
  8. Veter
    Veter Motoviajero
    Oct 14, 2012
    45
    #8
  9. johnjen
    Nov 28, 2001
    17,137
    If it dies in the middle of BFNo-where, at night, you'll be glad it was there.
    Realistically the chances of this happening is slim to none.
    BUT
    Once you have said lamp on the bike the chances of EVER needing it are nigh on incalculable.
    Why? Murphies law… :evil
    JJ :lol3
    #9
  10. rpt
    rpt Been here awhile
    Aug 24, 2006
    176
    CT
    If your headed to the north east bring gas.Its all you will need
    #10
  11. Chat Lunatique
    May 9, 2011
    1,472
    Niagara, Canada
    I spent a month in Peru and it's pretty hard to be "really far from civilization in Peru"....unless you consider the Peruvians uncivilized? Man, I found guys everywhere there, including the wilds. Seriously, you can get parts shipped to where you're going. Based on your info...
    1. By pass cable for fuel pump controller failure. Mine failed this year (2010 GS) and the dealer recommended carrying a spare controller as this was a very common failure. A cable is much cheaper for a temp fix and easier to install on the side of the road.
    2. Headlight and oil cooler guard for the flying rocks on dirt roads.
    3. Tire plugs and an air compressor with a plug that by-passes the can-Bus.
    4. Rubber boot that will seal the valve covers. When you drop your bike (and you will), if the valve cover is smashed, the boot slips on allowing you to continue riding without losing all your oil. Order new covers in the next town.
    5. Gas filter/funnel. Off the beaten track, fuel is really shitty and if pumped from a drum, it can be contaminated with water and sediment. There is a neat litttle funnel that strains the fuel and separates water and silt. I don't have a link for it , but I'll try to get it.
    Johnjen:
    Riding at night in these countries is suicide. Bandits, washouts, cattle, broken down vehicles, trucks in your lane on corners, all make night travel nutz, even if you run aircraft landing lights. Best to hole up in a casa with a cervesa and a chica 'til dawn :1drink
    #11
  12. Veter
    Veter Motoviajero
    Oct 14, 2012
    45
    bildonna, thanks, that's really what I needed!
    Will be looking for that rubber boot now. I had a special offroad training in Death Valley and dropped the bike like 25 times and each time I was wondering how oilhead survived an what to do when it doesn't :))
    As to the filter I use metal MSR coffee filter and it's just fine for the job as no filter can filter out water from gas at least not the one you can carry in your pocket :)
    #12
  13. Chat Lunatique
    May 9, 2011
    1,472
    Niagara, Canada
    Quote: no filter can filter out water from gas at least not the one you can carry in your pocket
    Well, not exactly true. Here`s a link to a small water separator- filter. The F1 is 6`` high and 3.5`` dia. You are going into very wet areas that supply bad fuel. Look at the ad and rethink this a bit.
    http://www.mrfunnel.com/Mr._Funnel/Home.html
    Here`s one place to get the rubber boot. Also includes a coil puller which I assumed was already in your toolkit.
    http://www.maxbmwmotorcycles.com/fiche/PartsSearch.aspx?parts=71%2060%207%20693%20897
    Have a great ride you lucky bastard!!!
    #13
  14. Veter
    Veter Motoviajero
    Oct 14, 2012
    45
    He-he damn I will, feel free to join :) And thanks for the links and info, buddy!
    #14
  15. PNWRR
    PNWRR A study in Mopishness
    Apr 29, 2011
    1,656
    Throw in a flashlight too. I know, not a spare, but...could get missed.
    :freaky
    #15
  16. Wyodrill
    Wyodrill Master Chief 1200
    May 29, 2012
    64
    NE Wyoming
    How does the coffee taste after that?
    #16
  17. 10Cup
    10Cup Long timer
    Oct 23, 2008
    2,700
    NW Arkansas
    On the trail...........probably about the same:rofl
    #17
