Spark Plug Pictures
Discussion in 'Trials' started by alpineboard, May 13, 2018.
  1. alpineboard
    alpineboard Been here awhile
    Mar 2, 2016
    602
    New Hampshire
  2. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    12,505
    Dubuque, Iowa
    alpineboard likes this.
  3. lineaway
    lineaway Long timer
    Oct 1, 2011
    8,776
    nm
    What fuel?
  4. alpineboard
    Mar 2, 2016
    602
    New Hampshire
    1 part VP16 (116 oct) Plus 4 parts 91 eth free pump gas. = 96 oct
    Or
    1 part Sunoco Supreme 112 Plus 3 parts 91 eth free pump gas = 96 oct
    Either mix used plug looks similar.
  5. lineaway
    lineaway Long timer
    Oct 1, 2011
    8,776
    nm
    Plug looks way better than mine, but running junk pump gas with the spark arrestor. The arrestor just gives too much back pressure. But my bike does run gooood.
    Norman Foley likes this.
  6. Brewtus
    Brewtus Buffoonery, Inc.
    Jul 30, 2008
    5,483
    Portales, New Mexico
    Pick one, got 8 racks of 'em...
    :lol3
  7. Norman Foley
    Norman Foley Devotee of the Husqvarna Supporter
    Mar 20, 2004
    2,296
    New York... The Finger Lakes
    I loved my old Italian Husky manuals, which the literal translation for spark plug from Italian was..... The stick which lights the fire! :D
    slicktop, alpineboard and Brewtus like this.
  8. heffergm
    heffergm Long timer
    Sep 22, 2014
    2,206
    That's a pretty good literal translation... 'candela' is spark plug in Italian. You can probably guess where the word originated (obviously it also has more than one meaning).
    #8
    Brewtus and Norman Foley like this.
  9. Bronco638
    Bronco638 Nobody Home
    Dec 1, 2004
    5,533
    Itasca, IL
    Is it me or does that plug, in the original post, look like it's slightly rich? I'm basing that on the color of the insulator and the spark tip, not the color of the electrode (which looks good, to me).
    #9
  10. lloyd193
    lloyd193 n00b
    May 14, 2018
    2
    Florida
    #10
  11. lloyd193
    lloyd193 n00b
    May 14, 2018
    2
    Florida
    The photo appearance of the plug does look rich, However to get an accurate indication, It is necessary to operate at wide open throttle under load for at least 10 seconds, Then turn off the ignition, Close throttle then visually inspect the plug. The insulator around the center electrode should appear bleached white to a very Slight tan. Make adjustments in small steps, A too lean engine will transfer Metal. A slightly rich Mixture aids in cooling the engine at W.O.T..
    #11
  12. heffergm
    heffergm Long timer
    Sep 22, 2014
    2,206
    The last time a trials motor operated at >10 seconds WOT was the last time someone detonated one after a getoff without a lanyard.
    #12
    jonnyc21, Brewtus and Norman Foley like this.
  13. Norman Foley
    Mar 20, 2004
    2,296
    :photog
    #13
    jonnyc21 likes this.
  14. motobene
    motobene Motoing for 46 years
    Mar 9, 2013
    5,328
    Wichita Mountains SW Oklahoma
    Bougie (candle) in French.
    That was a clean running engine to have such a nice plug, bun 8 hours isn't much run time. I expect a plug to last years, even the life of a bike with a cleaning every few years. If it needs it:-)
    #14
