Sold Specialized Stumpjumper FSR Pro Carbon $1100
Discussion in 'Other' started by rathawk, Sep 13, 2019.
Thread Status:
Not open for further replies.
  1. rathawk
    rathawk unbaffled noise pump
    Jul 18, 2012
    682
    Like new 2010 Specialized Stumpjumper FSR Pro Carbon 26" wheel bike, size large. Bike is in near perfect condition, everything works, the brakes could use a bleed. Bike was ridden only a handful of times and then hung up in the garage.
    Asking $1100, Also open to reasonable offers, no trades.
    Bike is located in zip 27704.
    Thanks for looking !
    Specs:
    forkSpecialized Future Shock S140TA, 140-115mm travel adjust, Trail Tune, Brain Fade, rebound adj., carbon 1-1/8" to 1.5" steerer
    rimsRoval Control AL, disc, 24mm
    stem3D forged alloy, adjustable rise, 31.8mm clamp
    chainSRAM PC-971, 9-speed w/Power Link
    frameStumpjumper FSR FACT IS carbon 8M main triangle, M5 alloy SS/CS with Brain mount, full cartridge bearing pivots, 140mm travel
    gripsSpecialized waffle lock on grip (S/M) Specialized Thick lock on grip (L/XL)
    notesProtective clear coat, derailleur hanger, reflectors, owners manual
    pedalsNone
    saddleSpecialized Format, Ti rails, SL foam, S/M/L: 130mm XL:143mm
    headset1-1/8" Threadless, 1 1/2" lower, Campy style upper and lower cartridge bearing
    cassetteShimano M770 XT, 9-speed, 11-34t
    cranksetShimano FC-M770 XT, 2pc., S: 170mm, others: 175mm
    featuresSpecialized/Fox AFR Brain rear shock with Brain Fade and adjustable rebound dials in the perfect blend of pedaling efficiency and bump compliance;All-new Stumpjumper FSR FACT 8m carbon main triangle with an M5 alloy rear triangle with full cartridge bearing pivots make this frame the perfect foundation of a lean and mean trail bandit;Avid Elixir CR magnesium body brakes with carbon levers feature tool-free reach and pad contact adjustment for power-packed performance and plenty of stopping power;Specialized FutureShock S140TA fork ,with 140-115mm adjustable travel and Brain Fade damping, integrates with the frame to create the optimal trail experience
    rear hubRoval Control AL with alloy freehub
    seatpostThomson Elite Setback w/ 12 degree clamp, S/M: 367mm L/XL:410mm
    front hubRoval Control AL, alloy, oversize 28mm axel caps
    rear tireThe Captain Control, 26x2.0", 60 TPI, tubeless ready aramid bead, dual compound
    chainrings44A x 32A x 22S, 4-bolt, 104/64mm
    front tireS-Works Purgatory, 26x2.2", 120 TPI, tubeless ready aramid bead, dual compound
    handlebarsSpecialized XC Carbon riser bar, 31.8mm, 660mm wide, 8 degree back sweep, 6 degree up
    rear brakeAvid Elixir CR Mag for SBC, alloy backed semi met pads, Elixir mag lever w/carbon lever blade and reach adj, Elixir aluminum caliper, SS hardware package, S, M: 160mm rotor, L, XL: 185mm rotor.
    rear shockSpecialized/Fox AFR Brain Shock w/ remote Trail Tune inertia valve, rebound adj. and Brain Fade, 7.875x1.9" Integrated cartridge bearing shock mount.
    front brakeAvid Elixir CR Mag for SBC, alloy backed semi met pads, Elixir mag lever w/carbon lever blade and reach adj, Elixir aluminum caliper, SS hardware package, S, M: 185mm rotor, L, XL: 203mm rotor.
    inner tubesUltralight presta valve
    seat binder7050 hard annodized alloy collar w/ QR, 36.9mm clamp ID, for carbon frame
    brake leversAvid Elixir CR Mag with tool-less reach and pad contact adj
    shift leversSRAM X-0, carbon/aluminum trigger
    bottom bracketCustom Shimano BB-91, OS, press-in bearing
    rear derailleurSRAM X-0, 9-speed, mid cage
    front derailleurShimano M770 XT, DMD, top swing, dual pull
Thread Status:
