Splicing Wires
Discussion in 'The Garage' started by trscott, Nov 4, 2007.
  1. IDRIDR
    IDRIDR Take me to the River Supporter
    Jun 16, 2010
    2,865
    Boise
    Are we pushing amps to the limit on this wire? Over a half inch segment? If so, we have a problem!
  2. troidus
    troidus Long timer
    Sep 1, 2010
    45,955
    Georgia
    It may depend on whether it's carrying AC or DC current.
    http://en.wikipedia.org/wiki/Skin_effect
  3. ttpete
    ttpete Rectum Non Bustibus Supporter
    May 13, 2009
    7,581
    Dearborn, MI
    I believe you're thinking of high frequency (RF). Litz Wire has been around for many years. The big difference is that the strands are insulated from each other. http://en.wikipedia.org/wiki/Litz_wire
  4. mefly2
    mefly2 Long timer
    Jun 28, 2010
    1,235
    Big Sky Country
    My inner elbows have scars ...
  5. troidus
    troidus Long timer
    Sep 1, 2010
    45,955
    Georgia
    There's a bar in North Lawrence that was built with welded steel beams. Where they added stiffening plates at the beam joins, it's really obvious that whoever welded it wasn't very good at welding with the stick pointed up.
  6. Pantah
    Pantah Jiggy Dog Fan Supporter
    Oct 25, 2004
    12,612
    Scottsdale Arizona
    I just bumped into this thread. I couldn't read much past the OP post, but for me, that post was GREAT!
    Most of us buy various GPS and other power outlet products. Some of us have no clue how to splice wire, and default to Home Depot crimp things.
    I finally bought a soldering iron and tried to do better with that. It actually worked, even though I didn't know what I was doing.
    But thanks to the original post, I know much better now. I may redo all my crimp things.
    'May' is the operative word.
    :D
  7. jsalman93
    jsalman93 Been here awhile
    May 20, 2012
    235
    Pasadena, SoCal
    Here is a question that hasn't been touched on yet:
    What kind of solder should I use for different connections? I watched a youtube video where someone mentioned acid solder or something along those lines. Can someone please enlighten me?
  8. mungo57
    mungo57 mmm Beer
    Oct 2, 2009
    17
    4680 Qld Aust.
    Use Resin core solder for normal copper wire solder joints, acid core will cause corrosion. Cheers Peter.
  9. johnjen
    johnjen Now, even more NOW!…
    Nov 28, 2001
    17,007
    Acid core solder is for plumbing.
    It should NEVER be used on electrical, anything.
    JJ
  10. jsalman93
    May 20, 2012
    235
    Pasadena, SoCal
    Got it. Well at least I know what it's used for. Thanks again
  11. catweasel67
    catweasel67 RD04
    Aug 18, 2009
    17,429
    Vienna, Austria
    Just wanted to add my thanks to the OP.
    I love step by step guides like this - they take a seemingly daunting task and break it down into simple steps that an idiot like myself can follow.
    Huzzah that man!
  12. Patriot4570
    Patriot4570 Trail Blaster
    Aug 5, 2002
    2,929
    First Coast
    I replaced the stator on my DL-1000. I soldered the wires and used heat shrink over the joints.To give it an extra bit of protection I wrapped electrical tape and painted liquided electric tape over the whole splice.
    The electrical system has been working good ever since and that included me changing out the rotor.
  13. v303x
    v303x Been here awhile
    Jun 19, 2006
    154
    Fort Walton Beach, Florida
    Learned the hard way on that one. I was building a test board with some 3.3V logic and used acid core on a pinch. The board ended in the trash, the cross talk and leakage to ground was un-fixable.
  14. tag346
    tag346 Roaming Adventurer
    Jun 1, 2003
    507
    Hillsboro OR
    Thanks for the tutorial and the discussion. Incredibly helpful. On my 2004 GSA I soldered the connections and they've been rock solid. On the 2014 GSA though I'm using a PDM60 and placing it in the back of the bike as others have done. In talking with the PDM60 folks they recommend 8AWG marine wire to extend the 12 (I believe) attached to the PDM60.
    There is a significant difference in wire diameter and this will make for quite a soldered splice. I would appreciate the thoughts of the experts here. I've been googling the threads here and looking at different crimp connectors but haven't found a great answer. I've seen step down connectors from Ancor but they go from 10-12 not down to 8. Excuse the lack of knowledge on this. I've looked at wiring charts and it sounds like i could go 10 for the length of the rungs instead of 8 which would simplify things a bit...
    Thanks in advance for advice...
  15. troidus
    troidus Long timer
    Sep 1, 2010
    45,955
    Georgia
    Here's an 8:
    http://www.grainger.com/product/3M-Butt-Splice-Connector-5ZNR9?s_pp=false
    On the other side, if your wire gauge is too small to fill the connector, you can strip double the length and fold it in half, then put that in the connector. If that's too big, get a short length of a smaller gauge, strip both ends and insert both ends in the connector (leaving a loop outside) along with your main conductor.
  16. tag346
    Jun 1, 2003
    507
    Hillsboro OR
    Perfect. Thanks troidus...
  17. troidus
    troidus Long timer
    Sep 1, 2010
    45,955
    Georgia
    np
