Sputnik sidecars
Discussion in 'Hack Vendors' started by jaydmc, Jun 23, 2015.
  1. jaydmc
    jaydmc Long timer
    Sep 26, 2008
    1,844
    I have another container of NOS sputnik sidecars in route, No ETA as of yet, nor do I know the condition for sure as we are not sure how well they were stored. I do know that the factory does not exist any longer and that these are coming in with out wheels as there are no wheels to be had anywhere that work with the brakes. We will be offering these with aftermarket Harley tubeless wire spoke wheels with a disk brake option.
    Pricing will be determined once I see the condition of the sidecars.
    Jay G
    DMC Sidecars
    www.dmcsidecars.com
    866-638-1793
  2. ricmachado
    ricmachado Been here awhile
    Jul 15, 2010
    355
    Longview, TX
    Any updates on this? expected price? availability?
    Just sold my sidecar and the bike, got me a new KLR and am looking for another rig
  3. jaydmc
    jaydmc Long timer
    Sep 26, 2008
    1,844
    The only update is that have confirmation that they are in route. Our plan is to offer these at $2995 with a Harley type wire tubeless wheel and bike specific mounts for about a dozen bikes. Other bikes will run a bit more. A disk brake will be a $600 up grade.
    Jay G
    DMC sidecars
    www.dmcsidecars.com
    866-638-1793
  4. ricmachado
    Jul 15, 2010
    355
    Longview, TX
    Thanks,
    I had a custom hack on my sportster (home build frame + HD body), but sold all last month, I'll be looking to mount another hack on the sportster on on my new (to me) KLR.
    I think that the sputnik may be a good choice.
  5. jaydmc
    jaydmc Long timer
    Sep 26, 2008
    1,844
    I have ran the Sputnik on the KLR, they work out well, the price of $2995 would include all of the KLR specific hardware. A couple of additional things I recommend. A stiffer spring for the rear of the bike, we sell these for $85, with our mounts you loose any skid pans you may have, we offer one that works with our mounts for $75. I also think that the brake $600 is important especially if you are going off road as coming down hill with a loaded sidecar you may find that you have enough traction with the front tire to either steer or brake but not both. Been there, no fun.
    We are taking refundable $1500 deposits to hold these sidecars and to make the bike specific mounts that come with them.
    Jay G
    DMC sidecars
    www.dmcsidecars.com
    866-638-1793
  6. JustKip
    JustKip Long timer
    Apr 28, 2007
    9,128
    Fresno, CA
    Hey Jay,
    I was looking for specs for these on the interwebs and found this on Bob Wark's website. Do you think the listed payload/GVW is pretty accurate?
    • 18 inch wheel, with fat spokes, and a fat axle
    • Weight 235 pounds
    • Acceptable load 205 pounds
    • Equals total GVW 440 pounds
    • Length 6 foot 3 inches
    • Width 3 foot 7 inches
    • Ground clearance 7 1/2 inches
    • Leg room 47 inches ( seat back to foot rest )
    • Hip room 22.5 inches, seat is 17 inches but body bulges in this area.
    • Wheel Brake, Yes !
    • Tail light and running lights
    Think it would be a good match for my F800GSA?
    Can it be had with a matching F800GS rear wheel and disc brake? (actually I'd like to have matching 18" wheels all the way around, but that's a conversation for next year's budget)
  7. jaydmc
    jaydmc Long timer
    Sep 26, 2008
    1,844
    It is pretty close as it is what is listed in the owners manual however its load capacity was more a function of the IZH motorcycle it would have been attached to. And the "Fat" axle is only a 17mm axle however we will be changing these out to 3/4 inch (about 19mm) and the brake was a drum brake standard but as we are not getting any wheels, it will not have a brake as standard, only as an option for a disk brake. It would work fine with your F800GS, changing to the GS wheel is possible, not sure on the details as I have not had an F800GS rear wheel off to see able sizes and such however I suspect that it will be to wide to fit under the stock Sputnik fender, also its brake rotor is larger diameter then we would like so a proportioning valve may be needed. At some point you may be better off just having us build you a sidecar if you want all of this custom work. We can however run an 18 inch wire wheel rather then the 19 inch we are planning on using.
    Jay G
    DMC sidecars
    www.dmcsidecars.com
    866-638-1793
  8. hogmaine
    hogmaine Been here awhile
    Jul 11, 2011
    139
    Mount Washington Valley NH
    Just curious Jay do you need any steering mod on the KLR setup?
    #8
  9. jaydmc
    jaydmc Long timer
    Sep 26, 2008
    1,844
    You never "need" steering modifications, but they are nice, they lower the steering effort, most of our KLR customers do not modify the steering, We do make a leading link front end $2000, I do recommend a stiffer rear spring on the bike, $85
    Jay G
    DMC sidecars
    866-638-1793
    www.dmcsidecars.com
    #9
  10. jaydmc
    jaydmc Long timer
    Sep 26, 2008
    1,844
    ETA on these sidecars to the Port is October 9th, how long it takes to clear customs we do not know, could be hours, could be weeks.
    We are taking $1500 deposits to hold these at this time.
    Jay G
    DMC sidecars
    www.dmcsidecars.com
    866-638-1793
    #10
  11. jaydmc
    jaydmc Long timer
    Sep 26, 2008
    1,844
    Sidecars are at the port, the department of Agriculture has put a hold on them, we no not why yet.
    Jay G
    DMC sidecars
    866-638-1793
    #11
  12. ag_streak
    ag_streak Tiene Ruta Cuarenta? Supporter
    Aug 9, 2006
    7,985
    Blue Ridge, GA
    Jay,
    Two questions, please...
    1. How many units are you expecting?
    2. The website lists the price to include mounts only for the F650, Sportster, KLR, and DR. Above you say about a dozen. What other bike-specific mounts are you planning to include for that price?
    #12
  13. jaydmc
    jaydmc Long timer
    Sep 26, 2008
    1,844
    We have a total of 35 sidecars, mounts are for a few dozen bikes that we sell the mounts for $775 for on our web site, more expensive mounts there is a slight up charge for.
    Jay G
    DMC sidecars
    866-638-1793
    www.dmcsidecars.com
    #13
  14. JustKip
    JustKip Long timer
    Apr 28, 2007
    9,128
    Fresno, CA
    What's changed?
    "As is", regardless of paint, rust, or dents?
    #14
  15. jaydmc
    jaydmc Long timer
    Sep 26, 2008
    1,844
    I have seen photo's and found that they were all stored in doors and still in their original shipping crates, they should be in good condition.
    The sidecars are at the port, the department of agriculture has put a hold on them, we have not been told why.
    Jay G
    DMC sidecars
    866-638-1793
    #15
    JustKip likes this.
  16. jaydmc
    jaydmc Long timer
    Sep 26, 2008
    1,844
    Sidecars have cleared customs, just working on getting them from the port.
    Jay G
    DMC sidecars
    866-638-1793
    www.dmcsidecars.com
    #16
    5x4 likes this.
  17. jaydmc
    jaydmc Long timer
    Sep 26, 2008
    1,844
    We will have the sidecars some time tomorrow. (9-16-2015)
    Jay G
    DMC sidecars
    866-638-1793
    www.dmcsidecars.com
    #17
    5x4 likes this.
  18. jaydmc
    jaydmc Long timer
    Sep 26, 2008
    1,844
    Now in stock.
    They are orange in color with a black fender.
    Jay G
    DMC sidecars
    866-638-1793
    www.dmcsidecars.com
    #18
  19. High Octane
    High Octane Long timer Supporter
    May 31, 2013
    3,161
    South Dakota
    Does the front flip forward on the Sputnik or does a dog have to jump over the side? Does your price include all the mountings and subframe fora Kawasukie Versys?
    #19
  20. jaydmc
    jaydmc Long timer
    Sep 26, 2008
    1,844
    The front opens, the trunk opens, the price includes the mounts but not crating or shipping. The crates that they arrived in worked for having them jammed into a shipping container where they can not fall over but would never hold up to a trucking company.
    Jay G
    DMC sidecars
    866-638-1793
    #20
