Stalling and Cutting out?
Discussion in 'Dakar champion (950/990)' started by Huber Tuber, May 4, 2006.
  1. jimboecv
    jimboecv n00b
    May 22, 2006
    6
    Wow, thanks for that insight.
    #21
  2. C.Fowler
    C.Fowler Motorcycle Grandma
    May 19, 2007
    36
    Heartland
    Your welcome.
    #22
  3. ridewestKTM
    ridewestKTM Long timer
    Jun 7, 2007
    1,878
    Mesquite NV
    I cleaned out my carbs and put a good fuel filter in the line, and haven't had much problem. But it could be I am not over-filling and loading up the carbon-canister any more.
    #23
  4. rolo tomassi
    rolo tomassi Been here awhile
    Aug 11, 2006
    334
    Matthews-land
    Wow, I've NEVER had s single problem like this. :clap
    #24
  5. busted knuckle
    busted knuckle SuperE
    Sep 12, 2006
    18
    When gasoline sits for a few months (especially in colder climes) the fuel can separate (chemically). The result is usually a varnish like substance that essetially glues (goos?) the idle jet passage(s), float bowl(s), etc. and the engine will not idle. It may start and run but only on high rpms, the engine quitting at low rpms. Happens in lawn mowers, outboards, etc. Solution is usually to add fuel stabilizer in winter. However, how that chemical reacts with the newer plastic tanks may prove that deterrant more trouble than it's worth. A possible solution is to close the fuel petcock (funny name huh?) and run the engine until all fuel is used up. Better yet woud be to unscrew the fuel bowl drain plug(s) and allow it to empty itself. (Albeit a lot of trouble, no?) Draining the fuel tank would also be in order so no separated fuel from the tank is emptied into the clean fuel bowl upon the next start. This is commonly known as a PITA! Short of these solutions, regular usage is the only alternative I know of.
    #25
  6. Venteuri
    Venteuri I don't give a shit
    Sep 3, 2007
    19,697
    Queretaro , Mexico
    bump
    #26
  7. fireproof46
    fireproof46 Adventurer
    Sep 24, 2009
    13
    Philippines
    My 2008 990adv w/ only 16,000 km has developed this problem too. But the engine only stops if i also pull in the clutch. Has anyone had a similar experience?
    Tnx
    #27
  8. Sumi
    Sumi Long timer
    Mar 30, 2010
    2,239
    Hungary
    Fuel filter?
    #28
  9. cpmodem
    cpmodem Orange Caveman
    Nov 29, 2004
    7,130
    masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
    The 990 computer uses the signal from the clutch switch to set the idle speed. Check the switch to make sure it is working. Be sure you are pulling the clutch lever all of the way to the grip, or the switch may not activate.
    See the link below for info on bypassing the safety devices for troubleshooting purposes:
    http://ktm950.info/how/wotf/wotf.html#990_clutch_bypass
    #29
  10. Sapling
    Sapling Been here awhile
    Dec 30, 2010
    413
    Sammamish WA
    After riding mine (2008) in the dirt this weekend I think I am victim of the trailing thottle cut off...
    If I rolled out of the throttle easy everything is fine.... If I quickly cut the throttle which is easy to do in the whoops with how sensitive the throttle is, it is almost like the ignition/fuel is cut and it slowly revs down until you pull the clutch then it dies.... I flip the kill switch off and back on and hit the start button it fires right back up...
    Did it at least 10-15 times and was a complete annoyance and very dangerous when the front tire goes into a whoop and there is no power to keep the tire up. I had to completely change what I was doing or I would have been tossed over the bars. (Big whoops!)
    I am hoping the clutch bypass in the link above will make this go away... Seems like a very strange feature to put on a bike at all!!
    It doesn't starve for fuel any other time so I don't think it is fuel filter related. It was a definite loss in fuel or ignition controlled by the ECU at the same time as getting out of the throttle.
    Any other advice??
    #30
  11. cpmodem
    Nov 29, 2004
    7,130
    The fuel cutoff "feature" was installed by the factory to improve emissions. It is only active above 5k rpm, throttle off, in gear, and clutch lever not pulled in.
    There are '07/'08 LC8 owners who report that they have fixed or considerably improved the fueling of their bikes with TuneUCU. Looks like this will all soon become a non issue. Just sayin' :evil
    #31
  12. Sapling
    Dec 30, 2010
    413
    Sammamish WA
    I know your a pro at these but I'm just getting here from the dirt bike world...:ear
    I have no issue with the Thotttle on this bike....:D There is lots of it...:clap to ride it aggressively well above 5K RPMS and have the thottle cut is a liability to KTM in my mind...
    I appreciate the info in your link above or I would have not known what it was... Mine will now be disabled and I will be running from those bears in the woods full time!!:lol3
    I have been following the TuneECU threads closely... I would also love to use it to turn my idle up!
    #32
  13. jimmex
    jimmex Guero con moto Supporter
    Jan 23, 2003
    4,311
    West Texas/Rico
    I just had my engine rebuilt after the bike got hot and now the engine runs fine up to about 4500 RPM them starts cutting out really bad at around 5000RPM.
    Any insight?
    #33
  14. cpmodem
    Nov 29, 2004
    7,130
    Read through some of the items here and see if any fit your scenario.
    #34
