Starter not engaging
Discussion in 'Dakar champion (950/990)' started by armstrongracer, Nov 27, 2019.
  1. armstrongracer
    armstrongracer Adventurer
    Jun 24, 2018
    30
    Dublin, Ireland
    Rode my 950sm (2006 my) to work yesterday, everything seemed ok. When I started bike up to go home all I got was the starter spinning up but the motor not cranking. Ivé had a sprag go before but they tend to announce their displeasure extremely loudly before finally going off in a sulk. Had no noise or trouble before this & it doesn't feel like a sprag. I'll be tearing her down at the weekend. Any ideas?
  2. rinho
    rinho Rinho Féroce
    Jul 19, 2009
    1,719
    back in France but Soul still in North America
    look for torque limiter/starter issue on the H.O.W
  3. armstrongracer
    Jun 24, 2018
    30
    Dublin, Ireland
    Cheers, I don't think it's a torque limiter/sprag clutch issue. I've replaced one myself in the past and that sounded like a bag of bolts in a spin dryer, even before it finally failed. All I get now is a gentle click - whiring sound.
  4. mountaincadre
    mountaincadre Long timer
    Jul 18, 2012
    1,769
    Mid Calder,Scotland
    Mine sounded exactly like you discribe and it was the sprag, if they "Go" properly then yes it sounds like a bag ae bolts but if early demise then just whirring.
  5. armstrongracer
    Jun 24, 2018
    30
    Dublin, Ireland
    Did you even get the odd clack beforehand? I've not even had the slightest squeak since sprag was replaced. Before it stopped people in the street as noise was so nasty. Sprag is my best bet, but wondering what the alternatives might be.
  6. mountaincadre
    Jul 18, 2012
    1,769
    Mid Calder,Scotland
    Nothing at all mate, it worked one day and when I went to start it the next just whirring.
  7. gearheadE30
    gearheadE30 @LC8Adventures Supporter
    Jan 20, 2012
    2,173
    Indiana
    That's generally the sprag. Usually rears its head first when it gets cold out and the oil is thick, and then if you can get it started and warmed up it will work okay until it's cold again.
    mountaincadre likes this.
  8. armstrongracer
    Jun 24, 2018
    30
    Dublin, Ireland
    Just taken case cover off, torque limiter is ok, freewheel can be rotated in both directions. "Hello Mr KTM can I have a new sprag please". Oh and I got my descriptions mixed up earlier in the thread, I've replaced the torque limiter before, the freewheel sprag is original. Also, does anyone know if KTM have started supplying LC8 sprags yet or do I have to rebuild using LC4 parts as per the knowledge base.
    #8
  9. Boatman
    Boatman Membership has it's privileges ;-) Supporter
    Mar 9, 2005
    14,137
    Mill Spring, NC
  10. armstrongracer
    Jun 24, 2018
    30
    Dublin, Ireland
    That link confuses me a bit, when you put part number quoted (60039005100) into the KTM fiche, it gives the complete rotor & sprag assy at $500+
    #10
  11. mountaincadre
    Jul 18, 2012
    1,769
    Mid Calder,Scotland
    I've seen ones advertised for 950/990 of chinese variety.
    #11
  12. Boatman
    Mar 9, 2005
    14,137
    Mill Spring, NC
    Thats because you can't buy the sprag separately from KTM thus no part number for it. Look at the diagram in the ad and they have the sprag circled.
    #12
  13. armstrongracer
    Jun 24, 2018
    30
    Dublin, Ireland
    Manually rotated the freewheel and it bit. Put everything back & bike started on the button. I'll order parts but not sure how much I can trust the bike not to let me down in the meantime.
    #13
  14. armstrongracer
    Jun 24, 2018
    30
    Dublin, Ireland
    Just rebuilt sprag assy using LC4 parts. Mucho heat and 18v Makita impact gun required to get flywheel off. By the way, that write up is superb. Thanks. One question for anyone who has done this before. Beans and retaining spring were well chewed up and the two side plates in the sprag assy had a fair bit of damage too from the beans twisting sideways. One side plate (non flanged) and the big wavy spring looked like they are the same part on LC4 and LC8 sprag assys, only the flanged plate looks like its the difference. Essentially I rebuilt my sprag using virtually all new parts from the LC4 assembly (beans, retaining spring, wavy spring, non-flanged side plate) only the flanged side plate was carried over to complete the LC8 assembly. Hopefully I've got this right, everything is going back together tomorrow so if I'm wrong on part compatibility can someone post up. Cheers.
    #14
