Starting questions 2012 Super Tenere
Discussion in 'Japanese polycylindered adventure bikes' started by liftline, Nov 12, 2019.
  1. liftline
    liftline Adventurer
    Nov 14, 2007
    75
    When starting my 2012 ST there is a delay in the starting procedure
    I hit the button one second delay
    bike tries to turn over (lets say one turn)
    then another delay
    then it starts
    I've had the bike for six months It's never failed to start
    The battery is less than a year
    I'm concerned that it's going to fail to start at some time
    what could this be?
  2. jwdub
    jwdub Long timer Supporter
    Oct 2, 2005
    1,404
    SW Washington
    When this occurs is the bike hot or cold or both? There are times when the bike is shut off while it's hot that one cylinder has got a fresh charge of fuel and is coming up on compression. When you try to restart there is a lot of resistance due to the expansion of fuel/air + compression and it will stall the starter motor momentarily. I've had this happen a number of times with the Tenere' and my Buell XB12XT.
  3. HeliMark
    HeliMark Long timer Supporter
    Jun 23, 2013
    1,312
    Tennessee
    Sounds like a weak battery, have the battery load tested. Doesn't matter if the battery is new, some just are bad out the gate.
    It takes a lot of juice to start this bike, and it sounds like the battery just barely has the umph to start it. Have you noticed the screen disappearing while starting?
  4. Ironhand
    Ironhand Adventurer
    Nov 12, 2010
    42
    Montpelier, VT
    Check the battery connections too. You never know. Simple stuff first...:-)
  5. whisperquiet
    whisperquiet Motorcyclist Supporter
    Aug 24, 2007
    2,592
    Waterloo, Illinois 62298
