1. eNewsletter Sign Up
Stebel R1200GS horn kit review
Discussion in 'GS Boxers' started by Artboy57, Feb 27, 2006.
  1. UT R1150R
    UT R1150R Long timer
    Feb 28, 2006
    11,299
    Utah
    Got the horn installed last night. As the french would say... Sacre Bleu!! this thing is loud.
    Thanks for everyone's help :clap.
    John
    #61
  2. drhines
    drhines Been here awhile
    May 10, 2005
    173
    Benton, AR
    I checked the Adv Workshop website. I was looking for a Stebel Nautlius compact. I can find a Stebel compact and I can find a Nautlius but no Nautlius compact. Which horn are you ordering for the R12GS.
    #62
  3. UT R1150R
    Feb 28, 2006
    11,299
    Utah
    #63
  4. dlew
    dlew Daypass Adventurer Supporter
    Oct 26, 2004
    2,145
    Brooklyn, NY
    Has anyone who placed an order--horn or other items--from Andrew just before he closed-up on March 2nd received their goods?
    #64
  5. markgsnw
    markgsnw WTF?
    Jan 15, 2002
    3,698
    Birch Bay, Washington US
    30 amps??!?!? what are you guys doing with this thing, welding or something? :eek1
    #65
  6. PegasoPat
    PegasoPat General Smart Ass
    Nov 18, 2005
    336
    Sarasota Fl.
    I knew that Andrew was going away so I ordered my horn from California Sport Touring Inc. I had it in my hands in two days! It took two more days for the charge to appear on my Credit Card! Now that is service. It was few $$ cheaper there two.
    Its a great horn, and worth the money no matter where you get.:clap
    #66
  7. rcompton
    rcompton I am not Iron Man
    Mar 11, 2003
    2,556
    Atlanta!
    Just installed the Stebel Nautilus on my R1150GS. After yet another close run in with an SUV, followed by my meek 'beep', and having heard this horn in Daytona at Twisted Sisters booth I knew I was ready! 15 minutes using the ready made kit (just a bracket and a couple wires..... nothing fancy) and I ave already hurt my ears! :clap
    #67
  8. rboett
    rboett posser noob 205
    Nov 5, 2002
    2,409
    nwa
    Anybody put these on a 1100GS? maybe with the 1150 kit? dunno
    #68
  9. GB
    GB . Administrator Super Moderator Super Supporter
    Aug 16, 2002
    67,860
    NJ_Bob has done it on his bike, using not the Nautilus Compact but the big ass full Nautilus.. he has a post with pics.. Look him up :thumb
    #69
  10. Big Blue
    Big Blue Adventurer
    Dec 19, 2002
    35
    Has he closed shop? I have called twice with no answer.
    #70
  11. AFekete
    AFekete Long timer
    Apr 9, 2002
    3,208
    Just busy as ever I cannot answer two phones at once.
    call me at 973-258-0034...
    I'll be waiting..
    thanks,
    Andrew
    You can also call Kurt. His number is listed on the first page of our site.
    #71
  12. Flash412
    Flash412 Elk Biffer
    Apr 22, 2003
    11,737
    Effin' 'ell
    The sucker is D-E-A-D. The horn SUCKS, it does not blow. A tuba player with emphasema makes more noise. I hereby declare the Stebel Nautilus a BIG WASTE OF MONEY. I am going to replace it with Framm knock-offs from Harbor Freight. They cost less than a quarter the money, are nearly as loud and last at least ten times as long.
    #72
  13. GB
    Aug 16, 2002
    67,860
    How did you install it? Was the trumpet facing down? I've had one for over a 2 years on my KLR and it's been through, rain, mud, off road shake and back test.. that thing blows like a freight train.... it's fantastic.
    #73
  14. Flash412
    Flash412 Elk Biffer
    Apr 22, 2003
    11,737
    Effin' 'ell
    Trumpet down, mounted to crash bar on a Gran Canyon. Mouth of trumpet was facing about 45 degrees to the left so that wheel spray did not go up into it.
    #74
  15. BiG DoM
    BiG DoM African Adventurer
    Jun 16, 2002
    2,612
    South Africa
    Ditto - but three yearson ... and one of best mods I did and began popularising it.
    #75
  16. BiG DoM
    Jun 16, 2002
    2,612
    South Africa
    Ok - this weekend I decided that my week old 1200 Adventure needed the Nautilus Treatment. I first tried one of these almost four years ago on my 1150 and posted here about it and the Nautilus has subsequently become the LOUD horn of choice. Anyway I had read that some had made bent mounting brackets etc but thought I would first have a look with an open mind ... I had a standard, non compact, new Naultilus (I have not seen the compact in SA). Removed the OEM pathetic bicycle beeper and started possible positioning - first impression was that there was no significant less space than 1150. Soon realised it would fit very easily with one flat 2" bracket. Very simply one does not use the OEM mounting bolt. You use the bolt on the LHS looking up forks that holds the forward facing subframe (there are two, one on each side just above where the OEM horn was). You bolt a flat 2" piece of flat steel or alu (as I did) drilled top and bottom - top for subframe bolt bottom for horn bolt ... and away you go... The trick is that the horn part faces forward with compressor rearward. I have pics but no smugmug. Someone pmail me who can post pics. Really is the easiest and neatest of installs. Electrically wire through relay and no CANBUS fuss!
    #76
  17. duckboy
    duckboy Been here awhile
    Nov 6, 2004
    298
    So. CA
    so i take it using the Adventurers Workshop r12gs Install kit did not require any cutting & splicing of stock wires??? :huh
    i don't want to do this mod if i have to modify the stock connectors or wires... not exactly the most electrically talented...:D
    duckboy
    #77
  18. duckboy
    Nov 6, 2004
    298
    So. CA
    anyone???
    #78
  19. Captain Ned
    Captain Ned Chafuggalooginatchacaahn!
    Dec 18, 2005
    286
    Southern Nuhvaaduh
    I installed the compact Stebel using the AW mount kit on an R1200GS. Indeed you do not have to cut any original wires and could easily return the bike to stock condition if you wanted to. Probably one of the better sub-$100 safety improvements you can make.
    #79
  20. 1WDrive
    1WDrive Here for the thrills ...
    Feb 22, 2006
    116
    Boise, Idaho
    Hi All,
    Just posting picures on behalf of BiG DoM. Thanks for sending them!
    1. The Aluminum Bracket:
    2. The bracket attached to the Nautilus, at slight angle:
    3 & 4. Views looking down into fork well from above - right hand side:
    5. View looking up forks from front - horn facing down and forward (does not touch any brake lines or snag forks)
    Cheers!
    -Heado
    #80
