Steering Stabilizer and Cushioned Bar Mounts
Discussion in 'Parallel World (790/890)' started by DustBuster, Apr 28, 2020.
  1. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    9,558
    On the Ground Laughing
    All the hyperpro products are Street dampers and will be less than ideal off pavement...
    When off road...the tire deflects and then wants to return to center....in dirt or sand the tire returns back to center slower...that is the dirt is actually acting as a return to center damper...you don't want this...you want the tire to return to center (stable) as quickly as possible....any damping back to center inhibits this....Ride sand slowly...tense up....grab the bars tight and fight the front wheel....Down goes Frazier....
    Stay loose let the tire correct....all good....a street damper acts like a tense rider off road...
    The RSC and CSC both have rebound damping...the fact that one in linear Vs. progressive doesn't make up for the fact that they are specifically incorrect for dirt....
    There is a reason ALL 790's in the Merzouga Rally were required to have a Scott's...the factory Street damper was removed...
    #21
  2. TrailTrauma
    TrailTrauma Nemophilist Supporter
    Jan 17, 2012
    6,495
    Ontario .. Superior
    Are the Scott's application-specific or could one buy a used one, and then the appropriate mount for the 790?
    #22
  3. blackSP
    blackSP Im 'in orbita ponendum simulat
    Feb 4, 2008
    1,140
    Amsterdam
    Hyperpro makes both types and I have the reactive one. The stock damper is a rebound type.
    #23
    comradecasey likes this.
  4. Nowwhat
    Mar 2, 2007
    9,558
    Man you are remarkably dense....
    #24
    Buildzall, brianbrannon and BHoward like this.
  5. Nowwhat
    Mar 2, 2007
    9,558
    A used Scott's will work...if you buy one make sure it is the dirt version not the street...
    #25
    TrailTrauma likes this.
  6. blackSP
    Feb 4, 2008
    1,140
    Amsterdam
    I'm remarkable dense?
    You really need to relax, it's only a steering damper. Amazing how worked up you get over that. Take a deep breath now brother.
    #26
  7. Nowwhat
    Mar 2, 2007
    9,558
    Not your brother...
    Stop posting bad info...
    #27
  8. el Pete
    el Pete toda su base
    Mar 3, 2009
    1,718
    colinas del norte, california sur
    And make sure to get the proper arm for your application.
    #28
    Nowwhat and TrailTrauma like this.
  9. DustBuster
    DustBuster Adventurer
    Feb 13, 2014
    37
    Scotts does make a street and dirt version, but I would bet most of their sales were dirt.
    I think the one I have has been on 4 bikes now, since the damper cost $360 new and a basic mount kit is half of that I usually take it off before selling and use the damper on the next bike, sometimes part or all of the mount transfers too, not so with the 790.
    #29
    el Pete, Nowwhat and TrailTrauma like this.
  10. TrailTrauma
    Jan 17, 2012
    6,495
    Ontario .. Superior
    I sold mine with the 500 several yrs ago, but then I got $13K+ for it so not all bad I guess.
    #30
  11. DustBuster
    Feb 13, 2014
    37
    Learned something new today...there is an easy way to tell a Scotts road damper from a dirt damper. The Road damper will have an "R" stamped stamped on the top as you can see in this picture, a dirt damper does not..
    #31
  12. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    6,825
    NW Sydney, Australia
    I wonder if one can be converted to the other?
    #32
  13. Tripleclampmoto
    Tripleclampmoto www.tripleclampmoto.com Supporter
    Nov 6, 2019
    18
    Canada and UK
    Lots of good info here, so I put an update here for those looking into XTRIG PHDS + Scotts damper mount.
    Sometime ago we updated the damper mount kit to give you more options in terms of possible positions you can install the PHDS handlebar clamps with our damper bracket. We made version 2 with a wider clamping spread than stock (90mm vs 108mm). This allows your to install the PHDS clamps at any position you want. With the stock spread (talking about the distance between the bar clamps) you were limited to only one possible for the PHDS clamps (the most forward position with spacers), stock clamps could always be installed in all four positions since they are smaller than PHDS.
    The damper mount bracket is 20mm tall. That is the minimum rise we could get away with. If you want more rise we make 10mm blocks with correct size bolts at a kit. The PHDS kits comes with optional 9mm blocks too.
    Version 2.0 is %100 compatible with stock clamps. If you decide not to use the PHDS, you won't have any issues but you always have the option to do that in the future.
    All kits include two gold or silver titanium M10 bolts and a link damper arm.
    Above pictures show TripleClamp Moto's version 2.0 Scotts damper mount kit for KTM 790 and 890:
    https://www.tripleclampmoto.com/products/tripleclamp-moto-steering-damper-for-ktm-790-890-adventure
    The original version 1.0 as posted above with other inmates is available for those who prefer that. Leave us a note about that when you order.
    And as for the PHDS, it's a fantastic product that is hard to appreciate without taking it apart. It's not just for vibration dampening. It gives you 360 impact dampening as well. You see them in use on pretty much all Dakar bikes. It is more than just squeezing a set of rubber daunts. The whole bottom cradle is floating with the handlebar while the main bracket is securely attached to the bike. This means when the clamp bolts are torqued to exactly 16nm, the rubber parts do their job without letting the bolts to get loose. You can change the rubber parts to a softer (green) or harder(red).
    https://www.tripleclampmoto.com/products/xtrig-phds-kit-for-ktm-and-husqvarna
    #33
  14. TrailTrauma
    Jan 17, 2012
    6,495
    Ontario .. Superior
    Beautiful work, as always.
    I'm just trying to figure out how to retain my HDB hardware/hand guards with something like this...:hmmmmm
    #34
  15. David_Moen
    David_Moen Long timer Supporter
    Apr 23, 2006
    2,036
    Salmon Arm, B.C. Canada Eh!
    He states that version 2.0 is compatible with stock clamps, so your HDB top clamp should work.
    #35
  16. markgrolex
    markgrolex Been here awhile
    Jul 23, 2017
    482
    West Grove PA
    Nice post on details--I just ordered your bracket/ stabilizer combo and the PHDS mounts too -all looks clean and quality!!
    #36
  17. Nowwhat
    Mar 2, 2007
    9,558
    #37
  18. ebrew
    ebrew Motorcycle A.D.D.
    Nov 4, 2005
    2,320
    Denver colo
    Yes I think they can at Scott’s
    They told me once they can
    #38
  19. TrailTrauma
    Jan 17, 2012
    6,495
    Ontario .. Superior
    #39
    Nowwhat likes this.
  20. jesusgatos
    jesusgatos fishing with dynamite
    Nov 17, 2006
    2,911
    santa cruz mtns, ca
    Be wary of any stabilizer mounts that only use two bolts to secure the adapter to the tripleclamp. KTM handlebar perch mounting bolts are already 2mm smaller diameter than most of the other moto mfgs and when you start stacking brackets things get super flimsy pretty quick. My brother purchased and broke almost every stabilizer mount made while racing hard enduros like King Of the Hammers. That's why the handlebar perch mounting bolts on our stabilizer mounts pass all the way through the stabilizer mounts and thread into the tripleclamps, so it ends up being much closer to the stock setup, in terms of strength/integrity. Not trying to sell anyone anything, only pointing this out because it's pretty easy to modify some of the other stabilizer mounts to use a second set of bolts to beef things up. Definitely worthwhile, especially on bigger/heavier bikes.
    #40
